vwfye Samba Member
Posted: Sat Mar 16, 2013 10:05 am Post subject: |
Doh! I have a gallon on beriemann's. didn't even think of that... Thanks _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
vwfye Samba Member
Posted: Tue Apr 23, 2013 1:26 pm Post subject: |
Induction should be in my hot little hands by Monday at the latest. Now I just need to put a distributor back in it and rough time it before the induction arrives... This car deserves to be back on the street! Oh crap... need to pull the slicks off! _________________ 64 No'back Speedster "Pearl"
Type3Buddha Samba Member
Joined: March 11, 2013 Posts: 291 Location: Port Orford Or
Posted: Tue Apr 23, 2013 11:47 pm Post subject: |
Excited to see this running. |
vwfye Samba Member
Posted: Wed Apr 24, 2013 10:43 pm Post subject: |
Ok, apparently Wednesday they will be here. No worries... already set up for a 2332cc. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Mon Apr 29, 2013 8:16 am Post subject: |
Wednesday... the day my carbs are to come, and the day I will be blind for a day. I doubt I will get any work done! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sat May 11, 2013 9:12 pm Post subject: |
the notch is running, so now my attention will focus on the speedster.
carbs are set up and ready! fuel pump mounted! need to remount the breather box, mount the linkage for the carbs, replace the fuel soft lines and put some street tires under it. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sun May 26, 2013 10:26 pm Post subject: |
going to try and work a way to get more air to the carbs/fan... then get it buttoned up to drive to work on Saturday. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Fri Jun 07, 2013 10:55 am Post subject: |
I missed the Saturday goal as I had to pull that stupid shroud back off... I am reinstalling it and seeing if I fixed the issue. If not, I'll through a stock T1 shroud back on it so it can be driven. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sun Jun 16, 2013 1:13 am Post subject: |
Going to go with the German doghouse shroud for now. After getting back on the 24th, I will finish the carb re-re-install and put the seats back in... With that, I should be ready for Grafitti! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Wed Jun 26, 2013 9:02 pm Post subject: |
Today was finally back to the car(s)! Mostly the Pink topless car. I got all the stuff for the engine mounted (Carbs, distributor, fuel lines, oil breather, belt, fuel pump). And the DTM! Everything was ready, so I stole the riding mower battery (again) to see if it would at least crank and it did Thumbs Up I cranked until I saw oil pressure and could smell fuel and stopped. Then, I ran down to the FLAPS and picked up a battery and with a cheesy grin, I turned the key again with the coil hooked up and it jumped to life... sort of. It backfired hard through the muffler and then I saw it! I had the distributor installed with the traditional T3 location... but this is a type 1 engine! Spun it around and turned the key again tonight and it fired off without even hitting the pedal! I let out a whoop, turned off the key and shut the garage door tonight.
Tomorrow I will clean the multiple year's worth of dust/dirt off the car, time it, install the driver's seat again and then try and drive it back and forth on the parking pad to make sure I have brakes and gears. After that, I have to get the tags renewed (expired in 06) and then I'm ready for Graffiti Week here in Roseburg!
All in all, it was a great day! _________________ 64 No'back Speedster "Pearl"
Posted: Wed Jun 26, 2013 9:23 pm Post subject: |
Killer!!! Pumped for ya bud. |
vwfye Samba Member
Posted: Wed Jun 26, 2013 9:25 pm Post subject: |
I think I will get out the grinder to write "Wash Me" in the windshield grime. I'm not sure my finger can penetrate it! _________________ 64 No'back Speedster "Pearl"
Posted: Thu Jun 27, 2013 3:33 am Post subject: |
Just use orange juice or the Goo Be Gone orange smelling crap. That shit don't let anything stick you don't want on there. |
vwfye Samba Member
vwfye Samba Member
Posted: Tue Jul 02, 2013 10:49 am Post subject: |
Finally back home! I found the last bits for the car this morning and tonight after the sun goes down I will install them. Next up are new tags and insurance, then a shake down cruise! Finally I will have it up and running again in all its pink glory! :rofl: _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Tue Jul 02, 2013 10:36 pm Post subject: |
well running through the gears tonight, I snapped the shaft of the slave cylinder for the hydraulic clutch. So now I have to try and find in new one, before graffiti week starts. Oh the joy of custom things... _________________ 64 No'back Speedster "Pearl"
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Tue Jul 02, 2013 11:53 pm Post subject: |
vwfye wrote: |
well running through the gears tonight, I snapped the shaft of the slave cylinder for the hydraulic clutch. So now I have to try and find in new one, before graffiti week starts. Oh the joy of custom things... |
Dude.
You actually need a clutch to drive a stick shift? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vwfye Samba Member
Posted: Wed Jul 03, 2013 12:03 am Post subject: |
I have actually driven this car without the clutch. The clutch went out in the middle of Boise during rush hour traffic and I had to get home running through the gears with no clutch. That was no fun at all but it could be done. _________________ 64 No'back Speedster "Pearl"
Posted: Wed Jul 03, 2013 12:29 am Post subject: |
vwfye wrote: |
I have actually driven this car without the clutch. The clutch went out in the middle of Boise during rush hour traffic and I had to get home running through the gears with no clutch. That was no fun at all but it could be done. |
What exactly broke? The push rod? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vwfye Samba Member
Posted: Wed Jul 03, 2013 12:48 am Post subject: |
no, the mounting rod that screws into the base. It broke inside the base and I don't have my tools to fix it because I lent them out. _________________ 64 No'back Speedster "Pearl"
