Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Mon Aug 10, 2015 8:29 am Post subject: |
Yarkle wrote: |
Randy, does anyone around us sell that gates hose? I need to do that as well, amongst the thousand other things. |
I get mine from O'Reilly.
**edit**
Just adding that you might want to ask nice and go back and look at the hose they have behind the counter. Roll of the dice if the counter person will know what you're talking about. _________________ 1976 Westy
1966 Beetle
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5778 Location: Los Alamos, New Mexico
Posted: Mon Aug 10, 2015 8:33 am Post subject: |
I found some 1/4" and 5/16" Barricade hose at our local NAPA. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
DougB Samba Member
Joined: January 09, 2007 Posts: 1076 Location: Falls Church, Virginia, USA
Posted: Mon Aug 10, 2015 8:59 am Post subject: |
Amazon stocks it, you just have to search by the Gates part number (usually a 5-digit code IIRC) as the Amazon product pages don't have specific details on ID or unit length. I've ordered 3 different Gates rolls via Amazon and everytime it was the right product. I bet JEGS has it, too.
- Doug _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
A very, very understanding wife |
Randy in Maine Samba Member
Posted: Mon Aug 10, 2015 9:24 am Post subject: |
Yarkle wrote: |
Yes you can get it at NAPA but you need to ask for it. |
Yarkle Samba Member
Joined: August 03, 2009 Posts: 1218 Location: the Hills of Western Maine
DougB Samba Member
Posted: Mon Aug 10, 2015 10:18 am Post subject: |
Mine is an FI bus and I believe I went with the 5/16" hose, as it was still a good fit on the fittings and injectors. IIRC it was too large for the Type 3 I got back on the road, also FI (though I know it's a different system). _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
Yarkle Samba Member
curtis4085 Samba Member
Posted: Mon Aug 10, 2015 10:28 am Post subject: |
If you want metric buy from belemetric.com _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
DougB Samba Member
Posted: Mon Aug 10, 2015 10:29 am Post subject: |
Yarkle wrote: |
my sons is a 69, so its carbureted, dunno if that makes a diff? |
Hmmm, best to wait for a more carb-knowledgeable person to chime in then. _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
Posted: Mon Aug 10, 2015 10:33 am Post subject: |
Yarkle,
I was thinking that the carbed 69 Sonsbus and Thing requires the 1/4" = 0.25" version. I was thinking that from the factory they were 5.5mm = 0.22".
Somebody will be along in a minute to confirm or refute that. |
Vee Dub Nut Samba Member
Joined: April 25, 2004 Posts: 1183 Location: Dallas, GA
Posted: Mon Aug 10, 2015 10:51 am Post subject: |
Going by memory, I'm pretty sure I used the 1/4" Gates barricade hose on my 68. I can confirm this afternoon when I get home if no one does before. _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut |
Smushy Samba Member
Joined: December 19, 2014 Posts: 91 Location: Ontario, Canada
Posted: Fri Aug 21, 2015 8:21 am Post subject: |
For 1971 1600DP/34Pic
Wondering if someone had a picture of the fuel line routing between tank and pump, especially into the engine compartment. My line has a filter after the tank, then comes through the left side engine seal/tin, seems like a bad place.
Also can I route a long fuel line between pump/carb to place a filter just above the left side engine seal/tin? It's currently very close to the engine. _________________ 1964 Type3 Notch
1971 Type2 Dormobile
1971 Type2 Westfalia
1973 Type2 Kombi
1977 Rabbit
1961 & 1964 Heilite Single Wheel |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5986 Location: Brooklyn
Posted: Fri Aug 21, 2015 9:24 am Post subject: |
Smushy wrote: |
Also can I route a long fuel line between pump/carb to place a filter just above the left side engine seal/tin? It's currently very close to the engine. |
Don't put a filter in the engine compartment. First, you already have a filter after the tank, so you don't need another filter. Second, the pump has a screen in it already. You want the filter before the pump to keep all the crap out of the pump.
Thirdly, the extra weight of a filter between pump and carb is thought to be a factor in the not terribly uncommon occurrence of the carb inlet pipe popping out of the carb and dumping gas all over the engine.
If I remember correctly, the area where the line comes through the tin should be a metal line with a grommet around it to keep the tin from chafing the metal line and eventually cutting through it. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Smushy Samba Member
Posted: Fri Aug 21, 2015 10:25 am Post subject: |
sjbartnik wrote: |
If I remember correctly, the area where the line comes through the tin should be a metal line with a grommet around it to keep the tin from chafing the metal line and eventually cutting through it. |
Thanks for the info, I'm going to remove the filter between the pump/carb, it's been on for a while and is still very clean. Do I have to change the screen in the pump ever?
