EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
curtis4085 Samba Member
Posted: Sun Oct 12, 2014 9:47 pm Post subject: |
EverettB wrote: |
No, yours is loose. |
Thank you for the reply Everett. Do you know if this cover being loose could cause a vacuum leak? I do not see a seal on it just some crimped areas at the base.
Any possible ideas for a fix? _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
Posted: Sun Oct 12, 2014 9:58 pm Post subject: |
curtis4085 wrote: |
Do you know if this cover being loose could cause a vacuum leak? Any possible ideas for a fix? |
That is something I wondered myself as I have a few that are loose and I had not noticed any sort of seal either. I feel like it would suck a little extra air in, leaning out the mixture, but the actual valve itself is a pretty tight fit in there so as long as all those parts are there maybe it's minimal.
I haven't tried to fix one myself but I have one where the rivets were replaced by screws. It's really poor work though - they just screwed in some small sheet-metal type screws. I think tapping it for actual threaded metal screws would work fine with some locktite or small lock washers.
Or maybe you can just tap the rivets tighter? _________________ How to Post Photos
Posted: Sun Oct 12, 2014 10:20 pm Post subject: |
Quote: |
Or maybe you can just tap the rivets tighter? |
Maybe I will try this to see if it helps.
I'm curious for those that have governors currently in service if they have experienced vacuum leaks due to this cover being loose. _________________ Special Thanks to:
Posted: Thu Oct 16, 2014 6:01 am Post subject: |
curtis4085 wrote: |
I'm curious for those that have governors currently in service if they have experienced vacuum leaks due to this cover being loose. |
Just to update. I did take a cooper drift to the pins/rivets on the side cap on governor at a attempt to fix how loose the cap felt, worked great. Feels nice and right now!
Thank you Everett for the suggested fix! _________________ Special Thanks to:
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Wed Mar 11, 2015 1:02 am Post subject: |
Here is a recently acquired poster that likely hung on a dealership wall at some time. It is dated 1956, slightly before these became available as the M 178 option. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Wed Mar 11, 2015 8:27 am Post subject: |
That looks to be rotational rather than vacuum. I wonder where it came into play. |
Schwing Samba Member
Joined: May 10, 2009 Posts: 2506 Location: Centreville, MD
Posted: Wed Mar 11, 2015 4:22 pm Post subject: |
You know, I didn't really take a good hard look at it. The left hand side doesn't look real familiar while the right hand side does look a lot like the speed governor that we all know and some of us love.
I'm reasonably sure that it isn't connected to the distributor directly. _________________ Roads Scholar &
BarryL Samba Member
Posted: Thu Mar 12, 2015 8:17 am Post subject: |
The output is on a shaft of the apostrophe. Technically, it could have been mounted in series with the generator/pulley and controlled the throttle with that output shaft. Don't know why it would have a bulletproof seal, though. |
Zundfolge1432 Samba Member
Posted: Tue Aug 30, 2016 4:20 pm Post subject: |
Zundfolge1432 wrote: |
Eaallred wrote: |
Half the time I can't get past the semi's because of the air coming off the front end of them. Getting past them pretty good until I hit that wall of air coming off the front of them, LOL. |
Hey I like these too and felt left out as everyone around here just looks at me like I'm crazy .... Most of them went in the S can a long time ago...... I put one back on when I did my resto of a 67 deluxe and I got 2 more govs but I need the long studs for the carb.... They are about 2 & 1/2 inchs long and I cant find them anywhere.... As you know VW studs have rolled threads ....
My question who has these or where can replacement stock be found now? Hey anyone wanting a factory look? I got lead seals and can safety the screw heads using .030 stainless wire or give you a good how to ... PM me I'd be interested in buying the studs if anyone has them .. |
I was given one of these for free last Saturday,and I found a source for the studs. Ace hardware sells metric all thread in size 8x1.25. It would work for this and other low torque applications.
In the second photo you'll notice I've installed new safety wire, actually a stainless .040 which will never corrode or discolor. |
Posted: Sun Sep 04, 2016 1:53 am Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
Back in the day you could buy a kit from the dealer that had the lead, wire and little VW stamp for your governor installation. I remember seeing it listed in a technical bulletin some time ago. I would suspect that the MSM is a company abbreviation. _________________ Roads Scholar &
Posted: Tue Sep 06, 2016 5:31 am Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
Here's an early governor mounted to a 36 hp. This was not a factory application. They were actually made in Michigan USA. Internally they look just like the APG governor.
lightice Samba Member
Posted: Tue Sep 06, 2016 6:24 am Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
Will a govenor fit an alternator equipped engine?
It does look to be quite flush to the generator.
Also, with it installed, how much higher does your carb sit?
Any issues with the air cleaner elbow? |
Posted: Tue Sep 06, 2016 1:04 pm Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
All of your questions are answered on the first few pages of this thread- it's a good read.
I know that the Handy governor will not fit with an alternator installed. It would look kinda funny IMO for a 1920's-30's device to rest next to a 1970's device at least for VW.
There will be air filter fitment issues with the stock intake manifold, that's why there were special short neck manifolds available for the bus. _________________ Roads Scholar &
Posted: Fri Sep 23, 2016 5:16 pm Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
finally came across an apparently, very rare 40 hp bus governor. It still has the twisted lock wire and lead seals in place.
Dealerships had sealing kits for sale over the counter that included the wire, some lead for sealing the lock wire and a tool to form the hot lead into a round seal. Some of the seals have a VW stamped into them and others have initials. This one is blank.
How can you tell it's a 40 hp governor? Visually and internally they are the same as the 1500 governors. The later governors have the nuimbers 1,5 (1500 cc ?) stamped into the aluminum cover. The 40 hp governors are blank where this stamping should be. The other indicator is the manufacturing date stamp. This one is stamped 072 which translates to July 1962.
note the long studs with the acorn nuts for mounting to the intake manifold. These also came with a steel spacer but I have found they tend to create vacuum leaks. Not sure why they are necessary. _________________ Roads Scholar &
EeVeeWee Samba Member
Joined: April 02, 2015 Posts: 836 Location: Amersfoort, Netherlands
Posted: Sat Sep 24, 2016 12:14 am Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* |
I have this one at home, so if someone might be interested....
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Sat Dec 17, 2016 2:22 pm Post subject: |
tasb wrote: |
Here is a recently acquired poster that likely hung on a dealership wall at some time. It is dated 1956, slightly before these became available as the M 178 option. |
It's an industrial governor (seen between crank/gen pulleys)... this is a 1958 photo: (rear face of governor matches the right side of diagram, above)
PS: get a load of those hats
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Sat Dec 17, 2016 3:04 pm Post subject: |
easy e wrote: |
Very cool! Got one of those hats and did not know that they were that early. It might have come out of the Buffalo NY dealership that was closed about 1960 due to conflict between dealership owner and VOA. Bill D. bought out the entire contents back in the early 1990s. _________________ In Stereo, Where Available! |
