sam_w Samba Member
Joined: March 07, 2002 Posts: 1479 Location: Petaluma, CA
Posted: Tue Aug 21, 2007 2:06 pm Post subject: replacement shifter |
I am now driving my thingster, but have a problem changing gears with the Scat shifter, any suggestions for a replacement?
I do not have the tips of my fingers on my right hand after the fire, caused by fixing a leaking gas line in my 70 bus. Always disconnect the battery when working with gas lines, then no spark!
BTW do you like my radio enclosure?
_________________ 63 singlecab
73 thingster
74 Thing |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Tue Aug 21, 2007 2:35 pm Post subject: |
I've heard nothing but bad reports on most SCAT shifters. I think the older units were good (don't know the time line). The "reverse" lockout thingy was a pain to pull up to engage reverse.
Check to see if the shift rod bushing(s) are worn out. There's one in the tunnel (remove the shifter, and look back about a couple of inches) as well as one under the rear center seat. Remove the cover plate, and you'll see where the shift rod connects to the transaxle shift point. This coupler gets worn too.
If all this checks out, put a stock shifter back in.
- OR-
If money is no object, buy a BERG shifter. Great units, but pricey. You'd never buy another shifter though. _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
sam_w Samba Member
Posted: Tue Aug 21, 2007 4:07 pm Post subject: |
I want a shifter that does not have the reverse thingy, does a Berg shifter have one?
I looked in the Gene Berg Catalog and the 14" shhifter looks right?
Is that a button you have to push with your thumb to mengage reverse?
Link http://www.geneberg.com/product_info.php?cPath=475_2971&products_id=1174 _________________ 63 singlecab
73 thingster
74 Thing
1961bluebug Samba Member
Joined: November 11, 2002 Posts: 1137 Location: Czech Republic, Europe
Posted: Tue Aug 21, 2007 4:11 pm Post subject: |
yes, berg also has a finger operated reverse lock. If you want a shifter without this feature, I´d choose a stock shifter witch metal quick shift kit and new bushing and coupler.
My Berg, nice, crisp, smooth, acurate:
|82x94|
1961 Deluxe beetle, 1971 type 181, 1968 T2a Baywindow, 1973 Type 147 "Swiss Fridolin"(sold), 1966 Deluxe sedan (sold), 1983 "Silver Bug" edition (sold), 1961 beetle (sold) |
sam_w Samba Member
Posted: Tue Aug 21, 2007 4:19 pm Post subject: |
What is a quick shift kit for a stock shifterr? _________________ 63 singlecab
73 thingster
74 Thing |
Posted: Tue Aug 21, 2007 4:48 pm Post subject: |
My shifter is 12" bent. _________________
|82x94|
uberautowerks Samba Member
Joined: October 17, 2005 Posts: 1600 Location: Longmont Co
Posted: Tue Aug 21, 2007 4:53 pm Post subject: |
sam_w wrote: |
What is a quick shift kit for a stock shifter? |
Basically a plate that moves the shifter base up and the "ball" down, thus increasing the fulcrum length and shortening the throw.
Here is a link to CB performance for a picture.
http://www.cbperformance.com/catalog.asp?ProductID=653 _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black) |
sam_w Samba Member
Posted: Tue Aug 21, 2007 6:44 pm Post subject: |
I guess if I use the quick shift kit, I need a standard gear shift. Is the Thing shifter different from the 73 bug? _________________ 63 singlecab
73 thingster
74 Thing |
kuebelwagen84 Samba Member
Joined: March 15, 2007 Posts: 144 Location: Edison, NJ
Posted: Tue Aug 21, 2007 7:41 pm Post subject: |
sam_w wrote: |
I guess if I use the quick shift kit, I need a standard gear shift. Is the Thing shifter different from the 73 bug? |
nope, the Thing uses the same shifter as the bug
also check out this thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=245039 _________________ // '73 Thing "Jeep Zerstörer" currently being restored / kustomized
// '07 Rabbit taking over daily driver duties
1600s of air-cooled German muscle! |
