Lynn Gleason Samba Member
Joined: August 17, 2011 Posts: 109 Location: Port Townsend, WA
Posted: Tue Jan 27, 2015 9:48 pm Post subject: |
DethSpork,
I usually run mine at 50 front/55 rear, around town, and 55 front/60 rear, when fully loaded up for camping. I`ve got a `79 HighTop, and these pressures REALLY help the handling, especially in wind.
I`ve also optimized the suspension: KYB (White) shocks all around, tightened steering box for no play, front & rear sway bars, new ball joints, new steering damper, new tie rods ends, etc. My bus gets used a lot, and handles GREAT, with no surprises! It also helps a lot, to drive it WELL within its capabilities---when it`s windy---SLOW DOWN!
Hope this helps,
Lynn Gleason
`98 Golf
`79 AdventureWagen HighTop Camper
`69 Porsche 912 Targa |
martinvcp25 Samba Member
Joined: October 12, 2014 Posts: 7 Location: Cordoba, Argentina
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Sun Feb 01, 2015 11:29 am Post subject: |
Dang. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22461 Location: Escondido CA
Mexicant Samba Member
Joined: December 31, 2010 Posts: 99 Location: Colorado
Posted: Mon Feb 02, 2015 12:27 am Post subject: |
So much inspiration from this thread! |
ejb111 Samba Member
Posted: Sat Feb 14, 2015 8:14 am Post subject: Lifting my 69 Camper |
Are you sure the size of your tires are 225/85-14? I called all around and could not find them. |
Brian Samba Moderator
Posted: Sat Feb 14, 2015 10:53 am Post subject: |
Largest 14" tires I found available are 225/70-14 and 27x8.5-14 _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Sat Feb 14, 2015 1:23 pm Post subject: Re: Lifting my 69 Camper |
ejb111 wrote: |
He is in Argentina. Quite likely that his selection of tires is different than ours.
BTW, the 85 in the tire size is often left out, so the size would be listed as 225R14. _________________ nothing |
Posted: Sat Feb 14, 2015 1:31 pm Post subject: |
I wonder what the different selections are like around the world. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
levi20AE Samba Member
Joined: June 24, 2005 Posts: 485 Location: Las Vegas, NV
Posted: Sun Feb 15, 2015 9:22 pm Post subject: |
We decided to take a last minute trip up to the mountains in Utah last weekend. We were only a few hundred feet up the road from where the plows stopped running and about .8 of a mile short of our intended campsite. A few days of above freezing temps and the road turned from hard packed ice to hard pack with areas where the ice had melted away underneath. After breaking though a surface layer of ice we ending up with the engine and trans supporting the rear end of the bus, tires hanging hopelessly. After and hour of diging in the dark and help from the hilift jack and maxtrax we were able to get out and ramp up onto the ice layer. Now I'm sold on maxtrax. Long story short after a lot of digging and repeated use of the trax we were able to back out and get to solid ground.
After this adventure i bought another pair of maxtrax and mounting pins and a few other bits to build a mount for the trax off the rain gutters and westy rack.
The good folks at GoWesty also agreed to sell me a vanagon rear bumper before powder coat at a discounted rate. So after some modifications to the overall width and fabricating new brackets I will have a place to store the spare tire out back and hopefully the jack and whatever else can be mounted up.
I'll get pics up once things start coming together. _________________ 1973 Campmobile http://www.thesamba.com/vw/forum/viewtopic.php?t=524511&postdays=0&postorder=asc&start=0
20th AE VW GTI - 369hp 340tq @ 26 PSI
1982 Rabbit Pickup - German AAZ 1.9TD - daily with lots of MPGs |
Posted: Sun Feb 15, 2015 11:36 pm Post subject: |
I wanna see that rear bumper, im starting the hunt to design my front and rear .... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Mon Feb 16, 2015 1:49 am Post subject: |
Where did you get your maxtrax? I really want a set.
Also I was thinking about it today; a really good mod you can do that's super simple is to get some piping that has a slightly larger OD than your tie rods and weld them on. Helps if you're going rock crawling and smacking around your front tires. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Mon Feb 16, 2015 6:47 am Post subject: |
To keep from bending the tie rods? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Mon Feb 16, 2015 7:04 am Post subject: |
exactly. Common thing to do with buggies is to take off the sway bar and use that tubing to reinforce the tie rods. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Tue Feb 17, 2015 4:39 pm Post subject: |
Here you go, easiest mod you can do.
~14 inches of pipe cut and welded to the tie rods.
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Tcash Samba Member
Posted: Tue Feb 17, 2015 6:48 pm Post subject: |
Hey Brian
Maybe drill some holes and do some plug welds along its length to marry the two pieces together.
Just a thought
Tcash |
Posted: Tue Feb 17, 2015 7:05 pm Post subject: |
I was thinking about doing that. The pipe I got had a pretty big ID and there is a good amount of space between it and the OD of the tire rod tube. But even currently, if I get a hard jounce the energy will dissipate through the larger tube. If my welds were good, else it's just going to split where I weled it. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
PEITRUS Samba Member
Joined: February 24, 2011 Posts: 59 Location: Redlands, CA
Posted: Thu Feb 19, 2015 8:17 am Post subject: |
This thread is awesome! I've gone through it at least three times. Makes me want to get lifted spindles adjust my beam and flip my drop plates! The high life looks way more fun than the low life. _________________ SlowSpeed | Meatwagon |
Posted: Fri Feb 20, 2015 1:29 am Post subject: |
PEITRUS wrote: |
This thread is awesome! I've gone through it at least three times. Makes me want to get lifted spindles adjust my beam and flip my drop plates! The high life looks way more fun than the low life. |
Get a lift, the fun ones can jump. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
77VWBusDude Samba Member
Posted: Fri Feb 20, 2015 3:40 am Post subject: |
Reminds me of a Dachshund
_________________ '77 Bus auto EFI(stock)
WendyArmbuster wrote: |
Oh man, I had forgotten the smell of a running bus. Sort of like a combination of old things and burning dust. Smells like... victory. |
