babywindow Samba Member
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
Posted: Sun Jan 04, 2015 11:20 am Post subject: Re: Sliding doors |
Thank you, will look today!
Update: Watched this, definitely one of their best videos so far! _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Royb Samba Member
Joined: May 24, 2008 Posts: 228 Location: Sierra Foothills
Posted: Sun Jan 04, 2015 6:47 pm Post subject: |
not warm out, but dry, so I found the time to finally change the oil and put in the pop-top shocks. I struggled to lift the top with a Rocketbox on before, now, with JackBombay's medium strength kit it's about as easy as it used to be unloaded. I'm guessing it'll be fingerlite without the box up there. Pretty easy install, given my limited skills. _________________ 1991 Westy |
Darren2dream Samba Member
Joined: April 12, 2011 Posts: 162 Location: Redwood City, CA
Posted: Tue Jan 06, 2015 9:05 pm Post subject: |
Installed a new CA catalytic converter today and noticed that they've been eating their spinach in the last few years.
Who's going to pass smog tomorrow... (ME ME ME!)
_________________ 84' Wolfsburg Westy GL 1.9 Manual |
BCE56 Samba Member
Posted: Thu Jan 08, 2015 9:25 pm Post subject: |
I went thru this CA Cat. issue a couple of months ago.
What I learned:
For God's sake, check your O2 sensor(s)!!
A bad sensor will kill a cat faster than you might imagine. (In my case about 100 miles...)
I also found that in Ca. the replacement cat. must have a CARB EO # stamped on the housing to be legal.
To avoid potential problems at visual insp, you might want to install it so the stamped #s are easy to see..
The cat sold by GW and VC is a Magnaflow #339918 (I believe the P/N is correct) and is Ca legal replacement for WBX Vanagons, it has the EO# stamped on housing.
If you are running a Subi conversion as I am, the plot will thicken...
Good luck, and let us know how you make out. |
DenverB Samba Member
Joined: July 23, 2012 Posts: 704 Location: Denver, Colorado
Posted: Sun Jan 11, 2015 9:54 am Post subject: |
So, it wasn't today -- but it's the last thing I was able to do to the van before unexpectedly going into the hospital for a week and then my subsequent recovery from a staph infection. ugh.
But hey, our van looks bad ass! Removed all plastic panels from Winnebago that had faded and browned over the years and sprayed them back to OG color using dove gray dye from RightLook.com (thanks to the folks at PopTopHeaven for the tip on what to use). The van looks so darn good now.
(I've got a few more pictures of the process if anyone is interested)
Next step is to replace the felt-covered celling panels with baltic birch panels to really spruce, er birch, it up. _________________ -------
'77 Transporter/camper (Bussy - Reef Blue/Pastel White)
'67 bug (Santos - VW Blue)
'84 Vanagon Westfalia (Pink Flamingo - Pastel White/Pink)
'88 Vanagon GL Westfalia (Frankie Says - Wolfram Gray)
'02 Eurovan Weekender (Green Apple)
'95-'03 Eurovan full campers and weekenders (rental fleet)
'84 -'91 Vanagon full campers and weekenders (rental fleet)
'72 Porsche 914 (Greta - RIP)
www.RockyMountainCampervans.com |
oldhuldy67 Samba Member
Joined: November 25, 2008 Posts: 506 Location: somewhere with a southern exposure
Posted: Sun Jan 11, 2015 6:00 pm Post subject: Vanny |
OCD never sleeps..put a copy of aux battery/charger/inverter wiring plan where I, my mechanic or a future owner might need to find it..
Found a pair of the seat COSTCO last year, LEDs with an auto-on, motion detector setting. I used Velcro to keep them in place, lights up the cabinets nicely, bright enough for reading.
This gauge pod arrived from T3Techniques..
This is what happens when OCD runs out of things to do...
Driver seat storage and mounted the Haylon fire extinguisher where I could get at quickly ...
I've had these later model headrests for a few years, thinking they might get mounted on the rear seat..no, not there..I use my slip-over headrests I use on my beetle when we have passengers..but, on the fronts the driver seat now clears the window when I rotate it..nice. I'm getting used to the "non-stock" look in exchange for functionality..one brick is as good as another..needs a cushion, then just right!
eurekabilly Samba Member
Joined: September 24, 2012 Posts: 29 Location: Eureka, CA
Posted: Mon Jan 12, 2015 12:57 pm Post subject: |
GoWesty 3rd brake light kit. That was easy! (and cheap too). |
KindaHippyish Samba Member
Joined: December 18, 2007 Posts: 109 Location: Austin, TX
Posted: Tue Jan 13, 2015 8:16 am Post subject: |
I bug-bombed it and vacuumed the interior top to bottom. I saw one too many bugs just pop up from between the dash and windshield and felt the need to do something about it.
