taknitez Samba Member
Joined: March 14, 2006 Posts: 10 Location: Raleigh, NC
Posted: Sat Jan 05, 2008 10:19 am Post subject: Will 165/80R15 Work on 79 Super Conv. |
Due to prices and such, I may have to go with a 165/80R15 for a new set of tires instead of the pricey 165R15.
Question is this....Will this work on my 79 Convertible with the standard sport wheel? Will it affect anything at all?
Thanks for your help.
T. |
Alan Willis Banned
Joined: November 22, 2004 Posts: 4181 Location: booted from the SEWR and stalked in here
Posted: Sat Jan 05, 2008 11:05 am Post subject: |
A 165R15 is really a 165 78R15...So you'd go from an aspect ratio(determines sidewall height)of 78 to an aspect ratio of 80,or from a tire thats 25.13" tall to a tire thats 25.39" tall...I don't know... _________________ die schwarzen Schafe #666 |
73stroker Samba Member
Posted: Sun Jan 13, 2008 7:01 am Post subject: |
I ran Conti 165/80/15's on my 1973 Standard Type 1 with no problems at all. |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Sun Jan 20, 2008 7:24 am Post subject: |
Alan Willis wrote: |
A 165R15 is really a 165 78R15...So you'd go from an aspect ratio(determines sidewall height)of 78 to an aspect ratio of 80,or from a tire thats 25.13" tall to a tire thats 25.39" tall...I don't know... |
I thought a 165R15 was actuall a 82 aspect (not that it makes much differance.
The 185's will fit on your wheels fine, just a tiny bit oversized over stock tyre size, nothting to worry about
you might like to use this also http://www.miata.net/garage/tirecalc.html
herbie13 Samba Member
Joined: March 26, 2008 Posts: 46 Location: Vancouver, WA
Posted: Wed Mar 26, 2008 4:31 pm Post subject: |
The stock tire diameter on a 4.0Jx15 rim is 25.63 inches, plus or minus .24 inches. Thats according to the Robert Bentley Manual for Volkswagen Beetle 1966 - 1969 page 5-48. I assume that the tire diameter specified by VW remained the same throughout the following years. The differences being the width of the later 4.5Jx15 and 5.5Jx15 rims.
A tire of 165/80R15 has a diameter of 25.39". That is the minimum diameter specifed by VW.
195/65R15 diameter = 24.98"
205/65R15 diameter = 25.49" |
