vw1965 Samba Member
Joined: January 07, 2008 Posts: 10 Location: Hungary, Kaposvár
Posted: Sat Aug 22, 2015 3:06 pm Post subject: Rubbing tires |
Hi!
Just dropped my bug with drop spindles. Has 155R15 tires. They are rubbing as I make short turns with load. Do you think 145' tires could solve my problem?
Thank you for your help!
Mark |
vwnut1 Samba Member
Posted: Sat Aug 22, 2015 5:42 pm Post subject: |
Yes, 145's are a popular choice for Bugs with dropped spindles, it should eliminate the rubbing. _________________ 1957 VW Oval Resto Mod |
vw1965 Samba Member
Posted: Sun Aug 23, 2015 2:48 am Post subject: |
Thank you! |
Bubbabomb Samba Member
Joined: September 30, 2011 Posts: 1 Location: Oakdale, CA
Posted: Sun Aug 30, 2015 7:49 pm Post subject: |
145's up front with drop spindles and 5inch narrowed beam
165's in the rear. I believe the rear has been lowered by previous owner.
Deejayrob Samba Member
Posted: Tue Sep 01, 2015 4:46 pm Post subject: |
Stock 1964 VW Bug
FRONT:
2" narrowed adjustable beam (all the way down)
2.5" drop spindles
Empi lowered shocks
155/60R15 tire
REAR:
4" oldVdubs drop plates
Monroe air shocks
195/65R15 tire
15" original smoothies with beauty rings
shadeddave Samba Member
Posted: Mon Sep 07, 2015 11:59 pm Post subject: |
muravr Samba Member
Posted: Wed Sep 16, 2015 8:42 am Post subject: |
SkyDawgVW wrote: |
4.5 narrowed beam, drop spindles
175/55 on 6 inch widened on the front
3 inch drop plates, 2 splines I think
205/60 on 7 inch widened on the back |
WOOOWWWW, very aggressive!!! |
muravr Samba Member
Posted: Wed Sep 16, 2015 8:59 am Post subject: |
German widened smoothies on the rear, 15x6" - 165SR15 Michelin XZX
Standard smoothies on the front, 15x4" - 145SR15 Michelin XZX
Og Vw patina hubcaps with black logo (MY '63)
Typ3Kai Samba Member
CHASINGJR Samba Member
Posted: Thu Sep 24, 2015 4:19 am Post subject: |
Front: 6 in. narrowed beam, dropped spindles, no shocks with 155/60/15 on stock smoothie.
Rear: Stock spring plates dropped 2 notches, widened smoothies to 5 1/2" with 195/65/15 and stock shocks.
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Thu Sep 24, 2015 3:40 pm Post subject: |
Stock adjustable beam on this one? No dropped spindles?
muravr wrote: |
ozzyash Samba Member
Posted: Thu Sep 24, 2015 11:42 pm Post subject: |
SkyDawgVW ...Put your stock smoothies back on...much cooler!! |
62ItalianRagtop Samba Member
Posted: Fri Sep 25, 2015 12:39 am Post subject: |
buguy wrote: |
muravr wrote: |
YES
Only stock adjustable beam _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/ |
buguy Samba Member
Posted: Sat Sep 26, 2015 1:44 pm Post subject: |
Perfect! Thanks! Thats exactly what i needed to see and know! |
vwnut1 Samba Member
Posted: Sun Sep 27, 2015 8:14 am Post subject: |
Love your stance 62ItalianRagtop, It's spot on! _________________ 1957 VW Oval Resto Mod |
beakermike Samba Member
Posted: Mon Sep 28, 2015 10:39 pm Post subject: |
Front is stock smoothies with smart car tires, can't remember the size.
3 inch narrowed adj. beam with 2 1/2 inch drop. Lowered a bit on the beam.
Rear is just sitting on bump stops. 7inch widened German smoothies.
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3292 Location: Rapid City, SD
Posted: Wed Sep 30, 2015 11:17 am Post subject: |
'65
Front
4" beam, drop spindles, no shocks
175/55/15 on Cip1 Super speed wheels
Rear
One outer spline down. Soon to put it back to stock and add rear drop plates.
196/65/15, short axles, cheap shocks
turboj74 Samba Member
Joined: November 19, 2014 Posts: 5 Location: Canton ohio
Posted: Wed Sep 30, 2015 7:08 pm Post subject: |
62
Front
4" narrowed beam
2.5" drop spindles
145's stock smoothies & portawalls
Rear
JerFab adj spring plates set at 2"
165's stock smoothies & portawalls
[/img] |
Posted: Wed Sep 30, 2015 7:20 pm Post subject: |
This was a before pic when I first bought her last November.
ozkroid Samba Member
Joined: August 21, 2015 Posts: 11 Location: West Los Angeles
Posted: Fri Oct 02, 2015 8:52 pm Post subject: |
Dropped Spindles front 2.5
Back stock
Stock brazillisn shocks front/back
HD sway bars front/back
15" 8 spokers, front: 185/55/15 rear: 205/60/15
No issues and smoothest ride imaginable
