Pictures of tire, wheel, and suspension thread for FAQ's
Goto page Previous  1, 2, 3, ... 80, 81, 82  Next
VOODOOKING
Samba Salami Slapper
VOODOOKING is offline
PostPosted: Sun Aug 12, 2007 6:44 pm    Post subject: Reply with quote
FRONT
current set up...
6 inch narrowed beam
2.5 CB drops
135 Diamondback whitewalls ($650 Nankangs with a white wall cut into them Shocked )
flipped tie rods
Chrome Rader repops ( still hasnt grown on me with the WW's,.. so stocks are going back on)
REAR
current set up...
KCW 2 inch tranny raise
2 outers
145 Diamondback white walls
Chrome Rader repops
notched spring plates
currently look like this:
Stockers going back on soon,.. possibly some other color than red
VOODOO KINGS CC.
HWVWC
Ost Kuste
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Sun Aug 12, 2007 7:02 pm    Post subject: Reply with quote
Front:
7" Narrowed beam, no shocks
Stock Smoothies
135's with Port-a-Walls
Rear:
3 Notches
Notched Springplates
No Shocks (might try to find some that will work)
Stock Smoothies
165's with Port-A-Walls
Jason C
Jason C is offline
PostPosted: Sun Aug 12, 2007 8:47 pm    Post subject: Reply with quote
It would be nice to have one of these (Pictures of tire, wheel, and suspension thread for FAQ's) in the offroad forum too.
Throw me a bone here. All I wanted were
sharks with friggen laser beams attached to their heads.
64 Bug
PostPosted: Sun Aug 12, 2007 10:17 pm    Post subject: Reply with quote
Let's try to keep personal comments to private contact. Please post your setup or questions related to set ups only.
How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
Michael Fischer
Michael Fischer is offline
PostPosted: Sun Aug 12, 2007 10:26 pm    Post subject: Reply with quote
Up front
7 1/2" beam no shocks SAW adjusters built by me.
CB drop spindles built by me.
Flipped tie rods.
3 1/2" spindle mount wheel with a goodyear 125 temp.
In the back
67 axles
3 and a half clicks
5" Randar with a 165
The shocks that came with the car
I tried to go 4 clicks in the back. The shocks wouldn't fit and the tires hit the body.
Germanpride
(O\U|U/O)
Germanpride is offline
PostPosted: Mon Aug 13, 2007 2:53 am    Post subject: Reply with quote
My 58:
Front-
4" beam, no shocks. Built by me
CB spindles
Hammered headlight buckets
175/60R14 on Bus wheels
Didn't rub too bad except on the top of the tires
Same tires on the 6"? wide 14" Pacers
Tires rub BAD both on top, inside (a little) and outer fender lip
Bottom SAW adjuster broke off, car continually lowers itself.
Rear-
3 notches down
165R15 on smoothies rubbed on inside fenderwell at the top after a couple months of driving
No shocks
195/65R15 on the Pacers don't rub, but are REAL close on the inside (too tall for me)
Bottomed out stock shocks
Notched springplates with extensions made by me, modified Hobbes design.
Short axles
(O\U|U/O) Top Vw (o\UU/o)
64 W/T Standard-Rustbucket driver
Lee.
Samba Animal Controller
Lee. is offline
PostPosted: Mon Aug 13, 2007 7:34 am    Post subject: Reply with quote
Front:
4" Hamburger Brad Signature Series Narrowed Beam
No shocks
CB dropped spindles
Stock 63 drum brakes
Nothing done to tie rods or headlight buckets
5.5 American Eagle 5-spokes
175/55/15 Continentals
Rear:
Springplates set at 4 deg (2 notches?)
No shocks (bounces all over but I'm deciding what kind to get)
Short axles
Springplates are not notched (It's on my to-do list)
195/60/15 Cheapos
AnimalsInTheAttic
lowrange2
lowrange2 is offline
PostPosted: Mon Aug 13, 2007 11:14 am    Post subject: Reply with quote
Front:
CB Drop Soindles
2" narrowed Beam
2" Wider fiberglass fenders
Caster shims
245 45 17 on 17x8 Rims with some huge backspacing...
Air Cylinders on instead of shocks (Formerly Airkewlds air shocks)
Rear:
2500 LB Bag
No torsions
Crazy Notched Spring Plates
Airkewlds original bag bracket setup.
Short ass shocks...
If i put some tiny wheels on it like all you guys have it would sit flat on the ground... Sorry about these horrible pictures... The pic of just the pan is the best i had to show for the clearance I have.
Scrubs the fender a lil at full drop while turning. but other than that with a lil steering bump stop it scrubs nothing.
scottvw
scottvw is offline
PostPosted: Tue Aug 14, 2007 4:14 pm    Post subject: Reply with quote
Front:
4.5" Porsche Fuchs
145 Firestones
CB Drop Soindles
2" narrowed Beam
Caster shims
KYB Shocks
Tie rod flip kit
Rear:
Deep 6" Fuchs
205-65-15 Warrior
Adjustable Springplates
KYB Shocks
Frankenbeetle
Frankenbeetle is offline
PostPosted: Mon Aug 20, 2007 7:31 am    Post subject: Reply with quote
Edit; Placeholder for pics of my suspension
(sorry glandnut)
Edit #2; Caster shims. I've dropped my front about 5 inches, and only have one set up front. Should I be using 2 sets of shims and lowered ball joints and lowered shocks?
