chabanais Samba Member
Posted: Sun Jul 19, 2015 1:53 pm Post subject: |
Man that just makes me sick to see that.
More than $50,000 I think...
_________________ "I spud therefore I yam."
BusPriest Samba Member
Joined: October 08, 2014 Posts: 420 Location: Denver, Co
Posted: Sun Jul 19, 2015 1:55 pm Post subject: |
So, is the shell salvageable when something like this happens? _________________ 1977 Champagne Transporter Custom Camper.
SOHC EJ25, tubbed, wagenswest
Work in progress build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=619684
Not a Priest. |
babysnakes Samba Member
Posted: Sun Jul 19, 2015 2:13 pm Post subject: |
Usually not, the heat warps the body panels to the extreme. Rust forms quickly. |
baybus70 Samba Member
Joined: September 25, 2008 Posts: 39 Location: Liverpool, UK
Posted: Sun Jul 19, 2015 2:33 pm Post subject: |
BusPriest wrote: |
So, is the shell salvageable when something like this happens? |
As I understand it a vehicle with that level of fire damage would likely be a category A write off here in the U.K. Means everything has to be destroyed and can never go back on the road- even if you had the skills and cash to fix it. |
Posted: Sun Jul 19, 2015 2:34 pm Post subject: |
BusPriest wrote: |
Not only can the body panels get warped but the metal changes and becomes weaker. _________________ "I spud therefore I yam." |
peteandvanessa Samba Member
Joined: July 01, 2009 Posts: 931 Location: Sacramento
Posted: Mon Jul 20, 2015 9:32 am Post subject: |
I loved y'all rebuild thread, P&V.
If I remember correctly, you had to buy it back from insurance. When you did this, did it render it having a salvage title? _________________ 1977 Champagne Transporter Custom Camper.
Not a Priest. |
beatles4 Samba Member
mango-smoothie Samba Member
Posted: Mon Jul 20, 2015 10:54 am Post subject: |
BusPriest wrote: |
If I remember correctly, you had to buy it back from insurance. When you did this, did it render it having a salvage title? |
That is correct, we had a real battle with the insurance company, they low balled it's value (and I mean really low). Had to get an independent valuer to get it appraised correctly and even then it was a long battle.
The bus now holds a salvaged title and we had to get the usual safety, light and brakes check. _________________ My 1974 Standard Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=568220&postdays=0&postorder=asc&start=0
My Son's 1971 Bay Window Westie Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=7295189#7295189 |
Posted: Mon Jul 20, 2015 11:37 am Post subject: |
peteandvanessa wrote: |
BusPriest wrote: |
The bus now holds a salvaged title and we had to get the usual safety, light and brakes check. |
And you can not get full coverage with a salvage, right? _________________ 1977 Champagne Transporter Custom Camper.
Not a Priest. |
Posted: Mon Jul 20, 2015 12:04 pm Post subject: |
BusPriest wrote: |
BusPriest wrote: |
And you can not get full coverage with a salvage, right? |
Well if you mean the current insurance and with it being a salvage title, then yes, we have full coverage on the Bus. It's insured with American Modern for an agree value of $15,000. _________________ My 1974 Standard Build Thread:
dailyoliver Samba Member
Posted: Fri Aug 07, 2015 4:57 pm Post subject: Help Needed PLZ - new to VW's and this post is scary!!! |
After reading this post I decided to check out my new van - 1979 Single Bay Westfalia w/ 2000cc engine.
WOW - I am so glad I did - because it breaks every rule. I am worried because I am a complete NOOB and this is my first van.
Can anyone help me PLZ?? Here's what I found.
Plastic fuel filter inline **after** the pump in the engine bay
THIS I NEED HELP WITH THIS - WHAT IS IT?
This thing sits after the fuel filter before the line to the single carb- It has two outlets - one which is blocked off.
Here's a look top down
Here's the back of it.
Finally - I see the fuel line entering the bay without a rubber grommet - at least I think that this is the fuel line?
I was thinking that I order a kit from German Supply - but given the set up I was not so sure it would fit?
What steps would you guys recommend I take to make the van safer from spontaneous combustion?
Thanks for any help - I am a complete beginner with little experience - but wish to learn if anyone could be kind enough to point me in the right direction.
Cheers - Daily Oliver |
curtis4085 Samba Member
Posted: Fri Aug 07, 2015 5:03 pm Post subject: |
Don't waste your time or money on Germansupply. Get some Gatesbarricade, new fuel filter and a rubber grommet for any areas where a hose passes threw sheet metal. relocate the filter pre fuel pump and out of the engine bay. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
Posted: Fri Aug 07, 2015 5:58 pm Post subject: |
I think your mystery object is a transfer valve usually used with a dual tank system on trucks. In your case it may be being used as a fuel cutoff.
Yes relocate your fuel filter to before the pump. I like metal filters myself, you can probably screw a Ford style filter right into the inlet of your pump. |
Posted: Sat Aug 08, 2015 9:34 am Post subject: |
Thank you guys (curtis4085 & Wildthings) I will relocate the parts as mentioned and will buy some Gatesbarricade - thanks a lot - better safe than sorry.
The help is really appreciated - Daily Oliver (Sooke BC) |
Posted: Sat Aug 08, 2015 1:36 pm Post subject: |
curtis4085 wrote: |
Don't waste your time or money on Germansupply. Get some Gatesbarricade, new fuel filter and a rubber grommet for any areas where a hose passes threw sheet metal. relocate the filter pre fuel pump and out of the engine bay. |
I notice that Germansupply quotes 7mm for (1979 Westfalia 2000cc single carb engine) - do you know what the correct size (part # ref) Gatesbarricade to use?
Thanks again for your help.
DO |
Randy in Maine Samba Member
Posted: Sat Aug 08, 2015 4:59 pm Post subject: |
5/16" is as close as Gates gets. |
Yarkle Samba Member
Joined: August 03, 2009 Posts: 1218 Location: the Hills of Western Maine
