BrockGrimes Samba Member
Joined: September 18, 2006 Posts: 1015 Location: Clovis, NM
Posted: Wed May 07, 2008 7:14 pm Post subject: |
Weird it must have some meaning.
Other wise why stamp the big D on it, LOL.
I can see it now:
Boss - "My nephew needs a job."
Foreman - "We don't have any open positions"
Boss - "Make a job!"
Foreman - "OK"
Later that day:
Nephew - "What does the D stand for?"
Foreman - "We lost the B punch so we are using the D to mark which side of the pulley goes toward the rear of the car. Get back to work...." _________________ Selling the SB:
http://www.thesamba.com/vw/classifieds/detail.php?id=557335 |
Fattie I'd roll it
Joined: November 27, 2005 Posts: 5582 Location: louisiana
Posted: Sun May 11, 2008 3:30 pm Post subject: |
my buddies pully just has two V's cut out on the back "engine" side of the pully and no other marks... any idea on which is TDC/BTDC ? We can't figure it out and we need to set his timing so he can get my super he bought from me rollin' the streets again with his engine and this is the last thing needed doing.... He has a 009 dist which I know how to set at full adv. 3500+rpm 28*-32*BTDC but ????? which mark to go by is unknown and I looked the pully over hard and can't find any other marking of any kind _________________ Donate and help me get another aircooled dub to share with you guys www.paypal.me/WhosCare |
glutamodo The Android
Joined: July 13, 2004 Posts: 26311 Location: Douglas, WY
Posted: Sun May 11, 2008 10:23 pm Post subject: |
How close are those two V's together? Just a couple of millimeters? If so they are probably 7.5 and 10BTDC. |
itfitz98 Samba Member
Joined: September 25, 2006 Posts: 487 Location: Backwoods of north west Georgia
Posted: Sat Jun 07, 2008 10:31 am Post subject: |
ok, well this was very helpful. I am having some valve adjustment issues and had some confusio of where TDC was. So now I know. the only question is if the rotor should point exactly to the mark on the dizzy AND the notch be lined up with the center of the case. And if they dont, what to do about it. _________________ If it was easy anyone could do it!
73 super in honor of my father. Well on her way to pretty. |
Posted: Sat Jun 07, 2008 11:54 pm Post subject: |
For valve adjustment, it doesn't have to be exactly 100% TDC, it can be a few degrees off on either side and still adjust OK. |
( o\_/o ) Samba Member
Joined: February 03, 2008 Posts: 177 Location: San Antonio, Texas
Posted: Wed Jun 11, 2008 11:22 am Post subject: |
im glad i saw this.... timeing was way off with my static timer finally found my timing gun and it drives so much nice , and i can finally get on the gas without worrying about the advace screwing up.
thanks a lot guys |
gvmmr2 Samba Member
Posted: Wed Jun 25, 2008 5:44 pm Post subject: i cant start my 73 beetle |
hey i just rebuilt the engine on my 73 beetle, but now that i have every thing back i cant start. but im not sure if i put the spark plugs back right. i have spark and fuel but does not start. any help |
roadster49 Samba Member
Posted: Tue Jul 01, 2008 8:14 pm Post subject: |
Make sure you have your spark plug wires in the firing order and the notch on the distributor as number 1. |
benchracer1 Samba Member
Joined: September 24, 2006 Posts: 583 Location: ramona
Posted: Mon Jul 21, 2008 9:43 pm Post subject: |
got a 74 standard beetle with 1 v on the pulley. any ideas? |
Posted: Tue Jul 22, 2008 9:12 am Post subject: |
Is there a dimple on there too, the rounded thingy on the outer section? It should, if it's a pulley made in the early 70s that is. Just compare the dimple to the 7.5 before and 5 after, it's very likely one or the other of those two choices. |
rriconoscuito Samba Member
Posted: Sun Jul 27, 2008 4:47 pm Post subject: |
mine has the one v knotch on the front part of the pulley and thats it is that tdc or is there something im not seeing and i dont have a mark on the motor that i can see or i dont know were it is _________________ 72 Super
1679cc engle 110 dual weber 34 ict : vw: |
slickrock Samba Member
Posted: Mon Aug 18, 2008 11:48 am Post subject: |
benchracer1 wrote: |
did you ever figure out if the single notch was 5 or 7.5? I have a 74 also and a single notch on the pulley.
