fuse amp and fuse block
pewe_kodok
pewe_kodok is offline
PostPosted: Tue Sep 25, 2007 8:32 am    Post subject: fuse amp and fuse block Reply with quote
what is the amp rate for fuse installed?
I see 16A installed there in my 181. even 25A there
but manual say 8A
which one is correct?
one more question, how do you attach + wire from instrument signal, gas relay to #2 terminal at fuse block?
my fuse block only had 1 terminal there at #2 and #1 go to ignition coil.
best regards
Ruben
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Wed Sep 26, 2007 9:23 pm    Post subject: Reply with quote
What year was this again? I think the only fuse not an 8-amp is fuse number 9 which is 16, at least in like 1974. Blue (25A) fuses should not be used anywhere.
pewe_kodok
PostPosted: Tue Oct 02, 2007 11:31 pm    Post subject: Reply with quote
hard to tell the year this vehicle
chassis number begin with 261 (believe me!!!)
26 is type 2, and use 1 as year71
so I take this year to refer wiring diagram :p
