Vroom, vroom, glog...
[email protected]
swhipps@emailaccount.com is offline
PostPosted: Wed Apr 17, 2002 3:36 pm    Post subject: Vroom, vroom, glog... Reply with quote
My 1600 dual port bogs down in 3rd and 4th gears when trying to accelerate (engine #A020537; not sure what year?). I have adjusted the valves and tinkered with the timing everywhere from 10 degrees BTDC to 10 degrees ATDC. Also changed spark plugs, fuel filter, and used a carb cleaner fuel additive.
Any ideas of what might be the problem? Thanks in advance,
Scott
[email protected]
mattirobinson@hotmail.com is offline
PostPosted: Mon May 27, 2002 1:08 pm    Post subject: Vroom, vroom, glog... Reply with quote
i'd like to know what that is as well, my 71 does the same thing, send me a mail when you figure it out if you don't mind.
[email protected]
[email protected]
dassid@excite.com is offline
PostPosted: Sat Jun 01, 2002 2:41 am    Post subject: Vroom, vroom, glog... Reply with quote
Scott,
Check out what carb and distributor you are running. The 34Pict3 carb and Bosch 009 distributor are notorious for a flat spot. What I have read says that the fix is to install a vacuum-advance distributor. Aircooled.net is the only supplier that I am aware of that offers rebuilt vacuum-advance distributors.
