LuftWagens Klub - Ft. Lauderdale, FL
Page: Previous  1, 2, 3 ... 266, 267, 268, 269  Next
babysnakes
babysnakes is online now
PostPosted: Mon Sep 09, 2013 9:17 am    Post subject: Reply with quote
No, I thought the engine had freed up. Pulling that won't do anything if it's good or bad. You mentioned going to Steve's so I thought it was running but poorly.
chris_skrepcinski
chris_skrepcinski is offline
PostPosted: Mon Sep 09, 2013 3:15 pm    Post subject: Reply with quote
I finally got it running but I'm pretty sure I'm down a cylinder...I'm gonna do a compression test tonight and maybe do a leak-down test too
Worse comes to worse I buy a decent used 1600 and throw it in the bug. Plus I can get a roller and throw in a motor
I know nothing...but still more than some
The Monkey From WPB
LuftWagens Klub
chris_skrepcinski
PostPosted: Mon Sep 09, 2013 7:42 pm    Post subject: Reply with quote
Checked compression....got 120-130 on 2, 3, and 4, and 90 on 1...
The Monkey From WPB
LuftWagens Klub
chris_skrepcinski
PostPosted: Tue Sep 10, 2013 3:32 pm    Post subject: Reply with quote
I keep posting and I'll be it's getting annoying...but I think I found the problem. I drained the oil and guess what came out? Certainly not oil...
I guess the carb leaks gas so my case was full of fuel and oil. Next step would be a rebuild of the carb and possibly the motor? Or can I just use a cleaner like SeaFoam or somethin?
The Monkey From WPB
LuftWagens Klub
babysnakes
PostPosted: Tue Sep 10, 2013 4:28 pm    Post subject: Reply with quote
This is the point I was trying to make. The fuel solenoid shut off valve is not working properly. It is intended to stop fuel flow when the ignition is off. Change the valve as it's the least expensive fix at this point. You will need a rebuild at some point with that 90 psi number. Fix the valve and roll it for now, and start saving for a good rebuild.
Bender
Bender is offline
PostPosted: Wed Sep 11, 2013 6:35 pm    Post subject: Reply with quote
good call Eric ........
Bite my shiny metal ass
'59 Twin Turbo Vert Beetle
'65 13 Window Deluxe
LuftWagens Klub Candy-ass free
Fort Lauderdale, Florida
chris_skrepcinski
PostPosted: Wed Sep 11, 2013 8:12 pm    Post subject: Reply with quote
As of today:
New plugs (gapped at .024)
Older Bosch plug wires (the Brazillian ones fell apart)
Compression still at 90psi in #1; all others at 125psi
Drained gas from sump and put in new oil
Valves (gapped at .006)
Pulled out fuel cut-off solenoid. The plunger seemed kind of loose :\
Checked float, float tank full of fuel
Car does not start without holding the gas pedal down a little. Also backfires and makes what sounds like a knocking noise. All at low idle.
If I bring up the rpm's, it all goes away but it still sounds like it's struggling to run.
Eventually I'll rebuild the carb, and if necessary, buy another 1600 and rebuild the one in the bug now.
The Monkey From WPB
LuftWagens Klub
babysnakes
PostPosted: Thu Sep 12, 2013 2:42 am    Post subject: Reply with quote
Did you put it back in, or replace it with a new one?
chris_skrepcinski
PostPosted: Fri Sep 13, 2013 1:43 pm    Post subject: Reply with quote
I put it back in after I tested it and it opens and closes correctly. I'll probably replace it but for now it works.
Also, I adjusted the timing and now it idles...rough, but ut idles. Only time it's really bad is when I give it gas. The motor shakes real bad then it evens out. Pulled plus one and two and there was no change, but three and four made the engine slowly die. I'm wondering if it's a bad seal or something and that's causing one and two to not have enough combustion. The car moves under it's own power, but it's a hell of a lot slower than it should be
The Monkey From WPB
LuftWagens Klub
babysnakes
PostPosted: Fri Sep 13, 2013 1:53 pm    Post subject: Reply with quote
How are the intake boots? Did you spray any carb cleaner or starting fluid on them? If they are bad, and you spray them the idle will change.
chris_skrepcinski
PostPosted: Fri Sep 13, 2013 2:24 pm    Post subject: Reply with quote
They seem fine. I sprayed carb cleaner on them and there was no change
The Monkey From WPB
LuftWagens Klub
babysnakes
PostPosted: Sat Sep 14, 2013 4:45 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=570079
chris_skrepcinski
PostPosted: Sat Sep 14, 2013 9:18 am    Post subject: Reply with quote
Now she purrs like a kitten....a dirty, oily, loud, kitten lol
Still leaks fuel I believe, so I'm gonna get a fuel shut-off solenoid today from McNab and see how that turns out. Otherwise I'll rebuild the carb
The Monkey From WPB
LuftWagens Klub
chris_skrepcinski
PostPosted: Thu Sep 19, 2013 2:24 pm    Post subject: Reply with quote
So...anything going on tomorrow?
The Monkey From WPB
LuftWagens Klub
babysnakes
PostPosted: Thu Sep 19, 2013 3:12 pm    Post subject: Reply with quote
I'll be chillin' at home. Bus is in Miami getting welded on. Pick it up on Sat. Won't be driving for a while. Doing a refresh. Pushrod tubes, solid rockers, possible valve replacement and maybe some other shit.
dirtylawnchair
dirtylawnchair is offline
PostPosted: Tue Sep 24, 2013 12:35 pm    Post subject: Reply with quote
Guys,
Here is the link to the Friday night before Bulli Brigade party.
The Warm Up ~ presented by the dirtylawchair crew
http://www.thesamba.com/vw/forum/viewtopic.php?t=571130
Paulie
63 Standard OG paint
Bender
Bender is offline
PostPosted: Thu Oct 10, 2013 10:03 am    Post subject: Reply with quote
Again, Thanks Al...........On another note...I don't think Bug jam is in the cards for me this year.... Crying or Very sad
HighTopBay
HighTopBay is offline
PostPosted: Thu Oct 10, 2013 7:52 pm    Post subject: Reply with quote
Hey all, we also this going on Saturday of Bug Jam weekend Smile
Louis DePaolis
chris_skrepcinski
PostPosted: Fri Oct 11, 2013 2:02 pm    Post subject: Reply with quote
Anything going on this evening?
The Monkey From WPB
LuftWagens Klub
daltondragger73
daltondragger73 is offline
PostPosted: Fri Oct 11, 2013 7:36 pm    Post subject: Reply with quote
http://www.bing.com/videos/search?q=crickets+chirp...DCF1A0E99A
Shine Dont Mean SHIZZZ!!
[url=http://www.vw-mplate.com/mplate2-6559.png]Click to view image[/URL]
71 9 passenger (LOW budget)
Chip Fuchs wrote:
How about Medium size for the smaller ones amongst us??? As you know most fat chicks are being ridden by skinny guys!!!!
Page 267 of 269
