Ted in Tallahassee Samba Member
Posted: Fri Sep 21, 2007 4:58 pm Post subject: My new drums from cip.1 are 13mm! Craaaaap . . . . |
Here I was thinking that at least the 181- numbered rear drum from Germany was going to have 14mm holes. (Don't stock Thing drums all take 14mm bolts?) Well, the new rear drum I just got from cip.1 have 13mm holes, and so do the fronts, which I guess I should have expected since they're same as Beetle (or Ghia?)?
Here's my question--can I simply buy a complete set of 13mm bolts? (Which I suppose are Beetle or bus bolts?) Will they still fit my stock Thing wheels?
I ASSUME the Thing was originally designed with robust 14mm bolts for heavier-than-Beetle use, and now, I'll have to wimp it down . . .
Chime in fellow Thingers. Am I OK with just getting a set of 13mm bolts?
Thanks,
Ted in Tallahassee |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Fri Sep 21, 2007 5:35 pm Post subject: |
Sorry, Thing had 12mm holes just like 5 lug Beetle. 14mm were for 4 lug cars. |
Posted: Fri Sep 21, 2007 7:16 pm Post subject: |
Yikes--it is entirely possible that I am totally cornfused.
I didn't actually measure a bolt I took off my Thing, but one of my "spares."
Hopefully maybe I have wrong sized spares? |
74 Thing Samba Member
Posted: Sat Sep 22, 2007 9:16 am Post subject: |
it is 12 x 1.5 |
kubelmann Samba Member
Posted: Sat Sep 22, 2007 8:29 pm Post subject: |
Bolts suck~~~~~~ wheel studs rock. INHO it is the 21st century, why use 19th century ideas..... replace all wheel bolt holes with studs. |
c.davis419 Samba Member
Posted: Sun Sep 23, 2007 9:17 pm Post subject: |
ditto on kubelwagen! Studs also make wheel changes easier... _________________ 1967 beetle
1974 Thing |
