Rene v Samba Member
Posted: Thu Aug 30, 2007 5:07 pm Post subject: Horse power in dune buggy |
Hi All
I'am wondering what size of engine everyone has in their buggies? I was thinking of a 1915 cc or is that too much HP for a buggy?
Thanks Rene |
seabeebuggy Samba Member
Joined: October 03, 2005 Posts: 2395 Location: NM, CA, UT and now NV
Posted: Thu Aug 30, 2007 5:33 pm Post subject: |
I am in the 230hp range. on my buggy. I still like more power. some day I will go to a 2332 turbo EFI _________________ Seabee turbo buggy build
(Quote Runslikeapenguin said)
so to everyone else whos not a retarded butt pirate marine with an tacky ugly ass car covered in auto zone bolt and stick on s**t. (end quote)
A better place to talk offroad |
darkdune Samba Member
a 1915 will only produce 100HP max.. thats not too much
im buying a 2275 this winter for mine _________________ 60 percent of the time it works every time. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Thu Aug 30, 2007 6:52 pm Post subject: |
100-120 HP is a lot for a 1300 lb fiberglass dunebugy. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Thu Aug 30, 2007 7:45 pm Post subject: |
indeed it is _________________ 60 percent of the time it works every time. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Thu Aug 30, 2007 7:51 pm Post subject: |
Depends on what you want? Sports car ...build a nice 1776 or 1915. Drag racer?? build a stroker.
Again even a 1600 with dual 40 webers will be great fun in a buggy. the weight thing does it.
Play with this and you will see what I mean. Assume 1300 pounds for the car.
http://www.wallaceracing.com/Calculators.htm
example 1300 lb car with 200 lb driver with 85hp===15.16@88mph
example 1300 lb car with 200 lb driver with 100 hp==14.36@92mph
example 1300 lb car with 200 lb driver with 125hp===13.33@100mph _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Fri Aug 31, 2007 6:22 am Post subject: |
My 2332 is very streetable just don't over carb/cam a dual 44 weber and a 120 cam works for me, great torque,good idle,and 8;803@ 74mph in the 1/8 mile Madmike |
Endoboy Samba Member
Joined: May 19, 2005 Posts: 502 Location: Allentown, PA
Posted: Fri Aug 31, 2007 7:02 am Post subject: |
Yeah, it really does depend on what you want. Mine is a 1600 with an Engle 100 cam, dual Weber 34s, and it goes plenty fast enough for me, even though it's probably closer to 70-75hp. Then again, I'm well past the uncontrollable urge to race every other fast car off the line.
It's also nice that I get over 30mpg on the highway. I really just wanted an engine that would last as long as possible and get good mileage. _________________ 1970 Autodynamics Deserter Series One (gone)
"Americans can always be counted on to do the right thing...after they have exhausted all other possibilities." --- Winston Churchill |
Zcarnut Samba Member
Joined: July 16, 2006 Posts: 409 Location: West Palm Beach FL
Posted: Fri Aug 31, 2007 9:49 am Post subject: |
Im running a 1600DP thats basically stock other than exhaust and ignition upgrades.
Has good power for what it is IMO.Keeps up with traffic,does 70+ MPH without having to floor it....etc
More ponies will come later! _________________ I do drive a Honda.
When im mowing my yard |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Fri Aug 31, 2007 8:03 pm Post subject: |
darkdune wrote: |
im buying a 2275 this winter for mine |
Are you 100% sure of this statment? _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
sturgeongeneral Samba Member
Joined: June 23, 2005 Posts: 2460 Location: Sacramento, California
Posted: Fri Aug 31, 2007 8:25 pm Post subject: Re: Horse power in dune buggy |
[quote="Rene v"]Hi All
I don't understand??? What is too much??? I am running just under 200 hp and will upgrade to a turbo soon. I should end up around 340 or so adding the turbo to the 2375. It is always better to have hp in the bank for when you need it, than to try and pull it out of thin air when you need it most to save your butt! Ask yourself what you want it to do? I know 200-300 hp is overkill for most people, but if you have a need to get radical, having the power to do what you want is necessary when you need it most. _________________ Street legal fiberglass rocket ship
2005 Lotus Elise supercharged
1974 Chevy Corvette
My fiberglass car collection!
