djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32591 Location: Reading Pennsylvania
kaeferman Samba Member
Joined: April 04, 2012 Posts: 115 Location: Sylva, NC
Posted: Sun Sep 14, 2014 1:10 pm Post subject: |
I fixed the full throttle switch on my 83 that was missing its tabs. i found wires hanging in the engine compartment that weren't attached to anything and it led me to realize that they didn't have anywhere to connect to. i guess people had broke them off inadvertently while fooling with the air cleaner box and air boot. VW jambed a bunch of stuff together right there...silly germans.
I was wary of soldering the old connection points for fear of melting the internal parts of the switch. I got lucky and found a tap and two screws to match from one of my screw hordes. I needed to file the screw down so that it wouldn't bottom out in the switch but I was stoked to find there is about a 1/4 inch of brass rivet there to tap and it held the screw well. I flattened a male connector crimp end and drilled a hole in it for the screw.
Henning Samba Member
Joined: July 17, 2011 Posts: 3 Location: Norway,Nittedal
Posted: Sun Sep 14, 2014 2:01 pm Post subject: |
Washt my syncro today
bonebrake Samba Member
Joined: February 21, 2006 Posts: 34 Location: Phoenix
Posted: Sun Sep 14, 2014 7:40 pm Post subject: |
It was a good weekend on the syncro. We retro fitted a custom bumper (from previous owner) with a 2" tow hitch to haul bikes, a scooter hauler and such. Pulled it off, scuffed it, cut the 2" receiver to size, welded it on and painted it. I also replaced the stereo-to-amp cable so I could actually hear my jams.
[/img] _________________ '58 Beetle Ragtop - RIP
'67 Beetle
'89 Syncro tin top
'17 Golf Alltrack Sportwagen |
narendra.vw Samba Member
Joined: February 07, 2013 Posts: 440 Location: Bangalore India
Posted: Sun Sep 14, 2014 11:18 pm Post subject: |
Henning wrote: |
[ /vw/gallery/pix/1256462.jpg[/img] |
I guess you don’t have old aged people at home. Van will stand out in any parking lot. Van has Cool & tough looks.
Can you please share some pic of F/R suspension . Thanks |
Love My Westy Samba Member
Posted: Tue Sep 16, 2014 10:07 pm Post subject: |
I rotated the tires the other day and noticed my left front was wearing more on the inside edge. I took it in and had the camber and toe in adjusted today. |
Posted: Thu Sep 18, 2014 1:02 pm Post subject: |
narendra.vw wrote: |
Henning wrote: |
Cool that you like my Syncro
Here are some suspension pictures that you asked for
The setup is: GoWesty springs and Fox shocks and a 4cm spacer at the top of the rear springs with 255/70-16" wheels
here are the build thread of it
http://vwbus.no/forum/viewtopic.php?f=55&t=30632 |
ledogboy Samba Member
Joined: September 19, 2005 Posts: 578 Location: Scappoose, OR / Oakland, CA
Posted: Sat Sep 20, 2014 11:11 pm Post subject: |
I decided to take out the windshield to see what was going on in the lower passenger corner where I was seeing rust. I wish I had left it alone for the moment, because it took over the last few days! I had to half ass the repair, as I don't weld, but this should hold me over for a year or two...
_________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
MacDude Samba Member
Joined: July 26, 2014 Posts: 101 Location: Bonny Doon
Posted: Mon Sep 22, 2014 10:28 am Post subject: Fixed my Window Rocking problem |
Finally took my driver door apart to poke around. Turns out that the fiber pad was missing (later found it down below in the drain area in the bottom of the door).
Issue: Driver window was rocking back and forth making a clunking sound when stoping, accelerating, or putting your arm down on it. (rather annoying)
Fix: While some of this could be related to the whole window armature, in my case it was a simple matter of replacing the felt pad in the door frame.
Here are some pictures:
reference picture. the pad is *not* the white one, it's above that.
Here is a closeup of the felt pad in place. It is above the white styrofoam pad.
_________________ '84 Wolfsburg Westfalia
'90 White Multivan (currently not running) |
bmwloco Samba Member
Joined: March 19, 2006 Posts: 1093 Location: Asheville NC
Posted: Mon Sep 22, 2014 1:26 pm Post subject: |
Woke up my '85 Westy yesterday from it's slumber on the street. A quick battery charge (came up to 100%... good battery) and she woke up with authority.
Did a few tasks that have been bothering me for a long time.
Repaired the vent window on the Driver's side. Simple. Figured out why the OEM Blaupunkt speaker on the driver side didn't work - the speaker wire was snipped in two.
And the best thing - added sound deadening to both drivers and passengers doors. Now when you close them, not more tinny "clink" when you close the doors, but a more authoritative Benz like "thunk".
It should really help with road noise - not that it is a big problem...
Now to fix that pesky oil leak... it is always something. _________________ '85 Vanagon Westfalia |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Mon Sep 22, 2014 2:06 pm Post subject: |
Got Scooby back on the road today after nearly 2 mths. The specialists fixed it by adding 2 one way valves into the fuel injection line. The pump itself was fine, it was just that the fuel was draining backward. I don't understand it so I might not be explaining it correctly. The bill was reasonable too. Now have to get used to driving that monolith again and different shifting patterns. Happiness is having it functional again. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
ultra_rnr Samba Member
Joined: September 19, 2014 Posts: 32 Location: Sacramento, CA
Posted: Mon Sep 22, 2014 9:10 pm Post subject: |
Took delivery on a vanagon today, she has been making her way across the US on the back of a truck for the last week.
87 syncro, tin top that was converted to a pop top.
Oh so much to do, but for now just need to get familiar with her squeaks and groans and get her to pass CA smog.
The list:
1.8T over at Stephans and all the bells and whistles that go with it.
Better brakes!!!
A/C (cause it is hot out here in CA I am learning)
Propex heater for the mountains in winter
And everything else that comes up as those are completed.
Oh the fun is only beginning!! |
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
Posted: Tue Sep 23, 2014 12:29 am Post subject: |
ultra_rnr wrote: |
The list:
Better brakes!!!
let the pocket-book pain begin
nice rims+tires, any specs/info available? _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed Sep 24, 2014 4:48 pm Post subject: |
Go, Dave, go!
- Dave
_________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Wed Sep 24, 2014 7:22 pm Post subject: |
ledogboy wrote: |
I decided to take out the windshield to see what was going on in the lower passenger corner where I was seeing rust. I wish I had left it alone for the moment, because it took over the last few days! I had to half ass the repair, as I don't weld, but this should hold me over for a year or two... |
yep...did the same to the passenger side rear window changing to the "vented window". Found some cancer that was not visible...destroyed a Sunday Afternoon and a night waiting for the paint to dry properly to put the window back in by myself. What sucks is I started a new job Monday morning and trying to stay awake was a challenge! What sucks even more is I just sold off some window frames which I could have used to do the repair! |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
