attack chicken Samba Member
Posted: Sun Aug 19, 2007 6:26 pm Post subject: caster shim thickness question! |
Any of you guys that have caster shims know around how thick the shims are in in. and how many degrees of caster their worth? I know you can get thicker shims, but I would guess by now there is a "rule of thumb" when it comes to a narrowed beam, ride hieght, and how thick the shim needs to be. I have a 6.5in. narrowed adjustible beam with CB dropped spindles and right now as it sits it has 0 degrees caster.....not too good!
Any help will be greatly appreciated!
Rick. |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Sun Aug 19, 2007 6:40 pm Post subject: |
Thanks drscope, it helps some. I really just want to make my own shims and would rather not stack them if I can help it. I will probably end up making some and then measuring the effect on caster.
Thanks again.
Rick. |
Posted: Sun Aug 19, 2007 6:44 pm Post subject: |
$10 a set. Can you find materials and make them for less then that? or are you just trying to say "I did it myself?"
If I was going to stack them, I'd certainly tack weld them together. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Sun Aug 19, 2007 7:02 pm Post subject: |
drscope wrote: |
If I was going to stack them, I'd certainly tack weld them together. |
Well I have the material already, I am cheap, but I also don't want to have to wait for shipping. I know that is a weak reason but I will probably have time tomorrow at work to make, install, and try the shims. It would be easier if the required thickness was known before hand. I have a MIG welder but no way to weld alum. and that's what the shims look like their made from. I built the beam myself and don't mind a little fab work but it sure isn't so I can go around and say I built everything myself. I may not have a big ole pile of money but my time is worth more than that to me. Ive built enough junk, I don't have to make everything! Work is slow and I will have some free time.
Rick. |
Lee. Samba Animal Controller
Joined: December 22, 2003 Posts: 3079 Location: Denver, CO
Posted: Sun Aug 19, 2007 7:09 pm Post subject: |
Lee. wrote: |
Are those things even worth using? |
They are a "MUST" for folks running a lowered beam, lowered beams equal less and less caster depending on how low you go, and caster is a manditory item. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Sun Aug 19, 2007 7:28 pm Post subject: |
Caster is the inclination angle of the spindle. On a lowered car with the rear lowered too there might not be much need for them. Rake the car with the rear being a little higher and that changes. Personally , I feel the money spent on a set...less than 8 bucks, is worth the money, wait time, etc for a piece that fits perfectly. It is more than just a section of pipe cut to fit the beam. It fits the beam and frame head....perfectly.
If your car is lowered, you will definitely notice a diffrence in the way she drives if you install a set. DEFINITELY. The twitchiness will go away and the car will be much more stable at speeds higher than 30mph.
One set and you can reuse your factory bolts, two sets, and longer bolts must be used. ....and don't forget to use torque specs on the frame head bolts or they WILL strip.
MURZ _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
noblewolf Samba Member
Joined: December 15, 2008 Posts: 29 Location: Singapore, Maldives
Posted: Mon Feb 23, 2009 10:31 am Post subject: |
i want to install a caster shim but i dont know where this actually go and how to install.. nobody here around my vicinity knows how to install this either.. can somebody post a picture or any illustrative instructions maybe..
thanks a lot folks!
noble |
ladybug89 Samba Member
Joined: February 27, 2005 Posts: 581 Location: City of Orange,CA
Posted: Mon Feb 23, 2009 11:29 am Post subject: |
noblewolf wrote: |
thanks a lot folks!
noble |
they go on the lower tube of the beam where the beam touches the frame head.
look at the bottom where the beam touches the frame head (shiney metal)
*not my pics* _________________ 1958 bug - 1958 baja - 1962 vert - 2000 Golf |
1clean63 Samba Member
Posted: Tue Mar 17, 2009 8:20 pm Post subject: |
I used 2 sets on my 54 because one set wasn't good enough on my 63!
So thats 2 shims on each side of the beam.
Here's my 54 pan:
