kenkennedy Samba Member
Joined: April 13, 2004 Posts: 63 Location: Alberta, Canada
Posted: Sat Dec 08, 2007 6:25 pm Post subject: Left rear wheel locked up |
Car was parked overnight. Next morning the wheel was locked. I worked the emerg brake over a bit...rattled thru the gears a few times..started it up and put a bit of pressure on it in reverse and first....nothing worked. I jacked it up and was in the process of trying to bang the axle nut loose and the thing came free. I have just towed the car over 1000 miles and have been driving it around for a cuple of weeks. Only happened once. I have not yet found tools to get the nut off and have a look....any ideas?? |
74 Thing Samba Member
Posted: Sat Dec 08, 2007 7:48 pm Post subject: |
Yes, the brake shoes rusted/seized to the brake drum when your e-brake was on. Was it wet or raining or did you wash your car before parking and using the e-brake? Taping the drum with a mallet usually will free everything up. |
kuebelwagen84 Samba Member
Joined: March 15, 2007 Posts: 144 Location: Edison, NJ
Posted: Sat Dec 08, 2007 10:33 pm Post subject: Re: Left rear wheel locked up |
kenkennedy wrote: |
this will help you get the axle nut off, it makes everything significantly easier:
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D7036 _________________ // '73 Thing "Jeep Zerstörer" currently being restored / kustomized
// '07 Rabbit taking over daily driver duties
1600s of air-cooled German muscle! |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Sun Dec 09, 2007 4:24 am Post subject: |
That's why I park my car in gear and leave the parking brake off.
But then, I have a garage, so that's not a big deal. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Posted: Sun Dec 09, 2007 9:58 am Post subject: Thanks for the help |
Yes it was parked and it was damp and the brake was on for a couple of days.....I will still open the drum up and inspect the shoes and the drum...I was a bit worried that it might be in the trans.... |
Bruce Samba Member
Posted: Sun Dec 09, 2007 1:57 pm Post subject: |
Whenever this happens, NEVER use reverse to try to break it free. Reverse gear is really weak, you could break the teeth off the idler gear very easy by overloading it that way. _________________
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
