vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Sat Jan 30, 2016 9:05 am Post subject: Re: What did YOU do to your van today? |
I think it may well be - thanks for that! _________________ Jim Crowther
Vespa GTS 300 |
yiucycle Samba Member
Posted: Tue Feb 02, 2016 11:02 am Post subject: Re: What did YOU do to your van today? |
fxr wrote: |
The horn was feak and weeble, so added a LOUD HORN from GW. Excellent horn - when it worked.
Turns out my horn ring (that doesn't sound good, does it...) was a thin sliver just 0.3mm wide, and the contact on the turn signal switch assembly was a thin flaky point. A bit hit'n'miss in other words.
A new horn ring (just the brass part) is on order, and I'll mend the contact with a bit of springy brass soldered onto the original - I'm not forking out for a new turn signal switch just for that. |
I added a horn relay, It use a better grounding path than stock horn switch.
https://sites.google.com/site/vanagonheadlightrelays/horn-relay _________________ 1980 2.8LV6 Fiero ASI/Riviera Vanagon
"there is no point in being embarrassed of all the stupid shit i done and will continue to do"
seans67 Samba Member
Joined: October 06, 2004 Posts: 453 Location: End of the Road, Alaska
Posted: Thu Feb 04, 2016 2:21 pm Post subject: Re: What did YOU do to your van today? |
Since finishing the 1.8T install a few weeks ago - new rear shocks.
Now I have the front end torn apart- new front wheel bearings, tie rod ends, upper ball joints, and Upper control arm bushings.
Also rebuilt the power steering rack, not really that hard. Waiting for power flex bushings so I can put it all back together.
Oh and a new stereo, nothing special just a pioneer deck from Amazon but it does have Bluetooth and a USB port. Now I need to make a cabinet in the back above the bed where the old AC used to be. So I can put the new speakers in there. _________________ Sean
'71 Squareback '71 Porsche 914 ‘80 Camper '87 Syncro Weekender 1.8T '87 Wolfsburg Weekender '97 Toyota Land Cruiser ‘03 Audi A6 Quattro 3.0 ‘04 Audi A4 Avant Quattro 1.8T ‘05 Audi A4 Quattro 3.0
‘06 Porsche Cayenne Turbo S |
oldhuldy67 Samba Member
Joined: November 25, 2008 Posts: 506 Location: somewhere with a southern exposure
Posted: Sat Feb 06, 2016 3:57 pm Post subject: Re: What did YOU do to your van today? |
OK...I know that there are real mechanics out there, master fabricators, electrical-solar-off-the-grid Sambanistas y Sambanistos. Me, I am just another poor soul who depends on a1980 Westy for my OCD treatments. I just found a good dose of practical therapy.
I have seen others post about Honda Oddessy's flip-down cup holder console and seen the report that they won't work on swivel seats. So... I thought about it and began to wonder if it could work if it had a bracket that would allow you to easily remove it. The seat could be turned around and then the small console could be put back into use while camping.
Toby Bennin and John operate an air cooled shop, Import Restoration in Smyrna, Ga. I am blessed to have these friends...they are worth the $, too.
So, here's what we came up with...
Bead blasted some old steel and painted it with "Vanagon Brown".
Poked the holes, cleaned up the wheel well surface and filled the old cup holder holes with dumdum, sealed the area with tar-backed roll sealer, heated it up with my heatgun, pressed/rolled into place, and then locked it into place with nyloc 5/16.
I decided to remove the front wheel to avoid banging into brake lines.
_________________ Currently:1980 Westy Westfalia Poptop (a total stock-look rebuild with all my favorite camping mods)
1967 stock Sunroof Beetle
Formerly:
1978 Westy Campmobile, the"EM50 Urban Assault Vehicle" code named "The Pickle"
1973 Squareback (sold on a lark)
1973 Super Beetle (crashed..walked away without a scratch)
1972 Standard Beetle (lost in a relationship..)
1966 Beetle (the Black Beauty, my Dad's)
1964 Beetle (the Beige Bug, my beginning beater, also my Dad's) Thanks, Dad. |
Abelabelabel Samba Member
Joined: November 17, 2014 Posts: 336 Location: Santa Ana, CA
Posted: Mon Feb 08, 2016 10:57 am Post subject: Re: What did YOU do to your van today? |
Installed a new Gowesty Dash PCB last week.
Pros:
It works! And there's no other robust alternative once the factory foil-type connectors bite the dust. They are so fragile.
