Pictures of tire, wheel, and suspension thread for FAQ's
Page: Previous  1, 2, 3 ... 97, 98, 99 ... 112, 113, 114  Next
FullFender
FullFender is offline
PostPosted: Thu Dec 03, 2015 6:57 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
advinnie wrote:
Here's some photos of my bug I to have 2 1/2" ground clearence but your bug looks lower than mine? And I have a 2" narrowed beam.
I read somewhere that the beams on later model cars are lower then the body and that the aprons on earlier model bugs are lower then the beam. I don't know how true that is tho. I like the stance of your car.
knightsafe
knightsafe is offline
PostPosted: Sun Dec 06, 2015 5:00 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Front
4" beam w/ shocks
Drop spindles
4" smoothies w/ Firestone 135s
Rear
Down 1 outer click
Notched and extended spring plates
67 trans w/ long axles
6.5" smoothies w/ Firestone 185/65s
Might go down a little bit more in the rear
1967 Type 1 Zenith Blue
1974 Type 181 Patina White
muravr
muravr is offline
PostPosted: Thu Dec 10, 2015 2:15 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Veeeery nice! Cool
advinnie
advinnie is offline
PostPosted: Thu Dec 10, 2015 2:27 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Sweet ride
oxtaco
oxtaco is offline
PostPosted: Tue Dec 22, 2015 12:01 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Front
Bagged
One off A-arm IFS
4" stock smoothies (I did shift the offset out 1")w/ Firestone 125 R15
Rear
Bagged
Stepped and extended spring plates
67 trans w/ Short axles
8" smoothies w/ Firestone 155 R15s
my 1962 build thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=495264
Cont:
http://www.thesamba.com/vw/forum/viewtopic.php?t=519611
FullFender
PostPosted: Wed Dec 23, 2015 12:36 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
oxtaco wrote:
Front
Bagged
One off A-arm IFS
Rear
Bagged
How is the ride? I love the double camber Applause
oxtaco
oxtaco is offline
PostPosted: Wed Dec 23, 2015 6:32 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
@FullFender surprisingly well, i assumed it would take a little rethinking after driving it for a while but she tracks straight and flat. the one thing i will be changing is the rear bags. Currently they are Slam Specialty RE8s and they are a little soft under acceleration so i think i will go with RE6s in the future.
Cont:
FullFender
PostPosted: Wed Dec 23, 2015 11:28 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Do you get any rubbing with those back tires? I love the way the rear tires fill out the wheel well.
c4lvinnn
c4lvinnn is offline
PostPosted: Thu Dec 24, 2015 12:53 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Front:
Airkewld 6" narrowed shockless beam
Airkewld drop spindles
145/65/15 Continentals on stock smoothies
Front fender to ground height: 20.5"
Rear:
Airkewld Adjustable Spring Plates at around 14 degrees
Doestech Shocks
Stock 165/80/15 (soon to be 175/65/15)
Rear fender to ground height 22"
May go lower all the way around if I can pie cut the front pan head. Beam clearance is about .5" right now. Sucks.
oxtaco
oxtaco is offline
PostPosted: Thu Dec 24, 2015 1:19 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
@FullFender not anymore. she used to have long axles and before i raised the transmission it rubbed a little. once i raised the transmission i had to swap back in short axles for tire clearance. Very Happy
Cont:
EVfun
EVfun is offline
PostPosted: Sat Dec 26, 2015 2:53 am    Post subject: Re: tire, wheel and suspension thread Reply with quote
fyrefast wrote:
Front:
145 ww's from diamondback
stock smoothies
3 inch narrowed adjustable beam w/shocks
drop spindles
Rear:
205/70/15 ww's from diamondback
stock smoothies widened to 6 inches
lowered one outer spline
[/img]
What is the paint color for those wheels? I have a black '57 with red interior and the wheels are black outside and white inside. I think that red could make a nice new center color.
Wildthings wrote:
VWMIke82
VWMIke82 is offline
PostPosted: Mon Dec 28, 2015 3:18 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
With all these narrowed beams, how many of you have the tires rub the headlight buckets? I put a 4inch narrowed beam in and even with smart car tires, the tires rubbed the buckets.
1959 VW Bug Sedan
I chopped it up for Baja and then put it back to stock...
1914 cc, 043 heads, 110 cam, weber 40idfs.
Canadian VW
Canadian VW is offline
PostPosted: Wed Dec 30, 2015 10:57 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
-Rims are 17 X 7 ET +40
-Tires are Yokohama S-Drives in 195-40-17
-Airkewld front and rear air ride kit with a Air Lift Auto Pilot V2 controller and dual Viair 380 compressors
-Airkewld 4 inch narrowed beam and Wilwood disk brakes front and rear
-Shortened and pie cut frame head
GeRGelu:
GeRGelu: is offline
PostPosted: Thu Dec 31, 2015 5:52 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
knightsafe wrote:
Front
4" beam w/ shocks
Drop spindles
Rear
Down 1 outer click
Nice ride!
Especially because it's a Pastel Blue too like mine Smile
72 Kombi Camper
61 Deluxe Bug
55 Standard Bug - Sold Sad
Looking for a pre 61 Splitty!
c4lvinnn
c4lvinnn is offline
PostPosted: Sat Jan 02, 2016 2:06 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
i'm not even close to the headlights on mine.
FullFender
PostPosted: Sat Jan 02, 2016 11:23 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
I bought a 4 inch beam and 175 55 smarts and no rubbing.
pezthing
pezthing is offline
PostPosted: Wed Jan 13, 2016 1:02 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
62 bug with....oh who gives a crap Smile
EMPIImp69
EMPIImp69 is offline
PostPosted: Fri Jan 15, 2016 6:41 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
If I go with a 3" or 4" narrowed adjustable stock linkpin beam with drum brakes, what mods if any will need to be done to either the shocktowers or the body? Thanks
1963 Ragtop Bug
Sharp64 Premium Member
Sharp64 is offline
PostPosted: Fri Jan 15, 2016 7:42 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Has anyone tried a 4" narrowed/lowered link pin beam w/ lowered spindles, disk brakes and 185/55 tires in the front? I want whitewalls, but would like something wider than the typical 135's and also disk brakes. Not really interested in trying portawalls either.
Anyone?
VdanielW
VdanielW is offline
PostPosted: Fri Jan 15, 2016 10:56 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
So, I can't say I've tried 185/55's, but I have used 205/40/17" (rims are 40mm offset) on a 4" narrowed, adjustable front end, dropped spindles, and disc brakes with no rubbing issues. I did some quick calculations and best I can figure your tire combo with 15" rims will be 482.75mm (about 19") tall and my 17" are 513.8mm (about 20.2"). As long as you are not pushing out too far you should be ok. This, of course is all calculations with your rims being the variable that I can't account for.
Page 98 of 114
