ztnoo Samba Member
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Fri Aug 10, 2007 5:49 pm Post subject: |
And at $7.50 for both sides, it's very affordable! |
bciesq Samba Member
Joined: April 13, 2005 Posts: 495 Location: Orlando, FL
Posted: Sat Aug 11, 2007 3:05 am Post subject: |
klokard wrote: |
FreakCitySF, I'm cut to the quick that you would think I'd post a pic of someone elses car. That is indeed MY car. I have included a pic of the car sitting in my driveway. As you can see the entire car is as clean as the engine compartment. |
I know that you were joking about taking offense to FCSF's statement, because having your car mistaken for a TS show car is quite a complement.
Wonderful job on the car BTW, you should be proud. _________________ '73 Thing -- making 45 mph exciting again. |
klokard Samba Member
Posted: Sat Aug 11, 2007 8:40 am Post subject: |
bciesq- Thanks. I was in fact giving a poke in the ribs to FCSF. That's always fun to do. |
Kustom41 Samba Member
Posted: Sat Aug 11, 2007 9:58 pm Post subject: |
Ian Epperson wrote: |
The stock oil cooler sticks up from the top of the engine on the left side, inside the cooling shroud. That first image is the picture of the stock '73 cooler as it looks when you look at the engine (back of car). That third picture is the opposite side (front of car).
Nice and confusing Ignore Woreign's second pic for less confusion. I doubt you'd be able to accidentally find that shroud - it's pretty rare.
The '73 shroud is flatter on the top to fit better in the Thing's engine compartment. It has the little fitting on the right hand side (the red arrow is pointing it out in the first shroud picture) and has the extra air ducting for the oil cooler.
Bug shrouds are cheap and abundant - but they are more round at the top and almost always have the ports for the heat exchangers (2" or so tubes on the left and right side). |
Here is what I have, correct for the thing or not?
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Sun Aug 12, 2007 12:33 am Post subject: |
Kustom. that's a 36HP shroud -- the right shrouds are flatter on top.
And, wow, if there's still a hook-up for real asbestos heater riser gaskets, I'm buying a bunch! _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Posted: Mon Aug 13, 2007 6:28 am Post subject: |
I will probably post this up in the classifieds but since we are talking about it does anyone have one they want to sell?? |
Thingggg Samba Member
Posted: Mon Aug 13, 2007 11:39 pm Post subject: |
Are you looking for Thing 73 fan shroud? |
Posted: Tue Aug 14, 2007 6:00 am Post subject: |
alsehendo34 wrote: |
I am looking for one without the heater hose ports |
ztnoo Samba Member
Posted: Tue Aug 14, 2007 6:27 am Post subject: |
Kustom41,
Then you are looking for a '73 shroud.
They are around, but getting more rare by the day.
You can expect to pay $200-250 for one in decent shape. |
Posted: Tue Aug 14, 2007 12:28 pm Post subject: |
This is stock correct engine, correct?? (got it off of ebay)
Maybe a different carb?? |
markie61 Samba Member
Joined: April 11, 2005 Posts: 583 Location: Northern Virginia
Posted: Tue Aug 14, 2007 1:12 pm Post subject: |
I dont see the vacuum can on the distributor (replaced by a 009 - too bad!) and there seems to be some emmssions stuff missing (no big loss). But, it's pretty close.
Mark _________________ Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!? |
Posted: Tue Aug 14, 2007 2:26 pm Post subject: |
markie61 wrote: |
Mark |
Nice I think I have it dialed in now, thanks again for everyones help
J.D. |
npconnor Samba Member
Joined: February 13, 2007 Posts: 194 Location: Central Texas
Posted: Sat Aug 18, 2007 12:35 pm Post subject: |
klokard wrote: |
100% stock except for "optional" dual air cleaner assembly.
The bottom one is my engine... see how I don't have the two hoses going from the engine down? What are those hoses/connecters and what do they do? Is it bad if I don't have them? _________________ '73 Thing
Austin Air-coolers Gang |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Sat Aug 18, 2007 5:16 pm Post subject: |
Are you referring to the 2 inch diameter feeds, one on the left and one on the right of the engine tin that I circled in yellow? That engine tin is for a '74 Thing - they go to heat exchangers in the exhaust to provide heat to the passengers. Since you've got a '73, none of the duct work is there, and you've probably got a gas heater to do this job.
These are just wasting your cooling air by blowing it around the engine compartment. Most VW shops sell caps for these - I've even used some old spray can caps and duct tape for the ghetto look. You've just got to block them off to help out with cooling. If you've got $$$ and want to go stock, you can try and find a '73 Thing shroud that doesn't have those (and has slightly different internal baffling) - but they're hard to come by because the offroad crowd loves to use them.
OK, you're obviously missing the fan belt, but I think you knew that
You're also missing the breather tube that goes between the oil-bath air cleaner (big black thing on the right) and the engine. It connects right next to the oil filler cap and goes to the same size hold on the air intake - I drew where it should be in green. Without this, you're polluting the air and blowing oil around your engine compartment. The proper part is a formed elbow and is pretty cheap. Don't ghetto this one up - I did that once with some cheap hose, and when it kinked, oil leaked from EVERYWHERE because the case couldn't breathe.
