Celthing Samba Member
Posted: Tue Sep 11, 2007 2:50 pm Post subject: install seat belt with shoulder harness? |
I'm finally through my wiring woes (are we ever really through?), and am looking to license this Thing. I want to install seat belts with the shoulder harness (is that called a 3-point?). Will the shoulder harness just bolt in between the front and rear doors, or will have to make special modifications?
As always, any help is most appreciated! |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Tue Sep 11, 2007 4:56 pm Post subject: |
That door post is pretty low. I had to bolt mine to the roll bar. |
kubelmann Samba Member
Posted: Tue Sep 11, 2007 5:30 pm Post subject: |
Yes.. I like to drill a hole in the roll cage. GEt a third point female from a bug adn weld it inside the cage pipe then use the factory bolt and washer set-up and it is safe and clean. |
markie61 Samba Member
Joined: April 11, 2005 Posts: 583 Location: Northern Virginia
Posted: Tue Sep 11, 2007 5:32 pm Post subject: |
Are you in Europe? I have seen pictures of Trekkers with a center door post extension which provides a higher point to attach a shoulder belt. Maybe it was a factory/dealer accessory?
Mark _________________ Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!? |
Space Ghost Samba Member
Joined: November 29, 2005 Posts: 37 Location: London, England, UK
Posted: Wed Sep 12, 2007 8:17 am Post subject: |
markie61, the door post extension that you are talking about was a factory installed thing for all RHD 181's ... i.e. all 182's. |
Pierre G Samba Member
Joined: April 28, 2007 Posts: 1771 Location: New Caledonia
Posted: Thu Sep 13, 2007 12:44 am Post subject: |
The door post extension did exist for LHD 181's too. I had a 1977 military thing in France with those and I could put some 3 points seat belts. _________________ 1976 181/Thing, 1967 fastback, 1973 squareback, 1964 microbus, 1967 Double Cab, 1969 westfalia (currently under resto), 1972 LM1C dune buggy, 1974 jean's bug, 1974 1303 (super beetle, currently under reassembly after new paint). |