Samba Whipping Boy of '07
Tram wrote:
That explains it. Jihad supplies ain't cheap! Very Happy
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
attack chicken
attack chicken is offline
PostPosted: Mon Aug 20, 2007 10:55 am    Post subject: Reply with quote
Here is mine. I have a 6.5 in. beam, 2.5in. spindles, no shocks in front, 145's in front on factory wheels and 205/60's out back. All around drums. The beam is adjusted almost all the way up. Some rubbing on the inside top when turning but none on the fenders. Need some caster shims and I will be happy. It rides pretty smooth otherwise.
erok81
erok81 is offline
PostPosted: Thu Aug 23, 2007 7:06 pm    Post subject: Reply with quote
Here is mine.
Front
~6 inch narrowed front by me with stock bushings. SAW adjusters, only the top one is in, no shocks. Also no drop spindles...yet.
145/65R15 Continentals in the front with smashed buckets. They still rub.
Rear
2 splines down with stock shocks. It bottoms out all over the place, the tires rub the fenders on big bumps and have about 1/4 of room before they hit the suspension items. Also notched spring plates. 165R15 tires.
Needs drop spindles so I can get the front a bit lower.
glandnut
40 horses of Fury
glandnut is offline
PostPosted: Fri Aug 24, 2007 12:32 am    Post subject: Reply with quote
Doesn't sound like your current set-up is working out so great. Maybe you could get some 175/55's up front instead because with future drop spindles and your current tires, you'll rub even worse. I hate to hear people pounding the backs of the headlight buckets, I just don't think it's really necessary most of time. Spindles will help center the front tires back in the wheel well and lessen or eliminate the headlight scrubs with 175's.
Looking for aluminum single port Kadron manifolds.
Slowlow Premium Member
Slowlow is offline
PostPosted: Fri Aug 24, 2007 8:03 am    Post subject: Reply with quote
He isnt talking about 145/80 Nankang.. he has the NEW 145/65
which is smaller than a 135
The drop spindles will move his front wheels BACK in the fenderwell and reduce the amount of rubbage.
A car without spindles that is low, gets that volksrod look as the wheels go to the VERY front of the fenderwell.
a 175 55 WILL work, but its so wide that it will rub the inner fender like HELL with a 6" beam when turning
*Autowerks Suspension*
sled
sled is offline
PostPosted: Fri Aug 24, 2007 8:37 am    Post subject: Reply with quote
sam is correct. (slowlow)
SK692A
L 53
L 312/L311
WTB set of 6.70-15 bias plies
Slowlow is offline
PostPosted: Fri Aug 24, 2007 2:36 pm    Post subject: Reply with quote
Update... Changed to stock wheels, so actually narrowed the front track by a HAIR
62 Beetle
Front -
4" narrowed adjustable beam, home built
NO shocks
CB drop spindles
135's on stock smoothies
Stock drum brakes
Rear -
Two outer splines
stock shocks
165's on Stock smoothies
Stock drum brakes
66vw2nv
66vw2nv is offline
PostPosted: Wed Sep 12, 2007 11:09 pm    Post subject: Reply with quote
front has air shocks with 125 temps and stock width beam
rear is solid on stock plate that need notched 3 outer spilnes i think may be 4?? 165 tires all on polishe 5 spokes...rear air to be continued Sorry shitty camera
PURE ENVY CAR CLUB MEMBER
TCB GARAGE WORKER
FLAT-WHITE 1966 VW BUG
sled
sled is offline
PostPosted: Thu Sep 13, 2007 5:32 pm    Post subject: Reply with quote
125 temps on a 5.5 is a terrible idea.
go with a 175/55/15 PLEASE before you hurt yourself or someone else.
SK692A
L 53
L 312/L311
Mine126
Mine126 is offline
PostPosted: Tue Sep 18, 2007 8:47 pm    Post subject: Reply with quote
Awsome thread
Would love to see some life back in it! Working on my dream at the moment, but would love to see other pics of peeps playing in the dirt!
More names of places to get 4" narrowed beams be cool, but I think i have mine picked out.
Hope to have my ride up here soon.
66vw2nv
66vw2nv is offline
PostPosted: Fri Sep 21, 2007 11:58 pm    Post subject: Reply with quote
Ok sled was right 125 temps are very bad!!!! went back to 4.5 steelys and 135's on them. The 125 was short and worked when i only drove it 5 miles to and from work but on a 70 plus mile trip they melted and in a town of like 30 people i was up shi# creek with no spare tires in town.
TCB GARAGE WORKER
Page 2 of 82
