splitpartsunlimited Samba Member
Joined: January 18, 2006 Posts: 1251 Location: Good Ol`Buenos Aires, Argentina
Posted: Sat Dec 01, 2007 7:03 am Post subject: "L" part number headlight lense ..... |
i `ve heard that split era headlight lenses didn`t come with the "A" and "NL" markings on each side of the "HELLA" markings at the lower part of the lense ......
as far as i recall , a friend gave me a set of headlight lenses with the "A" and "NL" letters on it , but the lenses have the "L" and a 6 digit part number on the rim where you put the rubber to chrome ring......
so what`s the story besides this set of headlight lenses ?? split era with "A" and "NL" markings ??
anybody knows ??
thank you !!
Ricardo _________________ in my Garage:
1951 crotch cooler split
1971 1302 cabriolet
1981 Mercedes Benz 230 military "Gelandewagen"
2010 Mercedes Benz c200 kompressor touring |
buggen Samba Member
Posted: Sat Dec 01, 2007 1:35 pm Post subject: |
lenses are hella , not bosch _________________ in my Garage:
1971 1302 cabriolet
HeSa Samba Member
Joined: January 15, 2007 Posts: 466 Location: FINLAND
Posted: Sat Dec 01, 2007 2:06 pm Post subject: |
Here are some pics of early Hella headlights. Lipped lenses with VW logo at 18.00hrs and rings with hella logos in the same position. Reflectors are brass.
HeSa Samba Member
Posted: Sat Dec 01, 2007 2:39 pm Post subject: |
This is probably the following generation; VW logo at 18.00hrs no lip and note a very narrow ribbed area on top. Hella logo at 18.00 in the ring.
HeSa Samba Member
Posted: Sat Dec 01, 2007 3:01 pm Post subject: |
Here are some more Hella lenses all with VW logos at 1200.
1) snake - Hella - arrow
2) snake - Hella - made in Germany - arrow
3) snake - Hella - A and NL far left + made in Germany - arrow
4) big A and NL approval markings.
And there are plenty of other versions.
Posted: Sat Dec 01, 2007 4:33 pm Post subject: |
i have the "hella brand" , "vw" at 12 , "hella" , "A" and "NL" and the snake at 6 , "L" code and 6 numbers at 2 on the rim
is that correct for splits ?? _________________ in my Garage:
1971 1302 cabriolet
janerick3 Samba Member
Posted: Sat Dec 01, 2007 5:07 pm Post subject: |
The Hella part number is cast into the lip of the lens at the top. The sequential "dash number" (revision) is cast into the lip at the bottom. These numbers moved to the lower left side of the lens face in 1958 or 59. For Hella-VW sealed beam assemblies starting around the Zwitter era, the Hella part number is 25484, and went through some 26 revisions before this part number was superseded in the fall of 1963. _________________ Thanks,
Jan K. |
HeSa Samba Member
Posted: Sat Dec 01, 2007 5:19 pm Post subject: |
A = Austria and NL = Netherlands approval markings are good for somewhat post 55 ovals. There was also a phase when the lenses had only A approval markings. I have a pic of a pretty original looking Dutch 54 with Bosch headlights. The lenses have originally only an A approval marking and the NL with a Bosch part number has been etched? in the center of the lense (IŽd guess) by the importer. This would make A+NL lenses earliest 55 and/or later.
Edit:
buggen Samba Member
Posted: Sat Dec 01, 2007 5:26 pm Post subject: |
Libreriajenny wrote: |
is that correct for splits ?? |
The "A" and "NL" are not correct for split. |
HeSa Samba Member
Posted: Sat Dec 01, 2007 6:05 pm Post subject: |
To add to the confusion hereŽs another oddity. A symmetric Hella lense without A and NL markings found in a post oval semaphore bug with Belgian plates.
Posted: Sat Dec 01, 2007 6:06 pm Post subject: The "A" and "NL" are not correct for spl |
ok, so why the "L" and a 6 digit number are on the lip of the headlight lense ????? _________________ in my Garage:
1971 1302 cabriolet
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Sat Dec 01, 2007 6:46 pm Post subject: |
buggen wrote: |
Agreed...............My '53 has the VW at 6, no "A" or "NL"....... "Hella" logo at 12 and the word "oben" above the logo. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
HeSa Samba Member
Posted: Sat Dec 01, 2007 6:47 pm Post subject: |
HeSa wrote: |
Btw the date code of this Hella light is 43J which would make it 1951 to my understanding.
Posted: Sat Dec 01, 2007 6:56 pm Post subject: |
53 0val wrote: |
buggen wrote: |
Agreed...............My '53 has the VW at 6, no "A" or "NL"....... "Hella" logo at 12 and the word "oben" above the logo. |
forgot to mention; "Hella" on the ring at 6. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
HeSa Samba Member
Posted: Sat Dec 01, 2007 7:09 pm Post subject: |
53 0val wrote: |
buggen wrote: |
I thought all fluted lenses with both Hella and VW logos have Hella down and VW up. This is another variation added to the confusion... |
Posted: Sat Dec 01, 2007 7:45 pm Post subject: |
HeSa wrote: |
53 0val wrote: |
buggen wrote: |
Sorry for the confusion.............This is the Canadian non fluted lens for "sealed beams" as required upon export........... The fluted lens does have the logo at 12 as you pointed out. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
ProjectX Accessory Nut
Posted: Sat Dec 01, 2007 10:46 pm Post subject: |
My '53 oval matches what Bob said. BTW Bob, my original lens matches your description, do you have the infamous oval impression in the center of the lens or is it clear/smooth? My lenses are oben at 12 , then the Hella logo just under it. At 6 at the bottom is the VW logo, kind of thick?
It would be nice to know they are the same, then it's just the ring I need |
Posted: Sat Dec 01, 2007 10:53 pm Post subject: |
It has the "oval" impression and the number 25484 on the back edge of the glass. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Sat Dec 01, 2007 11:28 pm Post subject: |
More items to hunt
That's why we are sick I suppose, it's a love hate thing! |
