vwfye Samba Member
Posted: Tue Sep 29, 2015 9:06 am Post subject: |
The engine cover is no pinned to prevent float. Shift light is installed, a big oil pressure idiot light is going in, the roll hoop will be replaced with a 6 point cage and other things will be done as well.
_________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
vwfye Samba Member
Posted: Sat Oct 17, 2015 3:02 pm Post subject: |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Sun Oct 18, 2015 5:22 pm Post subject: |
[quote="vwfye"]
I like it. Looks like you're almost done plumbing everything in place.
Is this still carbed? Or have you gotten the FI set up on? _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Sun Oct 18, 2015 9:06 pm Post subject: |
Blow through carbs. I still have to locate the water/methanol tank, the metering blocks, and the o2 sensor.
Also, I have to install the modified GM distributor with built in coil, mount the electric fuel pump, pressure regulator, gauges and design a new engine cover.
Then... new NHRA approved cage, belts, arm restraints, helmet and oil containment device.
I have until spring for all that to be done. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Tue Oct 20, 2015 1:04 pm Post subject: |
I am probaby most disappointed that I can no longer use the engine cover John Jaranson designed and built for the car. It was exactly what I had wanted.
I have the old cover in the shop that I will turn into a template to see how much I have to cut away and reshape to fit over the turbo and BOV. From there, I'll be able to see if the c/f cover can be modified or if I have to start from scratch. _________________ 64 No'back Speedster "Pearl"
Nate M. Samba Member
Joined: August 11, 2003 Posts: 1306 Location: Anacortes, WA U.S.A.
Posted: Tue Oct 20, 2015 3:18 pm Post subject: |
vwfye wrote: |
I have the old cover in the shop that I will turn into a template to see how much I have to cut away and reshape to fit over the turbo and BOV. From there, I'll be able to see if the c/f cover can be modified or if I have to start from scratch. |
Why not change the header to one of these:
http://www.cbperformance.com/ProductDetails.asp?ProductCode=7301T
That's cheap for a header and will preposition the turbo down low. Then re-do the piping so the BOV is out of the way. With some planning, not much $$$ and a bit of welding, you could get all that to not much taller than the shroud.
Then you can use that super cool cover. . . Just a different idea. . . _________________ Regards,
Nate M.
Squarsche build
Heavy Metal Affliction feature
For heaven's sake, put a type4 and a Porsche 5-speed in there. . . It's the right thing to do!! |
vwfye Samba Member
Posted: Tue Oct 20, 2015 3:31 pm Post subject: |
A) it won't fit my space-- hard blockage down there to the cab.
B) already have the over the alternator header in ceramic coat.
3) I didn't know before I got the header that it was going to stick up that high... _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Fri Nov 13, 2015 9:27 am Post subject: Re: Mid engine Notch Speedster getting more updates... |
I'm going to take a look at a complete re-route of the turbo plumbing to minimize what sticks out too high. I'm not confined to everything fitting between the shroud and the header... Sometimes I forget that. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Mon Jun 13, 2016 2:29 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Did not like the turbo placement verses the engine cover, so it is back out, for now.
Had to put the old mid-engine header back in. What a PITB! That puzzle was a mess, but the header is back in. Now I still need to hang the muffler/4-1 collector and reroute some oil lines. Then... Fire again and drive for the summer. _________________ 64 No'back Speedster "Pearl"
Posted: Sun Jun 19, 2016 10:36 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
vwfye wrote: |
Had to put the old mid-engine header back in. What a PITB! That puzzle was a mess, but the header is back in. Now I still need to hang the muffler/4-1 collector and reroute some oil lines. Then... Fire again and drive for the summer. |
Have you gotten that 13 inches of pan cut out yet? You know John's gonna be out there soon enough. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Mon Jul 04, 2016 7:25 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Well, just ordered paint for the car. The end of an era is near. _________________ 64 No'back Speedster "Pearl"
Posted: Mon Jul 04, 2016 9:04 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
vwfye wrote: |
Well, just ordered paint for the car. The end of an era is near. |
So, Gulf Blue and Orange will be it's new colors? Still didn't answer my other question. Did you get that 13 inches cut out of the pan? Or are you waiting for John to do it? _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Mon Jul 04, 2016 9:05 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
What pan? For the 356? It only needs 4.5 cut out _________________ 64 No'back Speedster "Pearl"
Posted: Mon Jul 04, 2016 9:11 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
vwfye wrote: |
What pan? For the 356? It only needs 4.5 cut out |
Yes, the 356. Sorry, Rob told me it was 13 inches that needed to be removed, not 4.5 inches. Still, that's quite a bit of work to preform just to get it ready for the body to sit on it correctly. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Mon Jul 04, 2016 9:29 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Should be ready by the end of July to try and sit the body on... _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Thu Jul 14, 2016 4:14 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
One of two possible new colors...
vwfye Samba Member
Posted: Thu Jul 14, 2016 4:20 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Or...
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Thu Jul 14, 2016 5:16 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
I vote for the blue. The charcoal grey is a little bit plain for a car of that stature. _________________ I think he meant "rare", as in "not well-done" |
Posted: Fri Jul 15, 2016 11:52 am Post subject: Re: Mid engine Notch Speedster getting more updates... |
eyetzr wrote: |
I vote for the blue. The charcoal grey is a little bit plain for a car of that stature. |
Agreed. The blue with some orange stripes will look great on it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Fri Jul 15, 2016 12:17 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
No Stripes. I'm trying to Mellow the lookout. _________________ 64 No'back Speedster "Pearl"