In honor of bowtie56jw:Another victim of the nasty "C" Praying for ya Jeff!
My exwife said if I towed home one more bug she would leave me. You know, every once in a while I miss her |
Posted: Fri Aug 31, 2007 8:55 pm Post subject: |
basic 1915 yes _________________ 60 percent of the time it works every time. |
MURZI Samba Member
Posted: Sat Sep 01, 2007 8:12 am Post subject: |
The engine I had was a 2276, with 120 cam, 40x35 heads and 44webers. Probably a 130-140hp engine, that idled like a stock one, would catch rubber in all gears, and run smooth down the interstate. Reliable. Plenty power and affordable.
A big engine with a small cam in a light buggy will give you miles of smiles and last forever...in my HUMBLE opinion.
Kinda like a big block in a street car.....sure there are more powerful small blocks, but the power never comes on down low like a big block. On the street, torque is where it is at. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sat Sep 01, 2007 2:43 pm Post subject: |
is there ever too much HP? If it scares you, get your foot out of it. I have a mild 1776/dual kads, thunderbird quiet exhaust. Tuned pretty well - guessing 70ish HP. Its nice and fun to drive - has plenty of zip. Would I like another 20 HP or so? Hell yeah! But that next 20 ha$ a $ub$tantial expen$e. LOL _________________ D-Dubya Manx clone - 63 Short pan,1914.
mr_bill Samba Member
Joined: February 19, 2006 Posts: 1008 Location: City of Orange, CA
Posted: Sun Sep 02, 2007 11:06 am Post subject: |
Single Port 1500cc VW crate motor (vintage 1967) Still in the car, never been apart!!! _________________ see ya' on the trail........
"Mr Bill"
Dos Perros Motorsports
Orange, CA
1972 Class 11x/Stock Bug
'60's era "vintage" Tunnell-Buggy
"...no one here....get's out ALIVE...."
Motor = electric
Engine = internal combustion
www.facebook.com/groups/DosPerrosMotorsports
www.alrchapter132.org
www.DAV.org |
EZGZ Samba Member
Joined: October 10, 2005 Posts: 923 Location: Loveland, Colorado
Posted: Mon Sep 03, 2007 7:23 am Post subject: |
2110 with usual tricks.
It's way overkill. I think a mild 69X94 would work just fine. _________________ 64 custom Ghia, 66 Bug, Sandrail, Barrien tub |
Corwin Samba Member
Posted: Mon Sep 03, 2007 6:09 pm Post subject: |
darkdune wrote: |
Uhhhh...I've got a 1915 that puts out 130hp all day long... |
Oz Towdster Samba Member
Joined: November 08, 2004 Posts: 133 Location: Brisbane QLD Australia
Posted: Mon Sep 03, 2007 6:19 pm Post subject: |
Allright i might of got a little carried away with the idea of putting a 2387 in my Towd but it'll be fun |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Mon Sep 03, 2007 6:59 pm Post subject: |
My wife's buggy is getting my old 1914 (69X94) turbo motor. Should be good for a few smiles when I'm done changing a few things.
My buddy Larry's buggy is getting a 2.0 Type IV turbo motor. We'll likely punch it out a little bigger but that depends on his budget. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
JiI Samba Member
Joined: February 18, 2006 Posts: 1845 Location: Michigan
Posted: Mon Sep 03, 2007 9:24 pm Post subject: |
I'm putting a EJ25 Subaru in my Cody Coyote. It should be running around 190HP through a Porsche 915 5-speed tranny in a 1500LB car. FUN!
JiI |
