oldhuldy67 Samba Member
Joined: November 25, 2008 Posts: 506 Location: somewhere with a southern exposure
Posted: Fri Jul 11, 2014 8:24 am Post subject: |
Love My Westy wrote: |
Added 1 can of R-12 to my A/C. I drove it around a while and it's nice and cool. It's been 2 years since I last added some. At that rate, the 6 cans I have left should take me 12 years into the future. I'll be almost 80 years old then and still lovin my van. |
I'm with ya! I've been taking a teaspoon of Marvels's Mystery Oil each day...I'm going to try a shot of R-12 in my 1980 "AC" van ...without A/C...couldn't hurt |
madspaniard Samba Member
Posted: Fri Jul 11, 2014 2:33 pm Post subject: |
oldhuldy67 wrote: |
make sure you also do a leakdown test (aka colonoscopy) _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Posted: Fri Jul 11, 2014 4:44 pm Post subject: |
madspaniard wrote: |
oldhuldy67 wrote: |
make sure you also do a leakdown test (aka colonoscopy) |
I get my rear oil checked every 10 years or 10K miles, my Dad used to say you gotta keep your " koperostic " shifting smooth in all gears...gotta love the Samba |
Dampcamper Samba Member
Joined: October 07, 2013 Posts: 788 Location: Rainy Portland, Oregon
Posted: Fri Jul 11, 2014 8:48 pm Post subject: |
oldhuldy67 wrote: |
Geez, I do a leakdown test every morning when I first get up. Slowly.
But I spent some time today replacing a leaking crankcase breather hose assembly, it had split and sawed through so I had the speckled egg look all over the back of my Westy after a trip to Seattle:
I'd repaired it earlier with some heavy-wall heatshrink but it sawed through:
Made a new assembly from copper refrigeration tubing and fittings:
Painted it white to match the engine:
And after the dog watched the paint dry I installed it using short pieces of rubber hose as jumpers:
The copper tubing is smaller than the rubber hose assembly so won't chew / get chewed between the filter housing and valve cover.
First thing tomorrow the van gets a bath (after my daily leakdown test). |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sat Jul 12, 2014 7:06 am Post subject: |
Dampcamper wrote: |
What mechanical marvel do you have in there? |
big swifty Samba Member
Joined: August 21, 2007 Posts: 246 Location: Formally in Republic of VT; now in Hollywood, FL
Posted: Sat Jul 12, 2014 4:54 pm Post subject: |
Steve M. wrote: |
Looks like a 1.6D. _________________ Evan
1987 Vanagon Syncro // Westfalia pop-top graft // Factory new ALH. 11mm IP. AFN 110 RC 2,3,4 // S7 turbo// Titan P502's
2013 Golf 4d TDI. No mods. Yet.
[1991 Jetta coupe TD. Giles Superpump. Custom tall 5 speed. SOLD |
Posted: Sat Jul 12, 2014 7:11 pm Post subject: And "Big Swifty" gets the prize! |
Yup, it's a stock 1.6 liter NA Diesel. Not setting any speed records nor getting any speeding tickets, it makes for a meditative driving experience and encourages the use of "the road less traveled". Because you're gonna have somebody climbing into your tailpipe on the freeway! Oh, and I get about 26MPG for the Westy, which I enjoy very much. And no emissions controls/modules to burn out.
I painted the engine mostly white when I had it rebuilt, I like to see where the oil leaks are when they are small so I can fix them sooner.
Today, the dog and I went over to another Diesel owner's place and pulled the injection pump out for rebuild. Oregon is one of the states that won't let you "pump your own", owner's wife stopped to get the tank filled and the highly trained pump jockey filled it with gasoline. She made it about 3 miles. Bad, bad, bad. I did the "pull" job while the dog kept their 3-year old busy. Local shop gets about $650 to gut, stuff and calibrate that pump.
There is an exception to the "no self-serve" rule in Oregon, you can pump your own Diesel. Which is what I do, or stand there watching while the jockey pumps in the diesel.
Posted: Tue Jul 15, 2014 12:46 am Post subject: Rolling under the Vanagon: |
Took apart the right rear axle today to troubleshoot a ticking sound. Found no circlip snap ring on the inner end of the half-axle so the axle would slip outwards. This let the outer CV joint catch on the inside of the stub axle and drag, wearing a half-circle inside of the cup and presumably skipping past part of it (thus the ticking sound, I think?).
The shiny silver semi-circle is the worn area.
Took this as a sign to just go ahead and overhaul the axles, replace CVs and bearings and shocks. Get dirty once, get it over with for a lot of miles. You all know what that job looks like so no need for pictures of that, eh? |
wasserbox Samba Member
Joined: April 08, 2008 Posts: 533 Location: Durango, CO
Posted: Tue Jul 15, 2014 8:10 am Post subject: |
Replaced the decomposing foam
Added some shifty-bits
Did some shopping...
frew Samba Member
Posted: Wed Jul 16, 2014 5:49 am Post subject: |
Tested and Fixed my coolant level sensor with a paper clip... the connector had some corrosion in it. |
adamjjohn203 Samba Member
Joined: March 18, 2012 Posts: 187 Location: Bainbridge Island, WA
Posted: Wed Jul 16, 2014 8:11 am Post subject: |
Painted my rear bumper and lower facia with DeeZee spray bed liner. It's just a one step spray can. Temporary until I get a chance to use raptor liner all around the bottom.