I would guess the nothc stands for 5 ATDC and I should set that in the center of the split ccase when timing? |
66 Shorty Samba Member
Joined: May 10, 2007 Posts: 916 Location: Rhode Island
Posted: Fri Oct 03, 2008 11:39 am Post subject: |
I'm not sure what the single mark means either... I have a '74 Standard Beetle that has only one mark as well. If no one else answers this, I should be getting a degree pulley soon, & I can match up where the mark is to the degree pulley. Don't hold your breath though, I'm not sure when my Buddy's bringing the Dizzy & Pulley to me. He's over 100 miles away! With gas prices the way they are, I don't see him coming untill he's ready to make the journey... |
Sakajama Samba Member
Joined: August 07, 2008 Posts: 9 Location: Sakajamalandia
Posted: Fri Oct 03, 2008 11:57 am Post subject: |
Thanks guys for the information about distribuitor advance and regulation of valves, are very utility, for me, hellos |
clonezero Samba Member
Joined: June 30, 2007 Posts: 57 Location: Saskatchewan, Canada
Posted: Sun Oct 05, 2008 5:04 pm Post subject: |
66 Shorty, my pulley had the 1 mark as well. I pulled it off and matched it to the paper template that is posted here earlier. It ended up being 5 ATDC. |
Posted: Wed Oct 08, 2008 8:06 am Post subject: |
Thanks man! |
DMC-12 Samba Member
Joined: September 19, 2006 Posts: 817 Location: Maryland
Posted: Tue Oct 14, 2008 9:11 am Post subject: |
I hate to keep beating this dead horse but I've put the seeds of doubt into my own head.
I totally understand the difference between the "dimple" and the "v" on the pulley. My only question is, where should the "V" be when looking at it with a strobe timing light. Does anyone have any pics of the "v" in the proper positions?
I mean, if the dimple is TDC, and I'm supposed to be 7.5 BTDC, then the dimple AND the "V" should be to the right of the split in the case, correct? Also, when checking your advance, how far to the left of the split should the "V" go?
Glenn's initial pic shows the dimple on the split which to me, means 0 degrees. And the wheels on the bus go round and round, round and round... _________________ "Unpimp ze auto"
1974 Orange Thing Daily driver/Rolling resto.
1981 DeLorean DMC-12 |
mnussbau Samba Member
Joined: August 26, 2006 Posts: 4589 Location: Central Maryland
Posted: Tue Oct 14, 2008 5:02 pm Post subject: |
The v would be to the right of the dimple. When you time it statically (engine off), the light would come on when #1 cylinder is about to fire, so the v notch is lined up with the case centerline.
If you use a strobe timing light here's what you do depending on what kind of timing light you have. I'm assuming your distributor requires 7.5 deg BTDC advance.
- With a standard light, at idle, the v notch would line up with the case centerline. A better way to set timing is at max advance. Paint a white line 30 deg to the right of the dimple, then get the rpms up to 3500. Adjust the distributor so the white line lines up with the case centerline. This diagram can help you with the 30 deg mark.
- If you have an advance timing light (where you can dial in the advance right on the light), paint the white line at the dimple (0 deg), and set the light to 30 deg. Then spin the engine to 3500 and line up the white line with the case centerline.
edit: I'm assuming you time your distributor to 30 BTDC at 3500 rpm, typically with vacuum hoses disconnected and plugged, but confirm your setup first. _________________ Mike
Sold my sedan
Parts... |
DMC-12 Samba Member
Posted: Wed Oct 15, 2008 6:56 am Post subject: |
Dang....the "v" should be seen on the case split??? That's my problem all along! I thought the "v" would be to the right of the case split. No friggin' wonder.
I have the variable advance timing light so I can also check the max advance timing. _________________ "Unpimp ze auto"
Whit 72 Samba Member
Joined: June 25, 2008 Posts: 118 Location: San Francisco, Ca
Posted: Sat Oct 25, 2008 8:40 pm Post subject: |
mnussbau wrote: |
Thanks!!!! i just got an advance timing light with a digital readout, RPMS and advance and had no IDEA how it worked.. (haven't tried yet but now i have a guide.. )
