david_594 Samba Member
Joined: November 08, 2006 Posts: 484 Location: Columbus, OH
Posted: Sun Dec 30, 2007 12:23 pm Post subject: Seal/Gasket between cluster and dash? |
Just wondering if anyone knows if this is available anywhere? I am talking about the thin rubber seal that goes in a small groove around the back edge of the cluster. Mine is in about 100 pieces and I would kind of like to find an intact one. _________________ 1968 westy weekender
2000 jetta tdi
79 vespa p200e |
JonnyPhenomenon Samba Member
Joined: November 03, 2009 Posts: 11 Location: Lewiston, Maine, USA, Earth
Posted: Sun Dec 20, 2009 4:40 pm Post subject: Re: Seal/Gasket between cluster and dash? |
david_594 wrote: |
Just wondering if anyone knows if this is available anywhere? I am talking about the thin rubber seal that goes in a small groove around the back edge of the cluster. Mine is in about 100 pieces and I would kind of like to find an intact one. |
I know this post is two years old, but I want to know the same thing. I just restored my instument cluster, and need one of these gaskets. I might just fab something of my own, but if the part is still available then I might just buy it.
looking hrough vagcat I cant find anything about the instrument cluster at all. |
SGKent Samba Member
Posted: Sun Dec 20, 2009 5:48 pm Post subject: |
it must be early buses because the 1977 and 1978 didn't have it. Could you get bulk o-ring from the auto store and use that? Some places sell the o-ring material in a spool and one can cut it to any length. A model airplane shop might have rubber hose that could be cut and used too. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
pwilson Samba Member
Joined: August 08, 2007 Posts: 252 Location: Lake Charles, LA
Posted: Sun Dec 20, 2009 6:59 pm Post subject: |
I have one on my '77. It looks more 'L' shaped than round. I have not seen the seal anywhere, not that I have really looked.
Phil _________________ Useless laws weaken necessary laws. -- Charles de Secondat |
Posted: Sun Dec 20, 2009 9:12 pm Post subject: |
it was molded to fit in the groove on the back of the cluster bezel. My guess it that it was put there to keep the cluster from rattling or squeaking from vibration. the rubber hose is a good idea. Im sure I could just fab something up. |
SandClemente Samba Member
Joined: June 19, 2006 Posts: 27 Location: San Clemente, CA
Posted: Thu Jul 24, 2014 4:37 pm Post subject: Instrument cluster gasket 69-71 bus |
The round piece of rubber that holds window screens into the frame, same on screen sliding doors comes in various diameters. I am trying it now. |
Posted: Thu Jul 24, 2014 4:38 pm Post subject: Instrument cluster gasket 69-71 bus |
SGKent Samba Member
Posted: Thu Jul 24, 2014 7:32 pm Post subject: |
used - Ken at Busco found one for me a year or so ago. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
hometurbine Samba Member
Joined: November 30, 2014 Posts: 157 Location: Cincinnati
Posted: Sat Feb 02, 2019 6:03 am Post subject: Re: Seal/Gasket between cluster and dash? |
Hello,
I'm also looking for the instrument cluster to dash seal (L-shaped) for my '75. Looks like there are some European suppliers (one shown). Does anyone know the P/N or if there is a US-based source? If not, I'll ask Ken at BusCo....
Thanks _________________ Bill
'75 Westy Bus with Subaru EJ25 engine
GE CT58-100 helicopter gas turbine
Tiernay TT10 APU gas turbine |
bigdaveb Samba Member
Posted: Sat Feb 02, 2019 6:46 am Post subject: Re: Seal/Gasket between cluster and dash? |
Try Buslab.com:
https://www.buslab.com/product-p/ok64659.htm
They are Bus-OK's partner in the U.S. located in California, from what I understand.
Hope this helps,
Dave |
Posted: Sat Feb 02, 2019 6:57 am Post subject: Re: Seal/Gasket between cluster and dash? |
Perfect. Thanks _________________ Bill
Posted: Sat Feb 02, 2019 7:43 am Post subject: Re: Seal/Gasket between cluster and dash? |
Apply a thin bead of silicone, smooth it out carefully and let it set up. Done for another couple of decades. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Sat Feb 02, 2019 9:00 am Post subject: Re: Seal/Gasket between cluster and dash? |
What are the cross scetion meaurements on that seal? Is it hard ....normal rubber...or is it,a foam like door seals?
You might try looking at the range of bulk...by the roll....glass channel setting seals and generic seals....in the Auveco catalog.
Ray |
Posted: Sat Feb 02, 2019 7:40 pm Post subject: Re: Seal/Gasket between cluster and dash? |
Ray
at the moment my seal is brittle, but I suspect this was relatively soft. The cross-section is shown in picture. The horizontal part is approximately 0.110 inch thick and the vertical portion about 0.060 inch thick.
Either way, I have a list of stuff that I have to buy from different vendors. I can live with $7 for the proper seal from Buslab. If I'm in a hurry Wildthing's suggestion is pretty good...or maybe even the cylindrical/rope rubber seal for screen windows might work.