_________________ '87 Westfalia
2000 Volvo V70 "eVOLVOd" |
Michael4104 Samba Member
Joined: February 09, 2014 Posts: 340 Location: Livermore, Ca
Posted: Wed Jul 16, 2014 8:24 am Post subject: |
wasserbox wrote: |
Is this above the transmission if so what is the material? Hard to see on my iPad. |
Posted: Wed Jul 16, 2014 9:05 am Post subject: |
Michael4104 wrote: |
Yep - http://www.mcmaster.com/#sound-and-vibration-damping-sheets/=sv339l
The aluminized adhesive sheets. We'll see how well it lasts.
They have other products that might be more appropriate, but I had a number of sheets of this left over from another project. |
dbrossi Samba Member
Posted: Wed Jul 16, 2014 11:56 am Post subject: My today (June/July counts as a single day here!) |
Since taking delivery of my 81 Westy in May, the following has been completed;
-New Oil Pressure Sender (I have the full gauge kit, but couldn't get it installed with the shrouds in the way, so this is temporary)
-New Upper/Lower Ball Joints, New Tie-rod assemblies.
-New Kumo 14 inchers
-New Windshield Washer pump
-New interior carpeting
-New Curtains
-Installed two low power fluorescent lamps
-New Blower Motor/Blower Motor Switch
-New water pump for the sink (Turbo charged! Poowwwerrr!)
-Updated the headlights with a new Relay kit and proper modern headlamps (Someday I -will- run Xenons)
-wired new rear speakers into the radio the P/O installed.
-Installed the brackets anchoring the pop-up tent to the body of the van
-Repaired the e-Brake wiring
-repaired defective LED panel for stove system (in progress, bad micro-controller, bad!)
Planned scheming afoot;
-Repack/replacement of Inner and outer CV joint boots (parts on hand, need to install)
-sort out heating issues (switch set to heat, air isn't heated)
-Replace bad seal around fuel filler neck causing a pungent fuel smell
-Replace fan on Fridge heating system (Parts on hand)
-Re-screen the screen panels for the sliding windows (Parts on hand)
-Finish installation of digital Tachometer (wiring run)
-Finish VDO oil pressure system (wiring run)
And the stuff I think needs done probably when it's cold out;
-rebuild transmission (s'a little vague don't you think?)
-rebuilt engine/replace engine (thinking a 914 2.0 might be the ticket though I have dreams of watercooling.) |
goffoz Samba Member
Posted: Wed Jul 16, 2014 7:57 pm Post subject: |
Nice light guard,I need some of those to go with my step bumper.
Did you make em? or purchase them ...where? thanks
[img][/img] |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Thu Jul 17, 2014 5:35 am Post subject: |
goffoz wrote: |
[img][/img] |
what rear bumper is this? Looks nice. |
goffoz Samba Member
Posted: Thu Jul 17, 2014 8:07 am Post subject: |
xoo00oox wrote: |
[/URL][/img]
Its from a 1989/1990 mitsubishi montero. requires some cutting and welding.
These bumpers are about 4" too narrow for the van.
I cut the center out and mounted the ends to a piece of stock section steel
The center section is a piece of 5" channel steel,w/box steel mounts that go into the stock vw openings....this is real sturdy to take the tow hitch.
The channel steel is then drilled to accept the mitsu bumper hardware,so its all bolt on...easy repair and replacable parts
The end caps need trimming to fit the van body lines.
the tow hitch is a 6 bolt flat mount...lots of options
Dodge raider and isuzu trooper bumpers can be used also, this way...but I don't like the looks of the end caps...this year looks right VW on steroids
HoustonPhotog Samba Member
Joined: February 20, 2013 Posts: 1514 Location: Houston, TX
Posted: Thu Jul 17, 2014 8:17 am Post subject: |
Last night I got a wild hair after work and decided to finally scratch another item off of my to-do list.
When I go camp we normally sleep downstairs with my head towards the rear hatch of the van. I always store my phone at night on the AC cabinet ledge which sits right above me while I'm laying down just in case I need it at night it's easy to reach and find. Well I've been thinking a dual USB charging socket would be nice up there so we could change both phones while we sleep.
I have a few extra Blue Sea dual USB sockets floating around so I decided to go ahead and take care of this install today. Drilled the hole, ran the wires to my Blue Sea fuse block located in the dead space under the flat cabinet and popped in a fuse. 20 minutes later I was done! Now I'll just leave me a cable up there for night time charging and I'm set!
_________________ Abel Longoria
VanAlert App for Vanagons/Buses | Texas Vanagons | My Vanagon Build Thread | Follow Me On Instagram | Vanagon-centric Stickers Available Now |
goffoz Samba Member
Posted: Thu Jul 17, 2014 8:57 am Post subject: |
Thanks... pricey, guess I'll make some up
..think I'll try flat stock on edge. ala landy style
