westylife Samba Member
Joined: October 28, 2007 Posts: 409 Location: Anchorage, Alaska
Posted: Thu Jan 10, 2008 8:10 pm Post subject: |
Ahhhhhh. nice one. _________________ 1983.5 Westfalia Bostig RG1 |
aguabonita Samba Member
Joined: November 27, 2005 Posts: 267 Location: Monterey, CA
Posted: Thu Jan 10, 2008 9:03 pm Post subject: |
Looks like a heck of a lot of work but it seems that you did a great job.
Let us know how much of a difference it all made in the acoustics dept.
Kevin _________________ '87 Westfalia, GW 2.2, and some other goodies
'90 Volvo 245 |
tikibus Samba Member
Joined: July 07, 2006 Posts: 834 Location: Rochester, NY
Posted: Fri Jan 11, 2008 5:35 pm Post subject: |
Dang!
Sorry, just upgraded my computer to finally see what folks are doing. Seriously, I couldn't see anything... Post with pic's... ahhh, dang.
Now me gots a kick ass machine.
First off. great job. really. Dash too. The Vanagon is clean via the Seam Sealer in the interior. Your pic's tell the story. Even the step ups are clean. Very Lucky. Why?
From my POV, the step up is a throw back to the original design.
Now, all is prepped in the interior,
my heart of hearts goes to exterior, you done a amazing job inside of the cabin, look at the Seam Sealer on the Outside ( under the seats, etc.) This inspection can cause one to go down another deep Rabbit Hole, but, if its a Love, then have a look.
GREAT JOB!!!!! _________________ Happy Trails!
Mark
______________
Founding member of the Empire State VW Camping Club.
http://www.empirevwcamping.org/
1984 Westy - Tiki
1997 Honda Civic -The Green Hornet
1971 Volvo P-1800E- needs TLC |
Posted: Sat Jan 12, 2008 2:10 am Post subject: |
tikibus wrote: |
Dang!
GREAT JOB!!!!! |
Thanks tiki!
I get back home in a couple weeks and will check that area out. I was also thinking about getting the step ups rhino lined. Not sure though. Reading your posts. I was wondering if you were an auto body repairman? You really seem to know your stuff.
p.s. to all. I have never done anything like this before. Everything I have done, I have learned from the Samba. Thanks to all for the posts.
Cheers,
Jason _________________ 1983.5 Westfalia Bostig RG1 |
FNGRUVN Samba Member
Joined: October 27, 2007 Posts: 2237 Location: Fort Collins, CO
Posted: Sat Jan 12, 2008 3:04 pm Post subject: |
Those pictures are exactly what my Westy looked like. I gutted mine to change the color from the orange/brown to all white. That was about four years ago and I'm just now putting the finishing touches on mine. What can I say, I'm not good, but I'm slow. When I get time I will post all the pics. |
McVanagon Samba Member
Joined: February 19, 2007 Posts: 1684 Location: Northern part of the Virginia
Posted: Sat Jan 12, 2008 3:27 pm Post subject: |
Dude, I totally have the same rear door for my garage. I did not know they made those types of doors for cars. Very trick!
Sarcasm off. _________________ '69 Mike
'85 GL
'87 Wolfsburg Hardtop |
captainpartytime Samba Member
Joined: December 04, 2005 Posts: 715 Location: Mission Viejo, CA
Posted: Sat Jan 12, 2008 3:30 pm Post subject: |
Look at that beautiful Assuan Brown....there's no better color _________________ -Kerry
1982 turbo diesel Westfalia |
shoblime Samba Member
Joined: December 28, 2007 Posts: 43 Location: State College, PA
Posted: Sat Jan 12, 2008 4:16 pm Post subject: |
I put 4 layers of brown bread dampening paper in two thicknesses all over an extended cab toyota pickup, it was "lexus quiet" except for the glass parts..stuck really well even on the ceiling. It takes a long time to do it right but it makes a huge difference for the sound system (truck had several audio upgrades) Putting some on the engine compartment does wonders, as well (the hood) you have to use the stuff for high temps though, it has more of a foil on top usually. |
Posted: Tue Feb 05, 2008 10:41 pm Post subject: Part 2 |
<-----------------------------------PART 2--------------------------------------->
Well I’m back to work so here is what I did last time I was home. I removed the old wall paper stuff from the inside panels and repainted them. I took a piece of the wall paper stuff into home depot and they matched it perfectly. You can see in the pic the color of the panels before. The PO tried to match the Asuan Brown but looked like poop. See Mightyarts post for panel repair.
http://www.thesamba.com/vw/forum/viewtopic.php?t=198673&highlight=interior
primed and ready to go
Installed 100ft of B-quiet and installed new insulation. I did run out of B-quiet at the back above the engine compartment. But at least I got everything else. Here are pics with B-quiet and insulation.