This is a great item to have available, as the foil is really *weak* The foil was delaminating, and attempting to install new LED's to illuminate clock + idiot light icons + speedo + Tach didn't work. The tach and speedo still worked, but I suddenly had no lights, and my Oil pressure buzzer would go on, and stay on as soon as I hit about 2300 RPM for the first time.
Cons:
My clock doesn't work anymore, which is just kind of annoying, because of where the new PCB is located, it's going ot be a PITA to torubleshoot. Sometimes my Oil Pressure light will "flicker" as I change gears and the RPMs drop and raise back up.
Pics of the install:
7MM bolts.
All cleaned up.
Some of the left overs.
Nuts set aside, these will be reused. Other plastic pieces pictured are "deleted" once new PCB is installed.
Getting the PCB pieces to "mate" with the old plugs was the hardest part of the install. Shined a flashlight behind to help me make sure I was making a solid connection between the female and male parts.
Must not have gotten it right for the clock, as it's still not working.
Could also be a little moisture that got in there when I was cleaning everything up while I had everything taken apart.
Here's another neat step. Little rubber tubing was included to help create a "light barrier" for the colored LEDs. Replacement is just those cut LED diodes, so "outside light" can enter. Putting these sleeves on keeps that from happening. Was kind of a pain, but it worked! Really made me appreciate the attention to detail that Gowesty had. It's still very much a DIY fix, but they've filled in all the blanks that would have made this a mediocre upgrade.
Another PCB install where Female - Male connection has to be done almost blind, since the replacement doesn't have "fitted" female plug. To make sure PCB stays on properly a small amount of glue is required. So getting it wrong the first time was a bummer, I had to remove the glue, clean, clean, clean, and test before semi-permanently gluing again.
Next on the list:
Hissy Leaky AC to figure out.
Pwer Steering ATF drip-drip-dripping
New Radiator that's ready to put on.
Then:
Brakes. . . Exhaust. . . suspension . . Paint. _________________ 1991 Vanagon GL / Carat Interior / Auto - White "Daily"
1990 Vanagon Carat / manual / Cherry Red "Bella Rouge" |
singletrackrod Samba Member
Joined: January 14, 2011 Posts: 77 Location: Southern Oregon Coast
Posted: Tue Feb 09, 2016 2:54 pm Post subject: Re: What did YOU do to your van today? |
Here's a quick photo- before the final fitting - of my new Wet Okole neoprene seat covers. The fit and finish far exceeded my expectations. If you are looking to re-do your seats and want a durable, easy to clean surface, these are worth a look.
More photos to follow.
I also finished the lacquer/wax finish on my table.
Final getting close to completion
_________________ Ella '89 Full Camper - bit by bit I'm importing the pieces from my wrecked '87
Louise '87 Full Camper - bought her new - zero hours 2.5L subie conversion. She had more add-ons and mods than I could ever count. (lost in an accident 10/25/2020)
'08 Stage 2 STI (sold)
'04 Forester XT
'00 4Runner Limited (sold)
Last edited by singletrackrod on Mon Feb 22, 2016 8:37 am; edited 1 time in total |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Thu Feb 11, 2016 6:55 pm Post subject: Re: What did YOU do to your van today? |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Sat Feb 13, 2016 7:32 pm Post subject: Re: What did YOU do to your van today? |
New squirters from T3 Technique:
And these FANTASTIC new plates. I finally found a specialty plate I can get behind (and qualify for.)
_________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Mountain1.8t Samba Member
Posted: Sun Feb 14, 2016 6:47 pm Post subject: Re: What did YOU do to your van today? |
singletrackrod wrote: |
Final getting close to completion |
More photos of the seat covers! Look solid. They just install over the factory seat fabric? Did you get the heat option? |
Posted: Sun Feb 14, 2016 6:48 pm Post subject: Re: What did YOU do to your van today? |
joetiger wrote: |
How is the spray pattern vs stock? |
Posted: Sun Feb 14, 2016 7:23 pm Post subject: Re: What did YOU do to your van today? |
Running_Man wrote: |
The individual spray patterns are a bit narrower. It took a bit of time and patience to get them directed properly, but you definitely get more fluid in more places on the windshield. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Posted: Mon Feb 15, 2016 8:42 am Post subject: Re: What did YOU do to your van today? |
Yup, they fit right over the factory seats. Because the fit is soooo good, it does require some effort to get them on correctly, but I think the result is outstanding. I didn't option for the seat heaters, as the van is now mostly a warm weather vehicle. I'll get some more photos posted once we have a dry, sunny day here.
