jex_the_bug Samba Member
Posted: Sat Oct 20, 2007 11:51 am Post subject: heater help needed |
hi
im trying to get my heater runing well in my 181. but the fuel pump is playing up i think.
it makes a tapping noice that i think should not be so loud.
and the heater when starting up misses lots till the fan realy cuts in then it runs ok but not great. it does not sound smooth like i think it should.
is it just that i need to adjust the amount of fuel its pumping?
the heater is the standard eberspacher BN4.
thanks luke |
howiesfamily Samba Member
Joined: March 31, 2004 Posts: 858 Location: Panther City, Texas
Posted: Sat Oct 20, 2007 1:52 pm Post subject: |
the amount of fuel is regulated by the fan. The fuel solenoid opens once for every so many revolutions of the fan. That might be why it doesn't work well until the fan gets going good. _________________ member of: Fort Worth Aircoolers Gang |
Posted: Sat Oct 20, 2007 2:11 pm Post subject: |
i thought you could adjust the amout of fuel the pump puts out by turning somthing on the pump. |
Posted: Sat Oct 20, 2007 2:36 pm Post subject: |
I think VW used 2 different types of pumps. The one I have is basically a solenoid type valve that doesn't exactly pump the fuel but opens to allow fuel to pass. I don't think there is any type of adjustment on that one. There was a thread here a few days ago that posted a link to the heater repair manual that describes both types. _________________ member of: Fort Worth Aircoolers Gang |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Sat Oct 20, 2007 11:29 pm Post subject: |
Ian Epperson wrote: |
This page may help
http://veewiki.com/HeaterBN4
Manual here:
http://failsure.net/oacdp/ebersp.html
The solenoid pump is an actual pump, not a valve. Each tick is it pulling the plunger inward to squirt the gas. If you pull it from the car, feed it some gas and give it 12v, you'll get a squirt of gas shoot (yes SHOOT) out of it. |
That's true. Both styles have pumps that are just that, pumps; not gravity fed fuel lines. Early BN4's have a pressure regular that regulates the fuel going into the heater and the later pumps every 33 revolutions of the fan.
So you should hear a tick, tick, tick sound with a later style heater. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Sun Oct 21, 2007 2:42 am Post subject: |
i guess that iv got the later style as theres a tick and no regulater. iv got it to run better now but stops firing every now and then.... only for 3 sec or so and every thing else keeps runing. it runs like this all the time.
its as if theres not enough fuel geting through. i will check out the links your give my thanks luke. |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Sun Oct 21, 2007 4:56 pm Post subject: |
jex_the_bug wrote: |
The left most knob, right next to the driver's door, controls the thermostat. If the furnace is kicking on and off strangely, it could be that the thermostat needs adjusting. Just for fun, here's the owner's manual page pertaining to the heater.
suntour Samba Member
Joined: November 25, 2004 Posts: 443 Location: Woodinville, WA
Posted: Sun Oct 21, 2007 7:55 pm Post subject: |
To a certain extent it is suppose to turn on and off. Once the heater reaches the desired air temperature it shuts off the fuel supply and just blows warm air. Once the air temperature has dropped below the desired temperature it kicks the fuel back on and heats the combustion chamber back up. Just like your furnace at home.
If it just kept feeding itself fuel it would get to hot and melt or some other catastrophic break down. Basically what you’re describing is a safety feature. _________________ Order of the Voodoo Spoon |