The plastic behind the lower front door panels was trashed and I was trying to find something to replace it with. I was going to use double sided tape and some painters plastic when I ran across this stuff at the Home Depot.
I remember when I moved into my house the movers put this sticky plastic stuff on the floor so they did not trash the carpet. I cleaned the door as much as I could and cut a piece bigger than the hole in the door. After I put it on I used a razor blade to trim off the excess. THIS STUFF WORKS GREAT! You can barely see that it’s even there. When I removed the top plastic it only tore in a couple of places so I just reused it and used this carpet protector to patch up where it tore.
I’m going to put wood (laminate) floors in and found this stuff made by Burke.
It has this amazing finish with a 30yr warranty. I did have to buy two boxes since I was two boards short. It’s going to look nice so who cares.
Next I have to put in the closet, top storage and install the floor. The panels look great.
Until next time….
noganav Samba Member
Joined: January 06, 2006 Posts: 1236 Location: San Diego CA
Posted: Tue Feb 05, 2008 11:14 pm Post subject: |
This is just awesome! Summer project here I come. Thanks for all the pics! |
mccabe Samba Member
Joined: March 20, 2007 Posts: 101 Location: Olympic Peninsula
Posted: Tue Feb 05, 2008 11:25 pm Post subject: |
Good call on the carpet protector plastic... I need to do something like that for my front panels. |
mordeaux Samba Member
Posted: Wed Feb 06, 2008 7:01 am Post subject: |
"4 layers of brown bread dampening paper in two thicknesses"
What is brown bread dampening paper? |
peakay Samba Member
Posted: Wed Feb 06, 2008 8:33 am Post subject: carpet protector plastic |
hey westy, regarding the plastic, there are two types you can use. one is for carpet (like you used) and is extremely stick y and will be permanent on a surface like a door skin. the other is low-tack and can be more easily positioned and likedly removed if you ever need to. i just thought i'd point this out for anyone else who may use it.
here is an online source for each:
Carpet Protection film: the high tack stuff
Floor Protection film: the low-tack, repositionable stuff |
Posted: Wed Feb 06, 2008 8:50 am Post subject: |
mordeaux wrote: |
http://www.b-quiet.com/ultimate.html _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Wed Feb 06, 2008 8:53 am Post subject: |
Thank you. |
wavanagon Samba Member
Joined: September 17, 2007 Posts: 400 Location: Everett, WA
Posted: Wed Feb 06, 2008 9:45 am Post subject: |
this post keeps getting better and better. thanks for the detailed documentation and great pictures! did you go to the loogy school of posting on the internets? this place is great. _________________ 1988 Vanagon GL - For Sale
1987 Westfalia
2008 Audi A4 2.0T
http://wavanagon.googlepages.com
Dirty from working on your Vanagon? Buy soap from my wife!
http://www.teatreesoap.com |
Posted: Thu Feb 07, 2008 12:32 pm Post subject: Re: carpet protector plastic |
peakay wrote: |
hey westy, regarding the plastic, there are two types you can use. one is for carpet (like you used) and is extremely stick y and will be permanent on a surface like a door skin. the other is low-tack and can be more easily positioned and likedly removed if you ever need to. i just thought i'd point this out for anyone else who may use it. |
Thanks for the links! I think this stuff is going to hold up well. I will let everyone know next year how well it works.
wavanagon wrote: |
this post keeps getting better and better. thanks for the detailed documentation and great pictures! did you go to the loogy school of posting on the internets? this place is great. |
Thanks for the comments! I'm sure the next guy will do one better than mine. Remember you can never take too many photos when you are doing work on your projects; I wish I would have taken more. I'm getting the propane tank powder coated right now but forgot to take a "before" photo, I'm sure we all know what a rusty old tank looks like. I will post a picture of it when I get it back. _________________ 1983.5 Westfalia Bostig RG1 |
Posted: Thu Feb 07, 2008 12:38 pm Post subject: |
Dude, I got your back w/ the propane tank pic. I will take one of mine. The van came from SanFrancisco and I swear someone, on a daily basis, sprayed the van w/ sea water. Jesus H. My propane tank is a beauty. _________________ 1988 Vanagon GL - For Sale
1987 Westfalia
2008 Audi A4 2.0T
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Thu Feb 07, 2008 12:42 pm Post subject: |
"So I assume people are using the B-quiet Ultimate, and not the Extreme?"
Jeepwillies, I used the Extreme, figuring the thickness difference between the two would likely not make that big a difference in the van. I did actually use two layers in some spots, though. I have not done the front compartment of the camper yet, only from behind the fronts seats on back. Good luck with your project! |
Posted: Thu Feb 07, 2008 4:31 pm Post subject: |
Yep, I used the Extreme. _________________ 1983.5 Westfalia Bostig RG1 |
