khalimadeath Samba Member
Posted: Sat Sep 20, 2014 2:12 pm Post subject: |
Stuartzickefoose wrote: |
talked to nate at wagens west, he said that the horse drop plates wont lift the bus, they like to fold to easily....but he has a lift plate designed that run about 350 a pair. ill post pics when he sends then to me. |
Keep us posted! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Sat Sep 20, 2014 3:22 pm Post subject: |
Kirk wrote: |
I love it more than my fancy late model westy I owned. I can take this anywhere and not worry. |
That right there is the reason to live. _________________ nothing |
Brian Samba Moderator
Posted: Mon Sep 29, 2014 9:53 pm Post subject: |
Cursing through old threads and found a Jersey looker
I dig the fender flare
_________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Mon Sep 29, 2014 9:54 pm Post subject: |
that rack! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
sxuxrxf Samba Member
Joined: May 18, 2005 Posts: 1338 Location: Oceanside, CA
Posted: Tue Sep 30, 2014 9:51 pm Post subject: |
Brian, the white Bus was at B&R Buggies for a while. Gary was doing some engine work on in. Owner must have had stock in Alcoa, cuz everything was aluminum. Even a full custom off-road style dash. I think it was a Chevy engine? _________________ (ignore the X's ) |
Posted: Tue Sep 30, 2014 10:00 pm Post subject: |
Niceee. I was over there last week, wish I could have seen it. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
RetroHäschtäk Samba Member
Joined: October 25, 2014 Posts: 7 Location: Deutschland
Posted: Sat Oct 25, 2014 12:27 pm Post subject: From Germany with no facts |
Hey all you Baywindow Driver..
i located in the west of germany.
A while ago i have my 77 Bay restored to the specifications which was always seen on meetings, lower..............
But now a few Years later i will do more trips with my little son. Funny Thing is he is not really a fan from all the great meetings such Spa Bug Show and other.
But he ask me more and more to do trips in to the wilderness and go camping, to mountains ....
Means our Bus needs a little upgrade. First we had the idea to sale the "BODO" and buy a Syncro T3 Vanagon. But these are in the meanwhile much to expensive here in germany, if ou need this in camper specifications. And by the way our son was crying if he heard that our Bus should sale to another person
So the idea, we lift our bus and now we are searching for information, because here in germany nobody does lift a T2 up everbody drop it down lower and lower and lower.. not so good for driving dirt tracks in the wilderness
Are the following facts are right ? we need:
1. Raised one outer spline in the rear / Did we need other CV or longer Driveshafts like the bus from "newboy113" ? ( the red one )
2. adjusters welded in the front beam / In which position ?
3. Gas Shocks / Which manufacture did you use ?
4. has anybody pics of his raised bus from under the car ? this would be very helpful to see details of the Adjusters ...
We are thankful for all helps and information
Withe best regards from germany and sorry for our bad explanations and bad english
Maarten _________________ ".....roadracing since 1988" |
Mr. Unpopular Samba Member
Joined: September 20, 2005 Posts: 3715 Location: Tampa Florida
Posted: Sat Oct 25, 2014 12:40 pm Post subject: |
You really don't need to do much if you just want to do some light off-road driving (dirt roads, shallow mud, etc).
This is my friend Jason's bus. It's totally stock suspension, CV's, axles, etc. He is just running the cheap EMPI coilover shocks on the front to pick the nose up a bit.
He's running VW Jetta 15" steel wheels and General Grabber tires (215/75 I think).
It is a good look, cheap, and does well in light off-roading. _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV |
Posted: Sat Oct 25, 2014 12:41 pm Post subject: my bus |
sorry to upload a pic from the gallery to my post is not possible.
The copy function with my imac does not work with the adress from the gallery.
But there you can see it _________________ ".....roadracing since 1988" |
Tcash Samba Member
Posted: Sat Oct 25, 2014 12:56 pm Post subject: |
Posted: Sat Oct 25, 2014 7:46 pm Post subject: |
Keith wrote: |
Brian wrote: |
Look here: http://www.rockauto.com/catalog/moreinfo.php?pk=3854481
It is cheaper to buy complete axle assemblies than individual CVs. But I was just reading too, as expected, bus axles are longer by a good amount than 944/181 axles. So, T4 on bus axles. But if there is too much lift, I think you can use axles meant for bugs using 3x3 arms. Those axles have a length of 19 and a 1/4. They all have the same amount of splines, so CVs are interchangeable (unless they're 930s) |
It's always cheaper to buy complete axles.
I figured I would go buy thing axles and then just swap everything to the bus axle shafts. If needed, I would go get longer axle shafts but I doubt it. I just want a slight lift with suspension and then a slight lift with tires, nothing crazy. |
so if im rightly understanding this, if i buy this linked axles, the joints should fit on my stock axles, and fit into my bus and give my the extra angle possibility? right? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
MadMax78 Samba Member
Joined: May 26, 2007 Posts: 511 Location: The Netherlands
Posted: Sun Oct 26, 2014 7:09 am Post subject: |
Brian wrote: |
This bus belongs to forum member Bursch
In that picture we're actually running front tyres that are too small. You can see that the ones in the back are larger, which makes the nose dip down somewhat.
We had the larger tyre lock up in the wheel well (on landing from a huge jump) and bend the entire front suspension. We had to fit a smaller tyre to fix the problem with the tyre rub.
On our last trip the front suspension leafs snapped again. So we're now probably going to ditch our bull bar with spare tyre setup. We want to switch to a lightbar setup like Kirk has. Really like the look of it! Probably going to stow the spare tyre on the roof where the spare fuel tanks are now. This will significantly reduce the weight that is dangling in front of the front axle.
First step is to fabricate spare fuel tanks which can fit on either side of the frame rails so we free up some space on the roof. _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply , Busted Bus, Aircooled Technology & DIYAutoTune
2008: Amsterdam - Beijing - Olympics -- 17.500km
2010: Amsterdam - Cape Town - FIFA World Cup -- 26.000km
2014: New York - Rio de Janeiro - FIFA World Cup -- 27.000km
http://www.oranjetrophy.nl
Camper Special Club Member |
Posted: Sun Oct 26, 2014 8:39 am Post subject: |
Madmax, will you ever be running an LED light bar? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sun Oct 26, 2014 12:38 pm Post subject: |
Madmax, will you ever be running an LED light bar? |
We're actually thinking about that as well. We are now running into the problem that the alternator can hardly cope with nighttime driving with all the lights on. So we're considering swapping the headlights out for full LED units (GE Nighthawk), also might fit lightbars from Lazer.
http://www.lazerlamps.com/
So not entirely sure on what we'll do yet. But first thing is we need to ditch the halogen, both the headlights and the two halogen lightforce units we have.
Might move the HID lightforce units to the bumper and fit one or two LED bars to the roof. But first need to do some photoshopping to get an idea of how it will look. Could also keep the lights on the roof and install a bar on the bumper. _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Posted: Sun Oct 26, 2014 12:51 pm Post subject: |
Look up das mule in seattle, and give thier vanagon a lookover...they have some absolutely insane light options ....worth a phone call! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
MonkeySee Samba Member
Posted: Tue Oct 28, 2014 6:38 pm Post subject: |
$270 for headlights? Nope. _________________ nothing |
