doc73 Samba Member
Posted: Tue May 10, 2016 7:13 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
4" narrowed beam w/shock towers running stock shocks and 185/65 with a little rubbing. Probably going to a 165 _________________ Speed Leaving Without Warning . . .
66 Bug
66 fastback (sunroof) |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5305 Location: Central Florida
Posted: Tue May 10, 2016 7:19 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
doc73 wrote: |
4" narrowed beam w/shock towers running stock shocks and 185/65 with a little rubbing. Probably going to a 165 |
Very nice. Why not go with a lower profile in the front? 185/55 or 185/60? |
doc73 Samba Member
Posted: Tue May 10, 2016 8:53 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
These tires- 185/65 front & 195/65 rears were off an older rim I was running and before the narrowed beam. I'll be changing to a lower profile but thinking of a disc brake upgrade first. _________________ Speed Leaving Without Warning . . .
66 Bug
kinkerstinker Samba Member
Posted: Tue May 10, 2016 10:10 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Sharp64 wrote: |
kinkerstinker wrote: |
potato_salad1 wrote: |
You're not as low as the others because you don't have it adjusted as low. If you want to rid of the fender gap, then you'll have to sacrifice beam-to-ground clearance. |
Thanks for the reply! I totally get that. I think, maybe, I thought id want to be lower than i really do once the car hit the ground haha. Ive had my share of cars with vital parts an inch or two off the ground, but wanted to keep this a little more drivable.
Maybe someone could help advise me on a tire size thats a little taller. That way it could adjust the beam to where it is now, but it would fill out the fender better. |
Easy enough to figure out on your own. The 145/65 you are running now is 94.25 tall. Which is a really tiny tire. I got this by multiplying 145 x .65 which gives you the height of the tire. 135's are 80 series (ive been told actually 83 but for simplicity...) which would make them 108
(112). A 185/60 would be 111. Figure out what you need to have and start figuring it up. Also, a lot of tire sites such as Coker, DBTires and others will give you heights for the various tires to help you figure out what you need. Keep in mind, if you stay the same adjustment on your beam, by raising the height of your tire, you will in fact raise the height of the car... |
Thanks for the info! I know it would raise the car a little. I'm after more of a filled out fender, rather than a panscraper so that would work perfect.
The picture I posted is right after the beam install too, so maybe the springs will "settle" after it gets driven since they are new and i'll be happier with the front. |
Posted: Tue May 10, 2016 10:22 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
You'll also have the weight of the hood, tank of gas and passengers. |
62RagAZ Samba Member
Joined: August 14, 2011 Posts: 147 Location: Peoria, Arizona
Posted: Tue May 10, 2016 2:12 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
1962 Ragtop
Front:
Tires: 145's
Wheels: 15" x 4.5" Randar Wheels
Beam: 4" narrowed beam
Brakes: Wilwood disks
Air shocks
Rear:
Tires: 165's
Wheels: 15" x 5" Randars
Brakes: Drum
Titan rear air ride kit
Accuair air management system
muravr Samba Member
Posted: Mon May 23, 2016 6:26 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
My old '63 lowered a little bit than before
Posted: Mon May 23, 2016 6:31 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
muravr wrote: |
Very nice. Like the stance. Data? Tires/wheels? Suspension? |
muravr Samba Member
Posted: Mon May 23, 2016 8:28 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Sharp64 wrote: |
muravr wrote: |
Thank's Sharp
The Front
original front axle with CSP adjustable kit, not narrowed
stock spindles with Bilstein rebuilt kit
original smoothies 15x4” with original patina hubcaps - 145SR15 Michelin XZX tyres
Smora® rebuiltable oil shock
The Rear
lowered 1 spline
Widened smoothies 15x6” with original patina hubcaps - 165SR15 Michelin XZX tyres
Smora® rebuiltable oil shock |
CLTVW Samba Member
Joined: March 21, 2016 Posts: 5 Location: Harrisburg, NC
Posted: Tue May 24, 2016 1:13 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
1965 Beetle
4 Inch Narrowed/Adjustable Beam and 2 inch dropped spindles by Autowerks Suspension
Extended and notched springplates by Autowerks Suspension
17 inch Raiders
205/50/17 Cooper (rears) 205/40/17 Coopers (front)
Combination of inner and outer splines for the rear height with KYB Excel G shocks.
