Campton Slow Samba Member
Joined: June 10, 2015 Posts: 11 Location: Winnipeg, Canada
Posted: Fri Jun 26, 2015 9:16 am Post subject: |
Got my van a week ago and I've started tracking down air and oil leaks.
Decided to check out the fuel lines.
So I've been replacing all those for the last 2 days.
Also set the valve clearance and a friend helped me installed a third tail light.
_________________ 1980 Vanagon, 1976 Standard Bug |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Fri Jun 26, 2015 2:52 pm Post subject: |
Campton Slow wrote: |
Decided to check out the fuel lines. |
Good decision! |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Jun 26, 2015 3:13 pm Post subject: |
^^^ Nice work, Campton...welcome to Samba!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
zak99B5 Samba Member
Joined: December 21, 2014 Posts: 471 Location: Albany, NY
Posted: Fri Jun 26, 2015 5:09 pm Post subject: |
Replaced the gear oil in the tranny with half Royal Purple MaxGear and half Pennzoil Synchromesh.
Shifts like a dream.
Also installed a new rad fan speed resistor. I only had high speed, which came on only after the radiator got pretty damn hot. _________________ 1991 Tintop GL Manual tranny, EJ22 |
volkylover Samba Member
Joined: March 18, 2005 Posts: 25 Location: Cabo Rojo, Puerto Rico
Posted: Fri Jun 26, 2015 7:13 pm Post subject: Installed my new stereo unit today |
Hi, guys. I replaced the Boss head unit, because it sucks big time. It all started with me wanting a back up camera. So I bought one at Auto Zone with the tiny monitor, and that didn't last long. Then I tried to go wireless, not a happy ending, either. I finally bought a good for the price back up camera and a Chinese DVD receiver with a nice screen, since our vans can't accept the motorized hidden screen stereos. That one didn't work for long (still under warranty but they want it shipped to China for service, so it's hidden in a box), and I made the mistake to buy the Boss re-manufactured DVD receiver. First it came with the wrong connector, so the seller had to send me the correct one. The user's manual is a bad photocopy of the original, the output sucks, the Bluetooth went nuts, and now the back up camera turns on for a bit when I start the radio. Anyways, here's my new acquisition, an Axxera Multimedia DVD receiver with Bluetooth:
The screen is 10.1" LCD.
Compared to the Boss unit.
My back up camera.
How close it is to the gear selector.
The A/C knob almost hidden.
Had to sacrifice the ventilation faceplate and remove the fan knob (I rarely used them).
The stereo sounds great, has HDMI input, a USB port for charging my phone and it's DualMirror ready. It's a tight fit, specially the wiring, and it has an extra mounting frame, so it could stick out a little bit further, bit it will still cover the ventilation fan knob. Check it out:
http://www.crutchfield.com/p_070AV1014B/Axxera-AV1...p;skipvs=T |
VWinVT Samba Member
Joined: April 21, 2013 Posts: 1541 Location: North East Kingdom
Posted: Sat Jun 27, 2015 4:08 pm Post subject: |
First, I built an upper bed extension for my 2 1/2 year old (her sister is only 14 months, she will stay in the pack-n-play till next summer). It leaves about 4 inches at he front of the van. Our daughter loves it..she calls it "the pillow door that daddy made me!" The first pic. is the dry fit of the 3/4 plywood. The second is the fabric covering. I painted the bottom whit and installed 2 metal (5 inch) tabs along the rear edge to hold it down.
Second, this was our first trip using the Thule box. I DO NOT have my rack mounted to the fiberglass, it attaches to the gutter. Yes, this is on purpose, so I have dry storage for all of the 'whatever' when camping. It takes my wife and I about 4 minutes to remove it from the roof.
Last is the cup holder I got at BusDepot. It is GREAT! No screws, just mounts in the ashtray opening AND the ashtray remains in place and works.
_________________ 1981 Westfalia with a 2001 Cabrio ABA
Small wheel turns by the firing rod,
Big wheel turns by the grace of God.
Every time that wheel turns 'round,
You're bound to cover just a little more ground. |
pbrown Samba Member
Joined: July 15, 2008 Posts: 443 Location: Seattle, WA
Posted: Sat Jun 27, 2015 8:55 pm Post subject: |
I installed my new radiator, silicon radiator hoses, stainless cooling lines, and SA grill and lights.
My first radiator came out of the box bent. Van Cafe was great and got me a new one right away.
I powder coated the fan shroud and radiator support brackets so this project took longer than normal.
