pewe_kodok Samba Member
Joined: October 15, 2006 Posts: 64 Location: Bandung, West Java, Indonesia
Posted: Tue Aug 21, 2007 11:09 am Post subject: cheating direct starter motor control |
hello all,
I try to tune my 181 by my self.... but I need someone to crank (turn ignition key) engine, to see what trouble the engine has.
as simplicity, can I just cheat direct control starter motor? I crank engine by myself without, begging other people to do so
clip direct control (50 at wiring diagram) and connect it to positive side battery. I think when you turn ignition key, direct control get current by 12v.
It is safe to cheat direct control?
thanks |
uberautowerks Samba Member
Joined: October 17, 2005 Posts: 1600 Location: Longmont Co
Posted: Tue Aug 21, 2007 12:10 pm Post subject: |
Safe enough, just make darn sure the car is in neutral, check it at least twice!!! _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black) |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Tue Aug 21, 2007 1:39 pm Post subject: STARTER SWITCH |
cAN BE DONE BY JUST HOOKING TWO ALLIGATOR CLIPS TO THE STARTER MAIN CONNECTION (13 mm nuT) THE RED WIRE AND THE BLACK WIRE TO THE SOLENOID,
MAKE THOSE TWO TOGETHER WITH THE KEY IN THE ON POSITION TO START. _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Tue Aug 21, 2007 6:30 pm Post subject: |
I do declare, kids these days don't involve their friends nearly as much as they used to. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Thingggg Samba Member
Posted: Tue Aug 21, 2007 6:31 pm Post subject: |
You can also get a cheep two wire tool with a trigger grip on it @ about any parts store. Frees up one hand to do other things. |
prom8n Samba Member
Joined: April 01, 2005 Posts: 60 Location: Pinckney, Michigan
Posted: Wed Aug 22, 2007 6:34 am Post subject: Remote crank switch |
I made one from an old back-up light switch I had laying in the spares box. Connect two wires to this, each about 3-feet long, one with an alligator clip and the other with a female spade terminal. Clip one wire to the positive terminal on the battery, and the other wire goes on the solenoid. Push the button on the switch and the engine cranks.
MAKE SURE IT'S IN NEUTRAL!! |
Posted: Thu Aug 23, 2007 8:38 am Post subject: |
yup check gear first. mandatory period.
then when you plug/ clip +12v be carefull. don't let this clip touch negative earthed body.
today I saw a firework for my own stupidity ( I clip + lead to cut out regulator. and fire it up for 3 or 5 second (( nothing harm and I think regulator is fine
for rule of thumb clip + lead at open space, don't clip at closed space or near negative earthed body.
my regulator is mounted at firewall., and regulator body is negative earthed
doh.. my engine still won't start ((((
Towel Rail wrote: |
I do declare, kids these days don't involve their friends nearly as much as they used to. |
sorry Papa... I don't mean to do it by my self. just simplicity when I work alone. that's all
usually I ask my daddy a favor, such as turn the key etc
poor me, my dad had severe pain at his hand joint this moment.
here We indonesian, call it 'asam urat'. dunno about science term. |
