npconnor Samba Member
Joined: February 13, 2007 Posts: 194 Location: Central Texas
Posted: Wed Aug 22, 2007 7:12 pm Post subject: Hoses |
Everyone see the RED and GREEN lines in the picture? Good, I am told by a prophet, Ian Epperson as some call him, that two hoses belong there. However, this prophet says I must find out the correct diameter and length on my own. So that is my quest, can anyone tell me the sizes so I can gain all 55 ponies back, stop causing global warming, and quit having to clean my engine from all the oil that sprays all over my engine bay? Thanks!
Edit: You should be able to enlarge the picture if you cannot see the green and red lines drawn by Him. _________________ '73 Thing
Austin Air-coolers Gang |
FreakCitySF Samba Member
Joined: June 08, 2004 Posts: 642 Location: San Francisco
Posted: Wed Aug 22, 2007 9:12 pm Post subject: |
I need to get some of the hoses too.
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Thingggg Samba Member
germansupplyscott Samba Member
Posted: Sat Aug 25, 2007 5:16 am Post subject: |
the air filter thermostat has a piece of red and a piece of green. the red is 4mm ID and the green is 4.5mm ID. the black 3.5mm stuff will work in a pinch but it doesn't fit very well. i'm not sure what they used on the air cleaner in the thingshop photo, but to be correct the t-stat uses the green and red hose.
http://www.germansupply.com/home/customer/product.php?productid=17125
we have the green one too but i can't find it on our site for some reason _________________ SL |