'04 Forester XT
'00 4Runner Limited (sold) |
Mike760 Samba Member
Joined: November 19, 2015 Posts: 43 Location: Oceanside, CA
Posted: Mon Feb 15, 2016 8:14 pm Post subject: Re: What did YOU do to your van today? |
Abelabelabel wrote: |
Installed a new Gowesty Dash PCB last week. |
Does your tach work with the kit?
Can't tell if you have one from the photos but I've got a broken tach (someone soldered the foil before but it no longer works) and am interested in the kit if it restores that.
Thanks! _________________ 1984 Westfalia |
digthemlows Samba Member
Joined: December 11, 2015 Posts: 36 Location: Sacramento, CA
Posted: Sat Feb 20, 2016 2:16 pm Post subject: Re: What did YOU do to your van today? |
Drilled my very first holes in the westy.....Lift assist is now installed.
Posted: Sat Feb 20, 2016 5:44 pm Post subject: Re: What did YOU do to your van today? |
While the aftermarket bumper options are very nice, they're a bit out of my price range. Having beaten up my original chrome rear bumper (and then another) I figured I'd go with a cheap black one this time around.
CIP1.com sells two versions, the super-flimsy one that we're all familiar with, and an upgraded version for more $$. They were having a sale last week, so I bought the more expensive one. I can tell you that it's as heavy as the original.
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-255-807-111-CBK
My foot slides off of them, which bugs me, so I added some self-adhesive treads cut down to size ($10 from Amazon.) We'll see if they stay on or if I need to come up with better mounting solution, or scrap them altogether. They do look OK right now, though, and should serve their purpose.
http://www.amazon.com/Keeper-05680-Safety-Step-2-p...3MYS44CHQV
'04 GTI 1.8T
'04 Golf R32
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1491 Location: Victoria,B.C.Canada
Posted: Sat Feb 20, 2016 6:58 pm Post subject: Re: What did YOU do to your van today? |
Fixed rad fan in 88 Wolfsburg Carat auto with Subaru 2.5L (no working A/C)
Wire colors are different from Bentley 97.141. My rad fan thermoswitch had RW3 (+ve with IGN ON); RB2 (relay clicked only when jumped from RW3);RBL1 (nothing when jumped from RW3)
Checked relays 2nd stage (#53) on fuse panel and 3rd stage with fuse under dash behind left air vent). Both clicked OK with 12v and ground from the battery.
Hooked up battery + and - to the rad fan using jumper cables and alligator clipped wires. Rad fan worked OK. Faulty fan ground. Added a second ground to the fan. Thank you The Samba.
Now I had high speed fan when jumping thermoswitch RW3 to RB2.
More wiring difference. RBL1 at thermoswitch becomes RB at the harness connector to the resistor (2 RB wires,1 B wire into resistor,1 red wire out).
Jumping RW3 to RBL1 at the thermoswitch I got + at RB2 at resistor. The other RB and B wires feed from the A/C. I Connected one RB to the B wire so resistor 1 and 2 will both be +ve when RW3 is jumped to RBL1 at the thermoswitch. Then I had slow speed fan .So I am bypassing the 2nd stage relay in the fuse panel.
So at 95 degrees C at the thermoswitch I get slow speed fan and at 102 degrees C I get high speed fan at least in my test scenario. |
MrBuelterman Samba Member
Joined: February 12, 2014 Posts: 91 Location: Seattle WA
Posted: Sun Feb 21, 2016 10:49 am Post subject: Re: What did YOU do to your van today? |
Installed Blazecut on the desk lid.
_________________ 86 2.4L 2WD Peloquin Westy |
rlbarnes5 Samba Member
Joined: March 01, 2014 Posts: 10 Location: United States
Posted: Mon Feb 22, 2016 6:21 pm Post subject: Re: What did YOU do to your van today? |
Added a driver's side grab handle!
Thanks to all who posted advice on this project. Handle cost me $10 on eBay. Wedges free from my mechanic. Total time about 45m for install. No cursing required!
Details on my mods page here: http://byronsalaskaadventure.blogspot.com/p/byron.html[/url] |
TommyBoyGomes Samba Member
Joined: May 28, 2005 Posts: 1531 Location: L.A./Dublin, Irl
Posted: Tue Feb 23, 2016 7:03 pm Post subject: Re: What did YOU do to your van today? |
I put new shoes on my multi. Love me some Rheins!
_________________ 1969 Squareback, 1776cc
1990 Vanagon Multivan |