I'll look for a groove for the pump line... but right now it's hanging loose through the engine tin and broken seals (I have new tin seals in the mail). _________________ 1964 Type3 Notch
1973 Type2 Kombi
1977 Rabbit
Posted: Fri Aug 21, 2015 10:56 am Post subject: |
Smushy wrote: |
sjbartnik wrote: |
I'll look for a groove for the pump line... but right now it's hanging loose through the engine tin and broken seals (I have new tin seals in the mail). |
You shouldn't have to change the screen in the pump if you have a filter before the pump. The filter element will trap smaller particles than the pump screen will.
For a temporary fix for your fuel line passing through the tin, you can find a piece of rubber hose that's big enough on the inside to go around the fuel line and small enough on the outside to fit through the hole in the tin, then cut a section of that hose, cut it open lengthwise so it's a C-shape, put it around the fuel line and slide it into the hole in the tin to act as a buffer between the tin and the hard line. _________________ 1965 Volkswagen 1500 Variant S
DougB Samba Member
Posted: Fri Aug 21, 2015 1:47 pm Post subject: |
Hello all,
So I know this isn't about the current hose discussion, but this does seem to be the place where people discuss fire prevention and suppression, so I thought I post about the Blazecut I just received.
Blazecut seems to be a bit more popular, discussion-wise, over in the Vanagon forums...and a good number of people seem to be running the 6' length. Just wanted to let folks considering the Blazecut know that, according to the instructions, the 12' version might be the better one given the engine compartment volume in our bays. The instructions say that, at 80 degrees C (fire temp?) that the gas contained in the 12' length will handle 1.34 cubic meters of engine bay volume (saturating the atmosphere with the sufficient percentage of chemical to suppress the fire). That seems about right...
...but the 6' version handles significantly less engine bay volume...so I'm just saying that the 6' length might not be enough.
Just wanted to post that for anyone considering it.
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2918 Location: Memphis
DougB Samba Member
Posted: Fri Aug 21, 2015 2:55 pm Post subject: |
Oh I know, expecting some link to a SoCal 6 o'clock news segment showing some bus engulfed in flames. Guess it's better that the thread is popping up so often because people are taking precautions _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
ewdb92 Samba Member
Joined: September 24, 2010 Posts: 502 Location: Plymouth, NH
Posted: Fri Aug 21, 2015 3:14 pm Post subject: |
DougB wrote: |
Oh I know, expecting some link to a SoCal 6 o'clock news segment showing some bus engulfed in flames. Guess it's better that the thread is popping up so often because people are taking precautions |
X2! I hate reading about burning VWs! _________________ Erik
71 Camper
http://zerotosixtyeventually.wordpress.com/ |
dailyoliver Samba Member
Posted: Sun Aug 30, 2015 8:02 pm Post subject: What items to relocate and where's best? |
Wildthings wrote: |
I think your mystery object is a transfer valve usually used with a dual tank system on trucks. In your case it may be being used as a fuel cutoff.
Yes relocate your fuel filter to before the pump. I like metal filters myself, you can probably screw a Ford style filter right into the inlet of your pump. |
Hi Guys, just to follow up on the advice you gave me. Thanks once again.
I now have some gates barricade and a new metal filter. At the minute in the engine bay I have [ pump > plastic filter > fuel (transfer) shut off valve wired to ign coil > carb].
You guys mention replace the lines - Ok cool with that.. Also to move the filter outside of enginer bay after tank but before pump - Ok cool with that as well.
HOWEVER confused with what to do with pump and fuel shut off, also the order they are in e.g. pump > shut off > carb
1. Should I leave pump inside the engine bay?
2. The fuel shut off is after the pump but before the carb - seller mentioned something about tank siphoning from carb onto the ground (eek )??
So what do I do about these two items pump/fuel shut off - leave them where they are, move just the fuel shut off before the pump but outside of engine bay? Heard about issues with fuel evaporating in the line and the ingitition having to stay on few mins to pressurize system again if shut off too far from pump?? Also where's the best place to move them to? Was thinking building a plate under back seat and mouting to that as underside is covered in wax oyl - difficult as fuel cut off unit grounds itself (no -ve wire only +ve).
Any simple advice - with pictures most appreciated as this is first bus I ever owned.
Cheers guys.
DO ( Sooke BC) |
