Goshen Samba Member
Joined: April 03, 2012 Posts: 833 Location: Miami. FL & Cartagena
jdpatv Samba Member
Posted: Tue Jan 28, 2014 11:17 pm Post subject: |
1967 stock rear, 2 1/2 spindles up front. 165s in rear, 145s up front
suicidedoordavid Samba Member
Joined: July 07, 2004 Posts: 147 Location: 10.34 miles WEST of New Orleans
Posted: Thu Jan 30, 2014 5:55 am Post subject: |
5 inches narrowed custom made with adjusters, no shocks originally, but i modified brackets on the fenderwell to attach link pin shocks.
2.5 in dropped spindles with flipped and narrowed tie rods.
rear is custom made 3 inch dropped spring plates, RAISED 1 inner spline.
tires are front 145/65/15.... rears are 185/60/15s
front beam is adjusted almost as low as it can go, and it's sitting 1.5 inches off the ground.
rear fender height this evening on 32PSI.
front fender height today on 30PSI.
all in all, this boy scrapes on most high spots in the road. i go around speed bumps because i KNOW i will drag at least 3/4 of the pan. the suspension bounces soft and i feel it all. i am using short '65 link pin shocks all the way around. the rear shocks bottom out when i dump the clutch quite often. i think i can rid of the extra bounciness if i can find a same length stiffer link pin shock, but right now i have higher priorities that spending more $$ chasing a softer ride.
and I'm ok with that.
That's what I wanted when I built, not bought this car.
oh yeah, when you run this low... it's quieter if you cut these guys off...
_________________ david duplessis |
CaffeineJunky Samba Member
Joined: January 05, 2012 Posts: 387 Location: Reno, NV
Posted: Thu Jan 30, 2014 12:54 pm Post subject: |
suicidedoordavid wrote: |
5 inches narrowed custom made with adjusters, no shocks originally, but i modified brackets on the fenderwell to attach link pin shocks. |
I would love to see how you set that up... Do you have pictures? _________________ 1969 VW Bug - 1600 on a 5" narrowed beam |
The Pilch Samba Member
Posted: Sat Feb 08, 2014 12:14 am Post subject: |
1967 Type 1.
Front: 2" narrowed adjustable beam lowered as far down as it will go, 155/60/15's on stock steelies painted white
Rear: Lowered 2 outer splines, 185/60/15 on stock steelies painted white. |
JWP80 Samba Member
Joined: July 11, 2012 Posts: 400 Location: First Capitol, OK
Posted: Mon Feb 10, 2014 6:14 am Post subject: |
Sweet looking '67 one of my favorite years. Those wheels will really pop with some Porsche Nipple caps. _________________ I have a German look bug, it was built in Germany and looks like it.
VW Beetle Top Gear tested to be the best car to cross the African continent....
'74 Super Beetle Autox/Track Car/Street Car build |
Posted: Mon Feb 10, 2014 10:13 pm Post subject: |
JWP80 wrote: |
Sweet looking '67 one of my favorite years. Those wheels will really pop with some Porsche Nipple caps. |
Thanks! Good idea about the Porsche caps. |
SLCmark Samba Member
Joined: October 15, 2011 Posts: 167 Location: Salt Lake City
Posted: Wed Feb 12, 2014 12:34 am Post subject: |
eggman95 wrote: |
Front:
airkewled 4" narrow adjustable beam
2.5" drop spindles
airkewled lowered shocked
Back:
3" drop plates from the.dub.lab
Tires:
Front: 135's portawalls
Back: 165's portawalls
Are you running your drop plates at stock notch placement? _________________ '65 T1
1300 SP
3" Narrowed Adjustable Beam/Griffin's VW Machine Shop |
BeatenBug Samba Member
Posted: Thu Feb 27, 2014 3:49 pm Post subject: |
Are those short axles/tubes? Looks good!
Gmiee5 wrote: |
before :
Lowering specs
Drop spindles
Two spines on the outside on the back
new rims
the back rims are 15x8 tires 195x60x15
the front rims are stock tires 125x65x15
after:
advinnie Samba Member
Joined: November 18, 2011 Posts: 1389 Location: oxfordshire
Posted: Sun Mar 02, 2014 3:29 pm Post subject: |
Here my 1971 beetle
Front
adjustable 2" narrowed beam
2 1/2 dropped spindles
145/15/77T tyres
4 1/2 stock steel wheels
Rear
Adjustable notched rear spring plates
Stock 4 1/2" steel wheels
155/82/15 tyres
61dub Samba Member
Posted: Sun Mar 02, 2014 6:56 pm Post subject: |
I have a 55' Bug with a 6" Narrowed Beam with disc brakes and Raders. I am currently running 165/45 up front, to small of tires for my taste. I want to get a little more tire under me that might help lift it up about 1" without rubbing (I will also raise it up one click in the front to get a little more ground clearance if needed).