Posted: Tue May 24, 2016 2:16 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
CLTVW wrote: |
1965 Beetle
17 inch Raiders
Love that color, well done! |
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1254 Location: Yulee FL
Posted: Thu May 26, 2016 1:58 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
This is how you calculate rolling diameter of a tire:
145/65/15
145 / 25.4 (mm to inches) = 5.70"
5.70" x aspect ratio of 65%= 3.71" (this is your 94.25 measurement below)
3.71" is the height of the sidewall so multiply 3.71" x 2 = 7.42" (total side wall height)
7.42" + 15" wheel diameter = 22.45 " tall tire AKA rolling diameter
Sharp64 wrote: |
spoole Samba Member
Posted: Thu Jun 02, 2016 4:30 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
alan_beetle1958
What wheel are those???? |
vwnut1 Samba Member
Posted: Sat Jun 04, 2016 3:24 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Here is my freshly finished '64;
FRONT: 2.5" drop spindles with 175 tires, stock smoothies
REAR: Kaddy Shack adjustable drop plates with 205 tires, 6" widened smoothies
_________________ 1957 VW Oval Resto Mod |
drumzvw Samba Member
Joined: November 03, 2005 Posts: 81 Location: Quail Valley, CA
Posted: Mon Jun 06, 2016 8:58 pm Post subject: |
cmdog73 wrote: |
145/65/15 up front
5 inch narrowed german beam w/adjusters
2 1/2 spindles
stock smothies
out back
2 clicks
180/65/15
notched plates
This is exactly how I want my 67 to sit! I have the adjustable beam, but it's stock length. Now I know how narrow I need to go to get the front end where i want it without rubbing. THANKS _________________ ( O \ l / O ) |
advinnie Samba Member
Joined: November 18, 2011 Posts: 1389 Location: oxfordshire
Posted: Mon Jun 06, 2016 11:43 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
vwnut1 wrote: |
Sending you a pm mate love your bug looks amazing. Any chance of some more photos? |
vwnut1 Samba Member
Posted: Tue Jun 07, 2016 6:05 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
This might be the dumbest question ever... but here it goes.
Are all disk brake conversion spindles the same?
And how do I tell what kit I have??
I have a '67 that I bought 13 years ago and drove for a few years on and off until other projects came up (like my bus). It has sat for about 7 years and needs to be completely gone through. I want to start getting serious about it but have no clue what replacement parts to get when I install the new front end because I bought the car with the discs already. I'm pretty sure they are not dropped spindles because with my adjustable factory width beam all the way down the tires barely rub.
Planning on going with a 5'' narrowed and drop spindles but would like to keep the front discs without having to drop another $300 on a new disc kit.
Also, it has Porsche rims and i'm not sure how the offset with the brake kit is going to pan out.... I'm starting to feel a little overwhelmed. I've looked around on different topics but none are relevant to my situation.
Any help is appreciated.
Thanks,
Evan
samstheman Samba Member
Joined: August 18, 2015 Posts: 239 Location: whittier
Posted: Tue Jun 07, 2016 6:13 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
2.25 drop in rear 2.25 adjustable air kewld beam adjusters
front 15x145 rear 175x70x15 in rear on 5.5 x 15 vintage ss rims from CIP
stock spindle with disk brakes from AC IND beam is stock width
Posted: Tue Jun 07, 2016 6:18 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Looks awesome! Those rims make it _________________ ( O \ l / O ) |