I also found a pinhole leak in the brake master cylinder and will be swapping it out this coming weekend. _________________ 1995 Eurovan Camper 5SPD
1991 Vanagon GL 4SPD – Subaru DOHC EJ25 - SOLD
1984 Vanagon Wolfsburg 4SPD – 1.8 I4 - Traded Away
1986 Vanagon GL Syncro 2.1L WBX 4SPD - RIP |
Posted: Wed Jan 14, 2015 12:31 pm Post subject: |
Finally got my 16" GoWesty Steel Wheels with the Michelin Defenders. Also added 1/2in spring shims to the rear, no more sag.
Posted: Wed Jan 14, 2015 2:48 pm Post subject: |
Got some ski bum renters this weekend and had to put the winter tires on the van. Here she is floating above the ground ...
on the FOUR floor jacks that Discount Tire (in Arvada on Wadsworth) used - they actually slipped one of the jacks and nearly sent my van to the concrete, but it thankfully was supported by the other three. I will never go back to Discount Tire after seeing their jackassery today and thankfully didn't have to pay for it after reaming them a new one.
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
Posted: Wed Jan 14, 2015 7:46 pm Post subject: |
eurekabilly wrote: |
looks great |
tam_shops Samba Member
Joined: November 15, 2012 Posts: 1530 Location: Vancouver BC
Posted: Wed Jan 14, 2015 9:33 pm Post subject: Re: Vanny |
Nice work!
Where did you get those? How much did they cost? And, how do you secure them? Might come in handy some time!
oldhuldy67 wrote: |
tam _________________ 1987 Vanagon Westfalia GL Automatic
Making it special:
http://www.thesamba.com/vw/forum/viewtopic.php?t=545885 |
Posted: Fri Jan 16, 2015 12:19 am Post subject: |
Hey, Tam...German EBay..oops, ist das vord verboten? Enshuldiegung sie, bitte.
Well, they weren't cheap, I seem to recall $60+ each and they were the only ones like that I've seen since. Vintage accessory for early Cabriolet. They have two straps that slip under the seat back and friction buckle to two corresponding straps on the other side, behind the seat back. That was the OG color, too. They are quite "springy", offer a good amount of resistance but soft to the touch.. and are basically held in place by your own body weight, I think they'd be effective in a rear ender, and better that having your head snap off with no head restraint at all.
I lived in Stuttguart for 4 years courtesy of the US Army.. Your tax dollars at work. Drove a 78 Bay Westy, I didn't know working for the government could be so nice, (as long as the Soviet Army stayed on their side of the Fulda Gap)
Non German speaker,? just use a computer translator and "copy and paste" away. Search for vintage headrests of something like that...feile Gluck! |
Slimvest Samba Member
Joined: March 20, 2014 Posts: 431 Location: Portland, OR
Posted: Sat Jan 17, 2015 11:51 am Post subject: |
looks good. Parked at the Humboldt north jetty? I've been too scared to take my 2WD out through the dunes the couple times I've surfed there. _________________ '87 GL w/ Reimo top |
pbrown Samba Member
Joined: July 15, 2008 Posts: 443 Location: Seattle, WA
Posted: Sat Jan 17, 2015 12:40 pm Post subject: |
I reinstalled my newly repaired speedometer (odometer fix).
I also changed out the rear hatch shocks. Hopefully the hatch stays up in the cold now. _________________ Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF |
Posted: Sat Jan 17, 2015 6:16 pm Post subject: |
pbrown wrote: |
I also changed out the rear hatch shocks. Hopefully the hatch stays up in the cold now. |
+1, I just did this too! Of course, the new awesome GW strut I just installed on left-rear side is exactly the same part# as the one I removed, which was only installed ~2-years ago - which makes me doubt the quality of the part. "Luckily" I ordered a set because I wasn't sure if I needed one or both, so now I have a spare for about 2-years from now _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
porterbrown Samba Member
Joined: February 25, 2005 Posts: 718 Location: Bentonville, AR
Posted: Sun Jan 18, 2015 2:36 pm Post subject: |
Been putting this off for years, literally. Finally got around to replacing the broken single-stage LP regulator with a new 2-stage regulator. No cutting/flaring involved for my van. The first attempt had some minor leaks so went back with teflon tape and everything is sealed tight now.
**Why did I wait so long to do this?** _________________ '90 Westfalia GL Automatic |
SteelB12 Samba Member
Joined: December 21, 2010 Posts: 591 Location: Central Virginia
Posted: Tue Jan 20, 2015 5:24 pm Post subject: |
Today I replaced the charcoal canister and the valve dealie that it connects to, the Temp 2 Sensor, a headlight bulb, and two door panels with home made ones _________________ 1987 Westy |
droppedsyncro Samba Member
Posted: Wed Jan 21, 2015 2:40 am Post subject: Re: Vanny |
That's a good idea....
oldhuldy67 wrote: |
