63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Fri Dec 07, 2007 9:40 pm Post subject: steering shaft question |
I am toying with the ideal of installing a quick disconnect system for my steering wheel. Does anyone know the shaft diameter and number of splines?
Thanks in advance |
uberautowerks Samba Member
Joined: October 17, 2005 Posts: 1600 Location: Longmont Co
Posted: Sat Dec 08, 2007 10:21 am Post subject: |
'73 or '74? The shafts are different. _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black) |
Posted: Sat Dec 08, 2007 11:14 am Post subject: steering shaft |
OK, my mistake
74.
also looking to add ujoints at steering box. looking for ujoints that will bolt on with correct splines at that point as well. |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Mon Dec 10, 2007 9:31 am Post subject: |
I don't know the diameter or number of splines, but VW only used two sizes for these older cars: "the larger diameter" and "the smaller diameter". The '73 uses "the smaller diameter" where as the '74 uses "the larger diameter". _________________ VW-181 shirts and stickers.
http://ian.epperson.com/vw |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Mon Dec 10, 2007 11:30 am Post subject: |
By the parts book the smaller shaft did not start till late 74. I have 2 74 cars with the large size produced in Jan. 74 and my July 74 car has the small size. It looks like the cars with the casted housing are early and the columns with the plastic covers are the late smaller size. |
Posted: Tue Dec 11, 2007 1:11 pm Post subject: |
Weird, both my '74's have the late bits! But I agree, the break is not at the year. _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