I have not added coolant yet. I still need to secure the stainless lines at the rear. I wrapped the stainless in heavy vinyl where they contact the body to electrically isolate them. I'll try to get this wrapped up tomorrow. _________________ Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF |
B-bear604 Samba Member
Joined: August 16, 2014 Posts: 118 Location: Delta BC
Posted: Sun Jun 28, 2015 11:08 am Post subject: |
Just got Yogi back from my mecanic yesterday with a new rad...he estimated that the front end is now 15-20lbs lighter. then I put on my new fender flares from TerraWagen. They look great and hide the po damage to the rear wheel arches making the van look less like its owned by some one who doesn't know how to drive. _________________ Brent H
1991 Westfalia Multivan "Vicki"
1986 Westfalia "Wolfsburg Edition" Lowered, RIP😭
2005 Jetta Wagon TDI
1985 Mercedes 380sl |
oldskewlsk8ter Samba Member
Posted: Sun Jun 28, 2015 11:45 am Post subject: |
Finally got tired of the rear end sag due to the suby conversion so I took some old toilet partitions, cut out some spacers, and in under an hour had my van rear end lifted up a lil higher than the front...I'm right at 17" in front and 17.5" in the rear, whereas the rear used to be about 16". Very noticeable to my eyes but I guess most people on the road wouldn't see it. _________________ 1986 Hightop w/EJ25 DOHC & 4EAT auto
1965 Kombi project
Last edited by oldskewlsk8ter on Thu Jul 02, 2015 7:39 pm; edited 1 time in total |
jokeraus Samba Member
Posted: Mon Jun 29, 2015 12:53 pm Post subject: |
The most exciting thing I've done to my recently acquired van, applied penetrol to the top.
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3092 Location: ABQ NM USA.... Except when not
Posted: Mon Jun 29, 2015 12:59 pm Post subject: |
Can you take a pic of the part that goes in the ashtray? Really curious how they did that. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Mon Jun 29, 2015 5:21 pm Post subject: |
Drove it over 420 miles from Albany NY to Orono, ME (alma mater where I met the mrs.) with the wife and three younger kids.
Took about 8 hours altogether. Ran great overall.
Hope I am not jinxing the ride home. _________________ 1991 Tintop GL Manual tranny, EJ22 |
Posted: Mon Jun 29, 2015 5:35 pm Post subject: |
New front window seals...quieter now!
"The WonderVan"
frew Samba Member
Posted: Mon Jun 29, 2015 9:48 pm Post subject: Aux Battery setup and radio toggle |
I worked on my GW auxiliary battery set-up which i partly installed last year, i never go to cutting the wires on the fuse panel... But i decided to cut the wire for the radio fuse 9 and hooked it up with success. Then I decided to try wiring a radio toggle switch in, and a connection for a Coleman solar panel... Well that's when I burnt out two fuses and fried a voltmeter... well it's in there now and some day i'll brave the fuse 8 connectors what i thought would be a 2-3 hour job was the whole day haha |
bmwloco Samba Member
Joined: March 19, 2006 Posts: 1093 Location: Asheville NC
Posted: Tue Jun 30, 2015 1:27 pm Post subject: |
Emptied it of all personal stuff after a decade of ownership. Loaded it with all the stuff I have collected over time.
Sold it on eBay. Goodbye to Beluga... after your second engine failure (blown head gasket) we are saying adios.
Oh, there may be another one someday, but for now. Good bye. _________________ '85 Vanagon Westfalia |
Posted: Tue Jun 30, 2015 2:03 pm Post subject: |
^^^ Sucks... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
faosto Samba Member
Posted: Tue Jun 30, 2015 9:15 pm Post subject: Super Stoked |
Got myself an new van and cleaned the crap out of it! California blue and running like a champ!
_________________ Do the work yourself... |
DenverB Samba Member
Joined: July 23, 2012 Posts: 704 Location: Denver, Colorado
Posted: Thu Jul 02, 2015 4:33 pm Post subject: |
repaired three norcold fridges (relighter board replacement)
put a new tent in a Eurovan top (made locally from rubberized canvas)
glued a new headliner in a Eurovan
new tires on my '88 (bfg at 195s)
removed rack mounts from a eurovan after nearly tearing off a roof on a low-hanging basketball goal on my neighbors garage
fixed broken interior door latch in a 97 EVC ($.47 replacement part took two hours of fiddling to fit)
And I removed/repacked (fought with)/fitted the CVs on my baywindow, but that's for another forum... _________________ -------
'77 Transporter/camper (Bussy - Reef Blue/Pastel White)
'67 bug (Santos - VW Blue)
'84 Vanagon Westfalia (Pink Flamingo - Pastel White/Pink)
'88 Vanagon GL Westfalia (Frankie Says - Wolfram Gray)
'02 Eurovan Weekender (Green Apple)
'95-'03 Eurovan full campers and weekenders (rental fleet)
'84 -'91 Vanagon full campers and weekenders (rental fleet)
'72 Porsche 914 (Greta - RIP)
www.RockyMountainCampervans.com |
BCE56 Samba Member
Posted: Thu Jul 02, 2015 5:27 pm Post subject: |
Welcome, faosto!
That's a clean looking tintop. Is it your first?
Details? _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!" |
Skidub Samba Member
Posted: Fri Jul 03, 2015 6:30 pm Post subject: |
Washed the van up because it needed it and applied a syncro sticker to the spare tire cover. Turned out sweet, but time will tell on stick longevity.
I cleaned the sticker area with mineral spirits and very carefully rubbed on the entire sticker, then rubbed more as I pulled past each letter, then rubbed each letter enough so that the texture of the cover telegraphs through the letters.
_________________ 86 Syncro GL Tin Top
Subaru 2.5L Swap
Rblt Transaxle w/ R Locker + Decoupler |