With two people in the car I bottom out a lot and mostly hit my front apron on big dips and not my beam. What tire would you suggest, 155/60, 145/65, or 135's. Or is there another tire that will not rub that you might suggest.
eggman95 Samba Member
Joined: October 05, 2004 Posts: 268 Location: Jersey City, NJ
Posted: Mon Mar 03, 2014 8:16 pm Post subject: |
SLCmark wrote: |
Are you running your drop plates at stock notch placement? |
Hi, yes I am. _________________ Henry |
70BeetleType1 Samba Member
Joined: March 04, 2014 Posts: 1 Location: Santa Clarita, Ca
Posted: Tue Mar 04, 2014 11:00 pm Post subject: |
SLCmark wrote: |
eggman95 wrote: |
Front:
2.5" drop spindles
Back:
Tires:
How many inches has your's been lowered in the front and back? It looks really great! Sorry if you've already said; I'm fairly new to this whole thing. Also, do any of you know how low I'd be able to lower my '70 Standard without the back wheels getting flared out? I'm not too big a fan of that look. Thanks! |
Posted: Wed Mar 05, 2014 5:35 am Post subject: |
70BeetleType1 wrote: |
Thanks. The back was lowered 3 inches. _________________ Henry |
xBLAKEx Samba Member
Posted: Thu Mar 06, 2014 7:54 pm Post subject: |
Retoft wrote: |
Front:
Homemade 2 inch narrowed beam, welded in adsjusters
Dropped spindles
145/65/15
Stock rims
Back:
1 click down
165/80/15
Stock rims
Retoft, your bug looks amazing! I know it's not suspension related.. but do you or anyone know what rack that is? I love the whole look of your bug! |
Posted: Thu Mar 06, 2014 8:07 pm Post subject: |
VDUBMOBN wrote: |
Front:
5 1/2" narrowed beam with adjusters.
2 1/2" cb dropped spindles.
Rear:
Notched spring plates.
Lowered 2 splines (outer).
Sealed bearings.
Wheels:
Stock smoothies.
Tires front:
125 15. Spair tires out of cars at the junk yard. Find a matching pair and only $10 a wheel.
Tires rear:
Nankang 185R 15
I dig this style! Where can I get one of those swamp coolers? |
01060731 Samba Member
Joined: November 13, 2009 Posts: 2 Location: Lakeville,Mn
Posted: Fri Mar 07, 2014 8:41 pm Post subject: |
xBLAKEx wrote: |
VDUBMOBN wrote: |
Front:
Rear:
Sealed bearings.
Wheels:
Stock smoothies.
Tires front:
Tires rear:
Nankang 185R 15
Can I ask-where did you get the sealed bearings for the rear. I've been searching for them! |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sun Mar 09, 2014 8:38 am Post subject: |
Back to Basics....
I changed the wheels from Eagle Alloys 5 spokes
Back to stock 1967 wheels..
Same specs.. different wheels..
Now it looks narrowed.... .... and Odd...
1967 Beetle
Stock transaxle (long axles)
Stock 1967 Wheels
Rear: Original unchanged ride height 185/65/15 tires
Front: Lowered front with CIP1 purchased spindles 1/4 offset and torsion adjusters welded in a stock length beam. 1 set of Caster shims and long beam bolts.
Front beam is 3 inches off the ground. 155/60/15 tires
From
To
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
gitchesum Samba Member
Joined: November 10, 2003 Posts: 513 Location: North Cali
Posted: Sun Mar 09, 2014 8:43 am Post subject: |
Never a fan of Eagles....looks good now...did you lose the hibacks too ? _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go... |
dankside Samba Member
Joined: March 19, 2013 Posts: 57 Location: Twin Falls, ID
Posted: Mon Mar 10, 2014 3:20 pm Post subject: |
So I've scrolled through 28 pages on this thread and can't seem to answer my own question so I will throw it out there. Call me whatever you want but I just want to know if I can run 195/65 15 on my 1964 that is stock height and has the stock wheels and is daily driven about 50 miles a day. I at least want to run them in the back. I would like to run them all around but I think they might rub when I turn if I put them up front. So I was thinking the 195/65's in the rear and the 165/80's in the front. I am truly amateur with this so if you want to lace in to me with how dumb of an idea this is feel free. If this is the wrong place to ask this also let me know. |
