khalimadeath Samba Member
Brian Samba Moderator
Posted: Fri Jun 19, 2015 9:04 pm Post subject: |
Short answer; no. Long awnser; nope.
I think a few places are making some t2 plates though. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Mon Jun 22, 2015 4:38 pm Post subject: |
I've asked this about a thousand times, but one more won't hurt:
What is the maximum diameter tire that I can stuff into the wheel wells, maintaining full travel, and without rubbing? I'm willing to change wheel size from the hard to find 14", but I insist on the C Rated (or equivalent) tires. Less interested in off road than max diameter for best ratio change. What is max diameter?
M _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
Nepenthe88 Samba Member
Joined: September 03, 2010 Posts: 1320 Location: Colorado
Posted: Mon Jun 22, 2015 7:14 pm Post subject: |
webwalker wrote: |
M |
I'm running 215 70R16 Yokohama Geolandars. The tire is 28" in diameter and mounted on a 7" wide rim with 5/8" spacers from T3 technique. I get a slight rub, but only when turning and at full bump. I know that's not the answer you're looking for, but ANYTHING smaller than that will fit without rubbing. In fact, My rub is so slight that I can't even tell WHERE it's rubbing. I don't actually see any evidence of rubbed off paint... yet _________________ a Black & Blue Su-BUS-aroo
Follow my adventures in the GoWAND'RLoST bus on Instagram:
https://www.instagram.com/gowandrlost/ |
Posted: Mon Jun 22, 2015 7:15 pm Post subject: |
235/75-15 is what I think will work well with stock _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
newboy113 Samba Member
Joined: August 03, 2008 Posts: 34 Location: Hastings East sussex
Posted: Sun Jun 28, 2015 3:50 pm Post subject: |
Brian wrote: |
235/75-15 is what I think will work well with stock |
Im running Wagonwest lift spindles and rear plates on my bus and I Couldn't squeeze 235's on. Rubbed out massively on the front on the doglegs and just rubbed on the rear arches. Obviously it deends on wheel off set. But the wagonwest kit does widen the track about 20mm on each corner. I'm currently running 215 75 15 BFG AT's and just getting away with a little rub on the front every now and then. Need more lift!! |
Posted: Sun Jun 28, 2015 6:23 pm Post subject: |
I have the 215s on a saggy front beam, no lift and I have 0 rub. I'm using some 66/67 beetle wheels though. I have some 0 offset wheels coming though, so lets see how that works out
But yea, up front I would love to see some 7-15s used. That would make for some fuel efficient buses. Even stock. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Sun Jun 28, 2015 8:45 pm Post subject: |
Nepenthe88 wrote: |
webwalker wrote: |
M |
I'm running 215 70R16 Yokohama Geolandars. The tire is 28" in diameter and mounted on a 7" wide rim with 5/8" spacers from T3 technique. I get a slight rub, but only when turning and at full bump. I know that's not the answer you're looking for, but ANYTHING smaller than that will fit without rubbing. In fact, My rub is so slight that I can't even tell WHERE it's rubbing. I don't actually see any evidence of rubbed off paint... yet |
It's the closes 'worked solution' yet. I'm willing to go up to 15" for a better select of tires, but I'm looking for the best on-road tire of the largest diameter that will fit. So far the best I've been able to generalize is to keep the total diameter under 28" regardless of the wheel size.
Posted: Mon Jul 06, 2015 5:36 am Post subject: |
Managed to get out and about this weekend. My bus has a new friend.
levi20AE Samba Member
Joined: June 24, 2005 Posts: 485 Location: Las Vegas, NV
Posted: Mon Jul 06, 2015 5:47 pm Post subject: |
Has anyone found a source for new rear torsion tubes or experience in increased spring rate performance? After raising it three notches the a few trips off road and a week of camping has got the rear almost back to where I started. This bus started out as a westy but came with the smaller bars for whatever reason and after 40 years they don't have much spring left. I would like to try the larger factory bars but figure any I find at the wrecker have as much use as the ones I'm using now. _________________ 1973 Campmobile http://www.thesamba.com/vw/forum/viewtopic.php?t=524511&postdays=0&postorder=asc&start=0
20th AE VW GTI - 369hp 340tq @ 26 PSI
1982 Rabbit Pickup - German AAZ 1.9TD - daily with lots of MPGs |
Posted: Mon Jul 06, 2015 8:49 pm Post subject: |
Contact sway-a-way. or look for some truck ones.
Also newboy, that looks way rad! _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Mon Jul 06, 2015 9:03 pm Post subject: |
Pretty sure the Bentley manual descriptions of which diameter bars went into which bus have been disproven many times over. Just gotta look at the bars themselves, not the bus from which they came. _________________ nothing |
Posted: Mon Jul 06, 2015 9:12 pm Post subject: |
I believe that. I'd still look into swayaway though. They make bug bars, and early bus bars. not sure about newer buses though. I'm sure it wouldn't be too hard for someone to engineer. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
c3sar3 Samba Member
Posted: Thu Aug 13, 2015 2:24 pm Post subject: |
hi to everyone ...
mercedes 15" x 6,5 et 30 can fit ? now i have 1" x 6 et 37 and i don't have any problem |
Posted: Thu Aug 13, 2015 2:35 pm Post subject: |
btw, got my spindles (finally) and the new wheel setup. Had a ton of fun in the sand dunes. Also mounted an LED bar
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
c3sar3 Samba Member
Posted: Thu Aug 13, 2015 3:02 pm Post subject: |
Brian wrote: |
Probably, what tire are you planning on using? |
195\75\15 |
Posted: Thu Aug 13, 2015 3:51 pm Post subject: |
They might work. But I think more than likely it will. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
notchboy Samba Member
Joined: April 27, 2002 Posts: 22448 Location: Escondido CA
