going from wide five back to stock four
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
oibovveroi
oibovveroi is offline
PostPosted: Fri Jan 11, 2008 7:17 pm    Post subject: going from wide five back to stock four Reply with quote
im thinking about going back to the stock four lug on my 69.
the po had put wheel adaptors and a set of american eagles empi wide five rims.
i have changed the drums to that of a 67 in front and rear to ditch the adaptors but i think when i do the front drums over to disk i will go to the four lug.
just curious on how many people out there might have went to the five and then went back to four lug?
maybe i should keep the wide five look....?
Skim
Rants Master
Skim is offline
PostPosted: Fri Jan 11, 2008 7:32 pm    Post subject: Reply with quote
Its all up to you and what type of wheel you prefer to run.
GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
Robert12
Robert12 is offline
PostPosted: Sat Feb 02, 2008 6:47 pm    Post subject: Reply with quote
I am thinking of doing the exact opposite you are doing? I want to take my 69 to the wide 5 look with adapters how did you do that? any pictures?
Thanks
Robert
1962 Ragtop, 1965 Notchback, 1974 Thing
Skim
Rants Master
Skim is offline
PostPosted: Sat Feb 02, 2008 8:55 pm    Post subject: Reply with quote
Thanks
Robert
You wont need adapters if you use 66-67 bug front drums. The rear is just about as easy if you use wide 5 rear drums with the spacer between the axle nut and the drum.
GFK
1953 Kabriolet
1954 Sunroof
oibovveroi
PostPosted: Sun Feb 10, 2008 10:57 am    Post subject: Reply with quote
i used the 67 drums in front and rear.
the rear with a spacer.
if you do it dont forget to buy new rear shoes for a 67 on the front its the same size.
sorry i never took any pictures but there are a crapload of threads that go into detail on this if you use the search.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
