Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Thu Oct 04, 2007 7:38 pm Post subject: |
The rear stops are Thing only and I think K-mann might have some used ones. |
npconnor Samba Member
Joined: February 13, 2007 Posts: 194 Location: Central Texas
Posted: Fri Oct 05, 2007 1:51 pm Post subject: |
OK, one more time: the red ones I can either plug up or put hoses on... Since I don't use them... what should I plug them up with?
The oil filler/ breather tube/hose is blue correct? I think I got that from cip1...
The yellow that I drew is something that I need.... can anyone point me in the right direction on this one?
If any of you guys know the real names to these dumb hoses I'd appreciate it. Or links from cip1, or German Motor Works would be nice... then I'll get out of ya'lls hair! _________________ '73 Thing
Austin Air-coolers Gang |
bciesq Samba Member
Joined: April 13, 2005 Posts: 495 Location: Orlando, FL
Posted: Fri Oct 05, 2007 2:11 pm Post subject: |
npconnor wrote: |
If any of you guys know the real names to these dumb hoses I'd appreciate it. Or links from cip1, or German Motor Works would be nice... then I'll get out of ya'lls hair! |
I think the names are:
Red: Fresh Air Hoses
Yellow: Pre-heat hose
Blue: Breather hose
To plug the (red) fresh air ports on the fan shroud, you can get freeze plugs from a hardware store, or these:
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D5439
On the engine tin, you can use pop rivets and the top off of a coffee can to cover the holes.
For the yellow Pre-heat hose, you can use the same hoses that you would use for the fresh air:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D028%2D129%2D087%2DF
If you don't have the pre-heat elbow under the engine tin, you'll need that as well:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D113%2D119%2D519%2DG _________________ '73 Thing -- making 45 mph exciting again. |
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
