Ninamashr Samba Member
Joined: October 12, 2005 Posts: 1400 Location: City of Round Rock in the Great State of Texas
Posted: Wed Nov 14, 2007 12:38 pm Post subject: Okrasa oil cooler |
If I was to install an Okrasa oil cooler kit to my 36hp would I have to remove/change the cooling ring in the fan? _________________ 1957 Karmann Kabriolet "Franky"
1957 Allstate trailer |
dinsdale Samba Member
Joined: October 12, 2005 Posts: 86 Location: London, UK
Posted: Wed Nov 14, 2007 12:59 pm Post subject: Re: Okrasa oil cooler |
Ninamashr wrote: |
If I was to install an Okrasa oil cooler kit to my 36hp would I have to remove/change the cooling ring in the fan? |
If you mean this, you have to remove it.
Peter |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Wed Nov 14, 2007 3:04 pm Post subject: |
Hello-
If you do add one, I would love to see some before/after temp' data.
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
Posted: Thu Nov 15, 2007 8:11 am Post subject: Re: Okrasa oil cooler |
dinsdale wrote: |
Ninamashr wrote: |
Peter |
Yep, that's the one, thx peter. I'll try to get thet temp info once I get it installed. _________________ 1957 Karmann Kabriolet "Franky"
Wiggy Samba Member
Joined: April 17, 2003 Posts: 6601 Location: Downingtown, PA
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13955 Location: Southampton U.K.
Posted: Thu Nov 15, 2007 9:36 am Post subject: |
Wiggy wrote: |
I don't think they make enough difference to go through the trouble. |
I've blown hot and cold on these...whoops sorry about the pun.
They have become, how can I put this...fashionable, with the Judson fraternity. I'm no different I used one on my Judson Beetle.
If you put any cooler in the airflow it will do two things:
1. It will cool the oil that flows through the cooler and
2. It will warm the air that flows over the cooler.
The first part of the equation, the cooling of the oil in my experience, (without figures to back this up) was successful. The second part, the heating of the airflow blown over the cylinder heads, I don't think on a normally asperated engine, is significant enough to cause problems.
However, as a supercharged engine runs hotter than the normally asperated, I now think it's not worth the risk to further increase head temperatures when supercharging.
Back in the day respected VW writer Henry Elfrink was a big supporter of the cooling spiral...did he get it wrong?
Personally, after giving this a lot of thought, I think the best aid to cooling is the good old fashioned sump extension, keeping the extraction of heat away from the top end of the engine cooling route.
We definitely need figures to sort this out once and for all. _________________ John.
Dave Haviland Samba Member
Joined: June 26, 2005 Posts: 322 Location: Burlington, Vermont
Posted: Thu Nov 15, 2007 11:18 am Post subject: |
Just by eliminating the throttle ring you should get better cooling. By putting the copper coil in its place, you are once again reducing airflow. I'd try it without the throttle ring first and see what that does for you.
Dave |
DaveM Mad Samba Scientist
Joined: June 11, 2002 Posts: 3010 Location: Dry side of Oregon
Posted: Thu Nov 15, 2007 11:48 am Post subject: |
Speedwell offered an oil cooler for placement in front of the fan intake. From my understanding, it was and still is a very bad idea. Now, when it comes time for me to build my speedwell sprint kit engine, I'll probably install the oil cooler just to in tune with the vintage gods. _________________ Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Posted: Thu Nov 15, 2007 1:28 pm Post subject: |
Dave Haviland wrote: |
Just by eliminating the throttle ring you should get better cooling. By putting the copper coil in its place, you are once again reducing airflow. I'd try it without the throttle ring first and see what that does for you. |
I did not notice an engine oil temperature increase when I installed the throttle ring. I did not specifically do any detailed temperature checks though, just random temperature checks after highway runs.
On the other hand, the car drove a lot better when cold with the ring installed. _________________ How to Post Photos
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
billb Samba Member
Joined: October 23, 2005 Posts: 369 Location: Austin, Texas
Erik G Samba Member
Posted: Thu Nov 15, 2007 3:02 pm Post subject: |
yeah, it's a vert so most likely I will not be driving it in the cold. I usually let my cars warm up for a minute or two anyways. I'll look tonight to see if it's there, doubt it though.
funny about the cooling flaps on later motors, in nor-cal, I really havent seen them too much. Every vw I've had has them removed. must be a CA quickie rebuild thing _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Pharquarx Samba Member
Joined: August 24, 2005 Posts: 249 Location: Southern California (Orange County)
Posted: Wed Nov 28, 2007 9:02 am Post subject: |
Just came across this. Several people told me that here in Southern California, that the cooling ring was not needed due to the mild climate and it was one of the first things that was discarded, at the dealerships is what I am lead to believe. I left the cooling ring in place, simply because it was functional and I like that. Have installed the okrasa cooling coil and positioned it forward slightly to make sure that it clears the cooling ring as it moves out. Body is currently off of my 56 bug and I have had plenty of opportunity to run the engine and observe the interface with the cooling ring and the cooling coil. All looks good and operates well. Eventually I will supercharge with a Judson. Love this old machinery, love to keep it running.
Charlie |
Eric Outland Samba Member
Posted: Tue Dec 04, 2007 9:32 am Post subject: Eric (VMR) |
I am of the old Mottoe! If it left from the factory with it ( Regarding The Engine) Then for my own piece of mind my 25-36hp motor's will also have it installed.
Now as far as the after market oil filter/ oil cooler, such as one manufactured by Steph. in Europe for the Judson or Okrasa line kits there is no other alternative but too eliminate the Fan shroud ring all together when running the Oil filter/oilcooler kit. Other than that if going stock set-up run the ring Eric (VMR) |
Posted: Tue Dec 04, 2007 9:47 am Post subject: |
My setup came from Steph. I let him know that I wanted to retain the operating cooling ring and he adjusted the design. I have it all. I will post some photos of my setup when I get home tonight.
Charlie |
ProjectX Accessory Nut
Posted: Tue Dec 04, 2007 2:31 pm Post subject: |
Here is a shot of the cooler with the cooling ring
Enjoy!
[img]http://www.thesamba.com/vw/forum/album_page.php?pic_id=399411[/img] |
Posted: Tue Dec 04, 2007 3:52 pm Post subject: |
Yes, exactly. I will still post photos of mine this evening (if I can relocate the primer as to how to post photos). Slight differences on mine as both the supply and return come over the shroud to the front, but the setup that you show is it, that is, the cooling coil held by a clamp secured to the case. I really liked this setup as it allowed for adjustment and proper placement of the coil assembly so there is no interference between it and the ring over the range of the ring movement.
Question, where did you get the small clamps to secure the flex return line to the top of the shroud and, is it a rubber sleeve, no temperature problem I take it.
Charlie |
Posted: Tue Dec 04, 2007 3:57 pm Post subject: |
They are rubber sleeve, Steph included them with the kit.
I haven't run it yet to find out if the temp will be an issue, but if it is I will use metal clamps. I already heated the thermostat to check free movement of the ring and it works AWESOME.
I prefer to keep all original parts on the motor, so I think having the ring in place is appropriate. However, like everyone has said, being in California it's probably totally unnecessary. I just like how mechanical it all is. Who am I to question German engineers??? |
Posted: Tue Dec 04, 2007 3:58 pm Post subject: |
Sorry, my lines are set up for an external Fram filter, that's why the return doesn't come back over the top of the shroud. |
