Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Thu Aug 23, 2007 6:38 pm Post subject: Heat riser tin |
I just bought these for my engine since they were missing:
You would think you could just put them in place and tighten the bolts... NOT! There's not enough clearance behind the heat riser for them to fit into place. Which engine tin needs to be removed for them to fit? I'm guessing this isn't easy, which is the reason they are missing from so many engines? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Thu Aug 23, 2007 6:41 pm Post subject: |
They should fit, you just have to work them from the outside in. _________________ Glenn
Member #1009
#BlueSquare |
FreakCitySF Samba Member
Joined: June 08, 2004 Posts: 642 Location: San Francisco
Posted: Thu Aug 23, 2007 6:55 pm Post subject: |
Whered you buy those?
Those look sooo new and clean almost a computer CAD drawing. |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Thu Aug 23, 2007 7:02 pm Post subject: |
Keep in mine that the stock heat riser tubes on the manifold are larger than a beetle. The hole may need to be cut larger. |
ztnoo Samba Member
Posted: Thu Aug 23, 2007 7:08 pm Post subject: |
Lest anyone forgets those obsure asbestos gaskets......
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113119597 _________________ "Here we don't have a single clock in the shop- time doesn't matter." ----Jake Raby
"The government cannot give to anyone anything that it does not first take from someone else."
When you put the 2 words "The" and "IRS" together it spells "Theirs"
* Don't worry about the world coming to an end today. It's already tomorrow in Australia !
Posted: Thu Aug 23, 2007 7:32 pm Post subject: |
I bought them on eBay from this guy:
http://motors.search.ebay.com/_W0QQfgtpZ1QQfrppZ50QQsassZbugcity
I won them both for $10.50 and $6.00 shipping! Unfortunately, they didn't come with the insulation that fits into the opposing tin...
I'll try to fit them in this weekend. I suppose these parts are a little smarter than me right now... |
Glenn Mr. 010
Posted: Thu Aug 23, 2007 7:36 pm Post subject: |
Ron Domeck wrote: |
I just checked the micro fiche and both a 74 Type 181 and a 74 Beetle use the same part. They have the same part number 211 119 577/578 _________________ Glenn
Member #1009
#BlueSquare |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Thu Aug 23, 2007 8:32 pm Post subject: |
From that part #, it might have been a Bus part first! _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
germansupplyscott Samba Member
Posted: Sat Aug 25, 2007 5:11 am Post subject: |
Glenn wrote: |
Ron Domeck wrote: |
I just checked the micro fiche and both a 74 Type 181 and a 74 Beetle use the same part. They have the same part number 211 119 577/578 |
yes all true. there are different diameters of heat riser pipes, the thing ones being the larger size. it is quite possible to have a set of these that look right in a photo but do not fit a thing engine. _________________ SL |
kubelmann Samba Member
Posted: Fri Nov 09, 2007 3:36 pm Post subject: |
A bunch of the various engine tin parts on a Thing came from a (68 -71) Bus like the tin that goes under the pus rod tubes |
