anthonywesty Samba Member
Joined: May 06, 2007 Posts: 107 Location: Sunshine State
Posted: Tue Jan 08, 2008 3:33 am Post subject: Instrument cluster with LEDs?? |
Recently i saw a vanagon with leds in the instrument cluster and the leds installed in the original plug of the vanagon. someone it knows where i can found the leds??
Thanks !! |
OilNBolts Samba Member
Posted: Tue Jan 08, 2008 6:25 am Post subject: |
Try these guys- www.jameco.com
Remember that an LED requires a series resistor to keep it from burning out instantly. Some math required. _________________ Current fleet: Vanagons, two '88 GLs and an 89 Bluestar. Beetles, '63, '64, '72 convertible. Plus, four Subarus and three Prius. Too many cars. |
Volksaholic Samba Member
Joined: December 26, 2005 Posts: 1771 Location: Salt Lake City, Utah, USA
Posted: Tue Jan 08, 2008 7:54 am Post subject: |
Try an outfit like this one: http://www.superbrightleds.com/1157.htm
or one of the many others that you can find on the Web (I don't have any personal experience with or financial interest in this retailer). The lights they sell already have the dropping resistors and standard bases, so if you can find what you need you don't have to mess around trying to adapt an off-the-shelf LED and dropping resistor. _________________ 1988 Wolfsburg Edition, 2001 Subaru EJ251 |
kevinbassplayer Samba Member
Posted: Tue Jan 08, 2008 9:15 am Post subject: |
I did this recently using blue leds from superbrightleds.com. You have to remove the bulb from their base and install it into the vw base, which is fairly easy but you have to be careful as the led legs which have a transistor attached are slightly delicate (I broke one so you might want to order a couple of extras, not very expensive) the lights look killer, they dim, and a huge energy savings. The light in the heater controls is a different story, a real pain. I had to modify a different led into the vw base by cutting the plastic base and soldering the led in, but I managed to break one of those also and then cracked the plastic of the heater faceplate in the process. I took pic's of all this to do a write up but haven't had time yet, I'll try to get them posted. |
ahollon Samba Member
Joined: November 19, 2007 Posts: 68 Location: Anchorage, Alaska
Posted: Wed Jan 09, 2008 12:43 am Post subject: |
kevinbassplayer wrote: |
I did this recently using blue leds from superbrightleds.com. You have to remove the bulb from their base and install it into the vw base, which is fairly easy but you have to be careful as the led legs which have a transistor attached are slightly delicate |
Do you know which part # of LED bulb you used from those guys? _________________ 84 Westy |
Posted: Wed Jan 09, 2008 8:37 am Post subject: |
ahollon wrote: |
Do you know which part # of LED bulb you used from those guys? |
For the instrument lighting in the dash I used superbright led's B8.5D Instrument cluster led bulb. These are a pretty straightforward affair to change out from the base they come with to the VW base. The light I used for the heater control panel is WLED 1-Led Bulb. This one takes some modification to make it work and you have to solder the led legs into the holder where you don't have to do that with the dash lights. Let me know if you have any other questions
Kevin |
a914622 Samba Member
Joined: July 29, 2004 Posts: 835 Location: Westend of HWY2 , Wash
Posted: Thu Jan 10, 2008 9:16 pm Post subject: |
The leds from superbrightleds work great. I tried the blue and the UV and white color. The uv look cooler but are a little dark for me. I think the UV would work best with the white face gages. White was a little bright for me. Blue is cool. I also put a blue DOME light up front and white in back.
Iv change all the back lights with white and added a back light to the headlight switch.(the rocker part from a 91 jetta is the same except the light picture lets light thur, just remove the green film)
oh ya dont forget the license lights (looks like a beemer) |
Posted: Fri Jan 11, 2008 1:17 pm Post subject: |
Forgot to mention in my last post but I also used the blue led's for the dash lighting, it looks awesome! |
r39o Samba Polizei
Posted: Fri Jan 11, 2008 1:41 pm Post subject: |
luvdavdhbs (sp?) did some fun things with cluster lighting. I believe you can find his thread via the Best Stickies. Click on the Best Threads in my signature below. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
targis58 Samba Member
Joined: July 11, 2006 Posts: 539 Location: sunnyvale,ca
Posted: Fri Jan 11, 2008 1:46 pm Post subject: led light |
any pictures to show how it looks? |
dpazos Samba Member
allsierra123 Samba Member
Joined: August 19, 2006 Posts: 1462 Location: Tecate, Baja California MX
Posted: Fri Jan 11, 2008 7:12 pm Post subject: |
Hey I am gonna order a few of those. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold |
vanshock Samba Member
Posted: Sat Jan 12, 2008 1:02 pm Post subject: |
I used the 42 draft designs in mine |
Posted: Wed Jan 16, 2008 9:41 am Post subject: |
which bulbs from 42 designs went where? _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
Posted: Tue Feb 05, 2008 5:53 pm Post subject: |
I was wondering if you could post those photos of the heater control panel MOD you did for the LED. I just ordered the LED's and will be attempting the same MOD. I am going to try the amber color in the instrument cluster, i also ordered the blue ones too. _________________ 84 Westy |
Posted: Tue Feb 05, 2008 5:59 pm Post subject: |
ahollon wrote: |
I was wondering if you could post those photos of the heater control panel MOD you did for the LED. I just ordered the LED's and will be attempting the same MOD. I am going to try the amber color in the instrument cluster, i also ordered the blue ones too. |
I deleted the pic of the heater led mod by mistake:( sorry! |
McHuntley Samba Member
Joined: November 12, 2002 Posts: 791 Location: Costa Mesa, CA
Posted: Tue Feb 05, 2008 6:47 pm Post subject: |
vanshock wrote: |
Is that a Lit Headlight switch? I would love to do that... or at least add it to the list of mods I want to do. _________________ Any opinions stated here are my own, otherwise someone else would have said them. |
ProvoCyclist Samba Member
Joined: December 07, 2004 Posts: 593 Location: Murray, Utah
Posted: Wed Feb 06, 2008 2:28 pm Post subject: |
Do we use the B8.3 base? No converting necessary! Only in blue tho.
_________________ Clark
Current: 1986 Tintop GL 2wd, stock 2.1L, manual trans, Flash Silver LP7Y.
Past: 1985 Sunroof GL, 2wd, Subaru 3.3L, manual trans, resprayed to Diamond Silver L97A |
