Ccino Samba Member
Posted: Wed Nov 14, 2007 9:48 pm Post subject: Type I engine in a Type III |
Im 17 and i want my first car to be a Type III. My buddy has a couple Type I engines for me if need be. Is the type I engine compatible with
the Type III? He said it can be done but i just want to make sure... Thx |
Posted: Wed Nov 14, 2007 9:54 pm Post subject: |
you can do it. it may over heat because there is no air going to it. |
Ccino Samba Member
Posted: Wed Nov 14, 2007 10:07 pm Post subject: |
thats all? maybe that problem could be fixed with a luvered hatch or something that raises the hatch alil |
Posted: Wed Nov 14, 2007 10:08 pm Post subject: |
that what i would do. |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22448 Location: Escondido CA
Posted: Wed Nov 14, 2007 10:09 pm Post subject: |
Its a bad idea to put a T1 in a T3. As stated it wont get air right. You would have to re-egineer the coolng. Hold out for a T3 motor. Or get the T1 motor-sell it then get a T3 motor. You will be happier in the long run. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3040 Location: Portland, Oregon
Posted: Wed Nov 14, 2007 10:18 pm Post subject: |
Or get the proper T3-specific parts (cooling tin, fan housing, etc.), strip the T1 engine, and put the T3 parts on it. Except for the oil filler, the engines are pretty much the same in the long block sense (or is that short block?...I get the two mixed up).
What model of T3 do you have? _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
Posted: Wed Nov 14, 2007 10:24 pm Post subject: |
Air_Cooled_Nut wrote: |
What model of T3 do you have? |
Long block=with P&Cand heads
Short block=with out those
And this is a good idea as well for a baller on a budget _________________
t3kg wrote: |
1964 1500 S
73notch Samba Member
Posted: Wed Nov 14, 2007 10:45 pm Post subject: |
FAQ
Q. Can I put a Type 1 (upright) motor in my Type 3?
A. Yes, it fits as the Type 1 and Type 3 motors are basically the same. However, your cooling will be seriously affected. The Type 1 engine is designed for a sealed engine compartment while the Type 3 is not. For best results and long engine life, you would have to completely seal off the engine compartment with custom tin, as well as provide a way for fresh air to enter. That work, combined with the increased noise and loss of the rear trunk area, make using a Type 1 engine a poor idea.
save up and do it the correct way. _________________ SubyNotch.com is back up! |
JSMskater Samba Grease Gorilla
Joined: February 01, 2006 Posts: 5362 Location: Murrieta California
Posted: Thu Nov 15, 2007 3:14 am Post subject: |
get a t1 engine from your friend. strip it down to the long block, and sell off the carb, gen or alt, fan shroud, tin, all that jazz. keep the fuel pump and distributor. you can even sell off the crank pulley.
then with the money you made, buy a used set of t3 tins and the fan and fan shroud. paint them yourself. with the money you saved take the long block and get the holes made in the case for mounting the rear hanger mustache(if its a late model) and then re-assemble the motor using the t3 parts. look for a complete FI system or a stock set of 32pdsit carbs. you can use weber 34's, but they dont work as well IMO.
DO NOT USE the t1 motor as is. its not a good idea. _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors |
COFBack Samba Member
Joined: July 05, 2005 Posts: 2148 Location: Colorado Springs
Posted: Thu Nov 15, 2007 6:30 am Post subject: |
JSMskater wrote: |
DO NOT USE the t1 motor as is. its not a good idea. |
Read and Heed _________________
iowegian wrote: |
Henceforth he shall be known as "Trameltoe".
Chickengeorge's wife wrote: |
bing chow ching fong fang T.J. fang ching dow fong |
SquareTone Samba Member
Joined: July 10, 2003 Posts: 1204 Location: Jenks, Oklahoma
Posted: Thu Nov 15, 2007 7:09 am Post subject: |
I say go for it.
The quicker we get all of the surplus T1 engines burned up the quicker we can quit getting this question. _________________ Tony
'70 Fastback AT/FI (daily driver (exept when the starter won't work, or it's out of gas, or I don't go anywhere, ...))
"...it is a well known fact, that those people who most want to rule people are, ipso facto, those least suited to it."
Help Improve TheSamba |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Thu Nov 15, 2007 8:39 am Post subject: |
This question comes up frequently enough that there should be a sticky,
similar to this one for the Late Model/Super forum. _________________ Everything known to man has been written.
Readers are Leaders! |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Thu Nov 15, 2007 8:45 am Post subject: |
Air-Cooled Head wrote: |
similar to this one for the Late Model/Super forum. |
There is, but the schools don't teach reading as a required subject anymore. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69807 Location: Phoenix Metro
Posted: Thu Nov 15, 2007 9:19 am Post subject: |
Ev
Pretty obvious the OP didn't bother to read the FAQs _________________
iowegian wrote: |
Posted: Thu Nov 15, 2007 12:44 pm Post subject: |
COFBack wrote: |
Ev
Pretty obvious the OP didn't bother to read the FAQs |
Read Haven't ya heard? "The best place to hide something is in a book."
The problem with what's already there is, it recommends against the idea, then gives the reasons why.
But that's like logically explaining to a 4 year old why he shouldn't drink anti-freeze, when all he understands is it looks and smells drinkable.
Chory Samba Member
Joined: September 24, 2006 Posts: 1318 Location: Jefferson Westside, Eugene, Oregon, USA
Posted: Thu Nov 15, 2007 5:25 pm Post subject: Re: Type I engine in a Type III |
Ccino wrote: |
Im 17 and i want my first car to be a Type III. My buddy has a couple Type I engines for me if need be. Is the type I engine compatible with the Type III? He said it can be done but i just want to make sure... Thx |
Better idea allaround. Get a T3 with an engine already in it.
Car first. Engine is of little concern without a vehicle.
You will quickly find in the world of the Type 3, that T1 guys are the very WORST source of advice. _________________ Be kind…
Current Fleet:
‘07 Saab 9-4 2L Turbo (GM era, US bild)
‘91 Honda Beat (JDM, mid-engine, KEI) |
Euro 67 Samba's 67 part whord
Joined: February 24, 2007 Posts: 1370 Location: Between Florida and Cali
Posted: Thu Nov 15, 2007 5:39 pm Post subject: Re: Type I engine in a Type III |
Chory wrote: |
Ccino wrote: |
You will quickly find in the world of the Type 3, that T1 guys are the very WORST source of advice. |
Hey that's not true for some of us.
I'm running a typ1 motor in my fasty. It has been converted to a type3 cooling, not hard. but the thing is, I can't run a vac adv.(not that I would)
because a type 3 dist drive gear is in a different position than the type 1.
and for the oil, put an early model oil fill, the cap does come off of them.
then find a long long long, type 1 dipstick.
this coming from the Type 1 guy _________________ 68 Bug totaled one day will live again
69 Bug donor car
Many parts had, always need em!
millerje78 wrote: |
I'm no expert but I'm guessing the spike during cold running has everything to do with the roofing tar(20-50) in the crankcase. |
bill may wrote: |
...i could be wrong as i have only been driving air cooled beetles since august 1965. |
Chory Samba Member
Posted: Thu Nov 15, 2007 7:22 pm Post subject: Re: Type I engine in a Type III |
Project_67 wrote: |
Hey that's not true for some of us. |
Okay let me clarify:
Chory wrote: |
You will quickly find in the world of the Type 3, that T1 guys (with the exception of about four of them in the whole world) are the very WORST source of advice (unless, of course, they are T1 guys who also rock T3s). |
Current Fleet:
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
