bowser Samba Member
Posted: Mon Apr 06, 2015 1:41 pm Post subject: |
Atl Darrick wrote: |
9s in the rear. 8s up front....stock fenders |
that looks sick, can you post some more pics now it's painted?
What is the back spacing on them? |
VolkDubz Samba Member
Posted: Tue Apr 07, 2015 11:30 pm Post subject: |
Great thread! |
atcryder250 Samba Member
Joined: October 20, 2008 Posts: 4 Location: California
Posted: Mon Apr 13, 2015 1:57 pm Post subject: |
I've owned this this car for nine months and used this thread numerous times to get the ride I wanted. Here is my contribution. Thanks Samba members for the help.
Front: 2.5" CB drop spindles 165-60-15 continental tires stock smoothies
Rear: stock 195-60-15 continental tires 7" Deep Smoothies
Front: 4" narrowed Jer_Fab Airbeam 2.5" CB Spindles 165-60-15 continental tires stock smoothies
Rear: 3" Jer_Fab drop spring plates air shocks 195-60-15 continental tires 7" Deep Smoothies
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3150 Location: Goodyear, AZ USA
muravr Samba Member
Posted: Mon Apr 20, 2015 12:00 pm Post subject: |
Before/after lowering...
And with NOS yellow front lenses..
FatherProphet Samba Member
Joined: January 02, 2005 Posts: 110 Location: Stanford KY
Posted: Sun Apr 26, 2015 12:31 am Post subject: |
1960 Beetle
6 1/2 inch narrowed front beam built by Sam Manis II at Autowerks Suspension
2 1/2 inch drop spindles
Rear plates extended by Micheal Womack
Down 2 outer clicks in rear
Front 145/65
Rear 205/65
BBT Sprintstars
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Sun Apr 26, 2015 6:42 am Post subject: |
My 54 Stratos Silver Oval
4 in narrowed front beam, with disc brakes
Rear down 1 inner spline
Front Rims are 5" wide, 3.5" Backspace - 185-60 tires
Rear Rims are 6" wide, 4.5" backspace - 205-65 tires
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Sun Apr 26, 2015 8:48 pm Post subject: |
Happen to have a side shot of that? Seems like it has a good stance and real tires on it! |
Thomanick Samba Member
Posted: Thu Apr 30, 2015 9:38 pm Post subject: 67 lowered |
67
Front
Contipro 155/60r smart car
Stock wide 5 powder coated rims
Adjustable 4"narrowed beam
Drop spindles 2 1/2"
Doetsch shocks
Disc brakes
Rear
185/65r conti pro
Stock wide 5 powder coat rims
2 outer notches
Doetsch lowered shocks
Drum brakes
Custom bump stop
Thomas Lindemann Samba Member
Joined: May 07, 2013 Posts: 111 Location: Gloucester, VA
Posted: Fri May 01, 2015 5:42 am Post subject: |
could you post a side view of your car? |
Krmnnghia Samba Member
Joined: March 28, 2005 Posts: 797 Location: Michigan, Land of salty roads!
Posted: Fri May 01, 2015 5:49 am Post subject: |
Thomanick wrote: |
Rear
185/65r conti pro
2 outer notches
Drum brakes
Custom bump stop
Seems pretty high for 2 outer notches of course all cars are a little different. Looks great. |
Mayor Marion Berry Samba Member
Joined: August 30, 2014 Posts: 119 Location: Fredericksbug VA
Posted: Fri May 01, 2015 10:30 am Post subject: |
What drums are those? |
Miklo ¡Chale!
Joined: August 27, 2008 Posts: 2058 Location: Antelope Valley, Ca
Posted: Fri May 01, 2015 11:40 am Post subject: |
They are front disc.
CB's perhaps? _________________ ✠Miklo✠
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote: |
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche... |
Posted: Fri May 01, 2015 9:13 pm Post subject: |
Krmnnghia wrote: |
Thomanick wrote: |
Rear
185/65r conti pro
2 outer notches
Drum brakes
Custom bump stop
Yeah it sat pretty high before I dropped it down... Maybe I'll go down another notch. Not sure yet. This is a almost a daily driver so I'm not trying to bottom out whenever I hit a pot hole. Might just raise the front a little more just to level things out but I don't have a low profile jack DOH! I might just have to get it up on some 2x4's lol First time lowering.
I feel like disc brakes are a bit overkill for a bug. I mean unless you drive it like a Subwru wrx. When I upgrade my motor I'll go with a little more stopping power and probably look into BAD series brakes with wildwood calipers from airkewld. For now I figured empi disc brakes are fine and they stop really well. No issues with flexing. Turning the bleed valve vertical helped get all the air out of the system. I'm happy with em.
Thanks for the comments
I'll try to post more pictures when I can |
brotherZ Samba Member
Joined: May 01, 2013 Posts: 39 Location: Salem, Oregon
Posted: Sun May 03, 2015 6:02 pm Post subject: |
Hey guys, can anyone tell me if it is perfectly safe to run 1 outer spline? Can the gear oil reach the bearings at this angle? I have 2.75 drop plates with 205/70s and the outer end of the axle is higher than the transmission side. I am running a big engine and don't need extra wear on fulcrums. Thanks |
Yorvo Samba Member
Joined: March 30, 2008 Posts: 131 Location: Lake Havasu City, AZ
Posted: Sun May 03, 2015 11:37 pm Post subject: |
For JonJonfromGuam
Dropped two splines on the rear (outer) and EMPI drop spindles up front. Tires are 145 up front and 165 in back. |
dbo@samba Samba Member
Joined: March 31, 2009 Posts: 15 Location: Central Coast of California
Posted: Tue May 05, 2015 10:12 am Post subject: 66 |
Front:
175/65/15"narrow, drop spindles, stock shocks, 2.5 ground clearance, zero front camber
Rear:
205/65/15, 3/8 wheel spacer, stock shocks, 2 outer clicks
Ride is good, but I want it to handle better.
smitty24 Samba Member
Joined: April 28, 2008 Posts: 2723 Location: Salem, Oregon
Posted: Tue May 05, 2015 9:15 pm Post subject: |
^^Nice car man! Some drop plates would help you out if the rear is that bad. |
hewica8 Samba Member
Posted: Sun May 24, 2015 5:10 pm Post subject: |
Finally have my setup dialed in to contribute after countless references to this awesome thread.
Front:
Stock smoothies with Firestone F560 145r15 tires
2.5" drop spindles on a 4" narrowed beam
Rear:
Smoothies widened to 6" with stock backspace and Firestone FR710 205/70r15 tires
Springplates reindexed 14 degrees down, equivalent to about 1.5 outer splines
pete94533 Samba Member
Posted: Mon Jun 01, 2015 11:28 am Post subject: |
Front:
15x6 cookies with 195/50s
2" narrowed beam w/adjusters and dropped spindles
CB Performance 5x130 front discs
Rear:
15x7 cookies with 205/60s
2 clicks up on the outside, 1 click down inside
CB Performance 5x130 rear discs
Does anyone else with a lowered rear end and fat rear tires/wide rims have a problem with the tire rubbing on the rear body mount? If so, what did you do about it? Spacer? Grinder? Raise the rear a click to remove some of the negative camber? |