Finally, there's supposed to be a vacume hose between the air cleaner and the carb - drawn in red. If you look below the carb on the right, you'll see a small fitting for a little 4mm (I think) hose. Leaving this open can make your car run poorly, so you'll want to take care of it. See that small hose already on the air cleaner? If you look where it connects, you'll see another 4mm fitting that's open. Get some cheap hose and connect these two together and your engine will run better.
One more item, that silver box on the left doesn't look like it's doing anything anymore but taking up space (purple X). It's the regulator for the stock generator - but someone changed out the generator and put in a (much superior) alternator on your engine. The regulator on your alternator is internal, so when they installed it they bypassed that silver box. Not a big deal at all.
Your fuel filter is BLACK! It's supposed to be see-through so you can see how clogged it is. They're only $2 or so, so you should probably replace it.
I don't know what that silver box is for - attached to the shroud shown above the oil filler. Maybe a junction box for the alternator wiring? |
thinghunter Samba Member
Joined: May 18, 2004 Posts: 403 Location: North Texas
Posted: Sat Aug 18, 2007 5:21 pm Post subject: |
I think that silver box is the regulator for the alternator, not all of them had internal regulators |
Posted: Sat Aug 18, 2007 6:29 pm Post subject: |
After you connect the vacuum hose between the air filter and the port below the carb, you will also want to install the duct hose that connects to the end of the air filter and passes through the hole in the engine tin. Once through the tin, it connects to a metal elbow that collects warm air from the cylinders. It is the large hose on the right in this photo:
And it connects to this elbow:
If you need the elbow, Bughaus sells it for $12.95. Other vendors sell it for $42.50! Be sure to shop around... |
Posted: Sat Aug 18, 2007 8:05 pm Post subject: |
These are just wasting your cooling air by blowing it around the engine compartment. Most VW shops sell caps for these - I've even used some old spray can caps and duct tape for the ghetto look. You've just got to block them off to help out with cooling. If you've got $$$ and want to go stock, you can try and find a '73 Thing shroud that doesn't have those (and has slightly different internal baffling) - but they're hard to come by because the offroad crowd loves to use them. |
Alright, just stop them up and I'm good?
Quote: |
OK, you're obviously missing the fan belt, but I think you knew that |
haha, yes I fixed it by MYSELF if you can believe that.
Quote: |
You're also missing the breather tube that goes between the oil-bath air cleaner (big black thing on the right) and the engine. It connects right next to the oil filler cap and goes to the same size hold on the air intake - I drew where it should be in green. Without this, you're polluting the air and blowing oil around your engine compartment. The proper part is a formed elbow and is pretty cheap. Don't ghetto this one up - I did that once with some cheap hose, and when it kinked, oil leaked from EVERYWHERE because the case couldn't breathe. |
I was actually wondering why I there was oil all over my engine. (Dear God what would I do without you?) "/smacks himself"
Quote: |
Finally, there's supposed to be a vacume hose between the air cleaner and the carb - drawn in red. If you look below the carb on the right, you'll see a small fitting for a little 4mm (I think) hose. Leaving this open can make your car run poorly, so you'll want to take care of it. See that small hose already on the air cleaner? If you look where it connects, you'll see another 4mm fitting that's open. Get some cheap hose and connect these two together and your engine will run better. |
Will do. 4mm hose at both ends, should be easy enough to find right? Anyone confirm this for me?
Quote: |
One more item, that silver box on the left doesn't look like it's doing anything anymore but taking up space (purple X). It's the regulator for the stock generator - but someone changed out the generator and put in a (much superior) alternator on your engine. The regulator on your alternator is internal, so when they installed it they bypassed that silver box. Not a big deal at all. |
Wait a second... something is actually GOOD on my Thing? Damn, looks like I'm starting to do something right!
Quote: |
Your fuel filter is BLACK! It's supposed to be see-through so you can see how clogged it is. They're only $2 or so, so you should probably replace it. |
It LOOKS black, it's actually clear and I can see fuel in it. It was black but then I scraped a good 1/8 inch of black... something off it. But should I have a replacement just in case?
Yeah, if I remember correctly... it's not attatched to anything. eBay time! :wink
Edit was for messing up my quotes. _________________ '73 Thing
Posted: Sat Aug 18, 2007 9:18 pm Post subject: |
npconnor wrote: |
['74 fresh air ports] Alright, just stop them up and I'm good? |
Yeup.
npconnor wrote: |
[Fuel filter] LOOKS black, it's actually clear and I can see fuel in it. It was black but then I scraped a good 1/8 inch of black... something off it. But should I have a replacement just in case? |
They're cheap. Most VW shops have a box of them near the register - like candy! When I went through my spares the other day, I found I had 2 extra. It doesn't hurt to carry one - if someone dumps stuff in your tank (like sugar), you'll have to change it out to keep running.
Also, there's a lot of debate on this point, but I think it's better to have the fuel filter before the pump. It'll help protect the pump and, if there's a fuel leak, it's less likely to leak into the distributor and cause a fire. |
