kevinlyndsy Samba Member
Joined: October 22, 2007 Posts: 20 Location: Sacramento
Posted: Wed Oct 24, 2007 2:21 pm Post subject: Water Tank Key And Oil Filter |
Anyone know where to get a new water tank key I could not find it on the lots o links, also where do you get those replacement oil filters I have allways just used fram but here you guys talking about some other brand filter with a check valve in it.
Thanks
85 westy |
meinvw Samba Member
Joined: October 24, 2003 Posts: 835 Location: Georgia
Posted: Wed Oct 24, 2007 2:22 pm Post subject: |
If you fnd a key let me know where as well!
I order my filters from bus depot, Mahle's. _________________ The memories of a man in his old age, are the deeds of a man in his prime.
Quando Omni Flunkus Moritati !
73 High roof, 91 Carat, 87 Weekender, Mr magoo buggy, 88 LT 28, 98 R32,81 Diesel double door, 73 tin top, 72 HR. |
Posted: Wed Oct 24, 2007 2:27 pm Post subject: thanks man |
I think I will try a locksmith for the key thing I hate to bust it. I will check out bus depot for filters thansk again |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6246 Location: Portland OR
Posted: Wed Oct 24, 2007 2:56 pm Post subject: |
You should be able to get filters at a good german garage or parts house. I know they have them in Sac. Call around and ask for Mann or Mahle filters. |
r39o Samba Polizei
Posted: Wed Oct 24, 2007 3:11 pm Post subject: |
RE: Water tank key
Oh heavy sigh. "Use the search, Luke." This sure has been discussed before. Please look at the Best Threads sticky. I know there is a thread about it.
Ditto the oil filters.....
[Preach mode = ON]
It conserves time, effort, bandwidth, etc to search before asking......
[Preach mode = OFF] _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
hiram6 Samba Member
Joined: September 29, 2006 Posts: 1880 Location: Beautiful South
Posted: Wed Oct 24, 2007 3:29 pm Post subject: |
1) Go up to the sticky that is titled links to the best threads.
2) Scroll down until you find the one titled: Water Tank Key
3) There ya' go. _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning. |
Rhinoculips Samba Member
Joined: August 08, 2005 Posts: 918 Location: Keystone, Colorado
Posted: Wed Oct 24, 2007 5:21 pm Post subject: |
When did the fresh water tank key go from an actual cylinder lock and metal key to a plastic setup? 1986?
As I believe that all the plastic keyed tank locks are the same, I have two extra keys if anyone is hard up for one. Just PM me. _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Wed Oct 24, 2007 5:33 pm Post subject: |
Rhinoculips wrote: |
As I believe that all the plastic keyed tank locks are the same, I have two extra keys if anyone is hard up for one. Just PM me. |
The key became plastic when a previous owner replaced it with a water lock setup from GoWesty! This is the setup that is now available. Original was a lock and metal key setup.
I went to a locksmith as the sticky pointed out, but my local locksmith could not match it. I got lucky and bought one off of the classifieds here with it's key. _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
Posted: Wed Oct 24, 2007 5:50 pm Post subject: |
bucko wrote: |
I went to a locksmith as the sticky pointed out, but my local locksmith could not match it. I got lucky and bought one off of the classifieds here with it's key. |
Hmmmm....
Strange, very strange indeed. I'm pretty sure that this was never changed from stock, unless is was a dealer option of some sort and added before we purchased it. The vehicle has been in my family since new and I've owned it for most of its life.
Though, I have been wrong before. _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Wed Oct 24, 2007 6:07 pm Post subject: |
bucko wrote: |
I think I'll bet you a doughnut on this one Bucko. My 87 had the plastic key setup and I am pretty sure it had nothing to do with GW. I don't know when they switched, or maybe it's a Canadian thing but at some point the plastic key setup became stock. _________________ -- 1987 Westfalia automatic (Captain Vino) |
msinabottle Samba Member
Posted: Wed Oct 24, 2007 6:15 pm Post subject: Locksmith's... |
Mine's metal and has the tumblers--and my local locksmith wasn't SURE he could duplicate the key, but he tried, and... it worked! So it's not a completely unfathomable lock.
Posted: Thu Oct 25, 2007 9:26 am Post subject: |
Rhinoculips - Can you post a close up picture of the key? I've never had one but would like to see if I could make one somehow.
My 89 is still stock and is a plastic set up. So was my 88.
Thanks!
bucko Samba Member
Posted: Thu Oct 25, 2007 10:08 am Post subject: |
I stand corrected. I had ordered a water fill hookup from GoWesty, and recieved the plastic key setup. The original I had was of the metal key and tumbler lock setup. I assumed that the GoWesty replacement was just that; a replacement for the original metal key/tumbler setup. I then found a water fill hookup with metal key and lock tumbler here on the Samba classifieds and bought it. It looks to be a better made setup then the plastic one.
Sorry about that call. Looks like VW went with the plastic setup sometime after 85-86.....
The mystery continues. _________________ Current VW drives: 1984 Westfalia
Posted: Thu Oct 25, 2007 11:15 am Post subject: |
PDXWesty wrote: |
Thanks! |
Here you go. The dimensions(not including the large flat part on the left) - the round section is just shy of 3/8" long X 3/16" diameter. The flat part that turns the release is a 3/16" long X heavy 1/16" high X 1/16" thick
I have a total of 4 keys. Theres no need for me to have 3 backups. So I am more than happy to give 2 away F.O.C. One per person. It would be nice if these would go to people that have lost all water tank keys and not just someone looking for a back up. If you would like one, PM your address to me.
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Thu Oct 25, 2007 11:23 am Post subject: |
PDXWesty wrote: |
Thanks! |
i'll get in line for one, i just broke mine, however i do have a spare so i would step aside if someone needs it more. hate using my spare cuz i'll end up breaking it at the wrong time
generous offer rhinoculips |
bucko Samba Member
Posted: Thu Oct 25, 2007 11:51 am Post subject: |
I have a couple of them as well that I'm not using. I'll be away for a couple of weeks, returning the 10th of November if you can wait that long for me to send out. If the other 2 get taken and there is a need for my 2, pmail me as well, and I'll dig them out. _________________ Current VW drives: 1984 Westfalia
Posted: Thu Oct 25, 2007 1:41 pm Post subject: |
PDXWesty wrote: |
Thanks! |
I did make one in brass as a gift for a Westy owner who had lost his (Banjojay67) and it workes fine. The lock is a bit of a tight fit so trial and error is necessary but it certainly can be done. Small files and a dremel tool are in order but certainly not brain surgery (or valve grinding). _________________ -- 1987 Westfalia automatic (Captain Vino) |
21-window Samba Member
Joined: March 23, 2004 Posts: 248 Location: out planting
Posted: Tue Jan 25, 2011 1:47 pm Post subject: |
I need to wake this thread up I think. Anyone know where to get a key like this. My westy came without and I open it with a pick thingy now.
Thanks
PDXWesty wrote: |
Thanks! |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Tue Jan 25, 2011 3:06 pm Post subject: |
What is this 'watertank key' you all mention? My watertank has a brand new cap I bought here in Germany. Came with a metal key, too. And its a real lock and key, not this luggage key in the pic. I got it from this guy
http://server5.gs-shop.de/200/cgi-bin/shop.dll?SES...terID=4357 _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
Timwhy Samba Member
