westcoast-paul Samba Member
Joined: January 31, 2006 Posts: 822 Location: CanadaYaHoser
Posted: Mon Jan 14, 2008 1:22 pm Post subject: IRS Axles 101 - narrow? |
I assembled the rear of my car - rolled it out into the driveway and figured out that the the rear track is too wide. i have 5.5" silver mangels with 185-60-15.
i have an extra set of IRS trailing arms (used) coming in a week or so. i will be cutting them to narrow the rear, but i need to find out about axles first.
from whati can tell (searching here and google) is that they come in a few standard sizes.
15 5/8"
16 1/4"
16 3/4"
17 1/4"
18 3/4"
19 1/4"
20 1/4"
http://www.swayaway.com/Axles.php
i have a 1974 IRS beetle chassis. I did pull the axles, but have not taken the CV's off to measure them.
Does anyone know what came stock on the 74 chassis? i think it's the 16 1/4" one??
There is also a Type 3 axles (passenger side only) that is shorter (is it 1.5" shorter? )
Ideally, i'd liketo gain about 1.5" on either side.
i do know about hte trailing arms that you can buy that are already narrowed. i plan on making mine fit the axles i buy.
any help by folks who have experience here is greatly appreciated.
thanks. _________________ - Paul |
Bruce Samba Member
Posted: Tue Jan 15, 2008 12:54 am Post subject: |
Stock Beetle axles are 415.5mm long.
The LEFT axle from a Type 3 with an automatic axle are 26mm shorter, or 389.5mm. _________________
Posted: Tue Jan 15, 2008 9:33 am Post subject: |
so what are the 15 5/8" (396.875mm) length axles from?
16 1/4" (412.75mm - or 415.5mm?) stock IRS beetles?
Does anyone know a sorce for the type 3 LEFT axles? _________________ - Paul |
Posted: Tue Jan 15, 2008 11:44 am Post subject: |
did some digging and found this:
http://listarchive.type3.org/archives/2003/december/msg00466.html
Quote: |
> MT shafts are 415.5mm/16.357"
> AT LH shafts are 389.5mm/15.333"
> AT RH shafts are 439.5mm/17.302"
It's comforting that LH auto + RH auto is about 2 x manual. |
http://listarchive.type3.org/archives/1998/december/msg00655.html
Quote: |
You're right! This info is not in the Bentley; I'm really surprised.
Here is what you need, taken from various other sources.
Type 3 Double Joint Axle driveshaft lengths (b: OAL)
MT: 415.5mm, 113 501 211, code # 1 on end of shaft
AT-L: 389.5mm, 311 501 211B, code # 2 on end of shaft
AT-R: 439.5mm, 311 501 212B, code # 3 on end of shaft
So you can see that the type 3 MT uses the beetle shaft, but the type
3 AT uses two different shafts, one shorter and one longer than the
MT. Type 2 half shafts are all completely different. |
http://www.shoptalkforums.com/viewtopic.php?p=8249...cebbd15800
Quote: |
OVERALL BETWEEN CIRCLIPS
Type I/III (4-spd) 415.5mm 405.3mm
Type IV (4-spd) 435mm 433mm
Type IV (Auto) 435mm 427mm
Type III Auto LH 389.5mm 379.3mm
Type III Auto RH 439.5mm 427.3mm
Type II (4-spd) 476mm
Type II Auto LH 457mm
Type II Auto RH 505mm |
http://www.blindchickenracing.com/How_to/CVJoints_Axles/axles_101.htm _________________ - Paul |
Posted: Wed Jan 16, 2008 12:05 pm Post subject: |
wow - this forum has been pretty much no help at all...
anyway - for anyone looking in the future (via search):
John at aircooled.net says the 1.5" narrowed trailing arms:
work with:
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=cfa0004
this means that 15 5/8" 33 spline (stiock T1 style) axles work. _________________ - Paul |
ninja90177 Samba Member
Joined: August 14, 2006 Posts: 640 Location: Las Vegas, NV
Posted: Wed Jan 16, 2008 2:46 pm Post subject: |
I'm guessing i'm gonna be going this route in the future with 9" wides in the rear.
I'm trying to tuck them just under the edge of the fenders (+1.5") but had no idea what I was in for. I had the option of different offsets on my rims, but only the one was available and the rest were on indefinite back order due to popularity.
Sucks you had to go through all this on your own (a PITA, i know) but thanks for posting the info here. It's been bookmarked.
Kenney _________________ Spun a rear drum? check this out |
56Hotrod Samba Member
Joined: January 09, 2007 Posts: 85 Location: Greenville, SC
Posted: Sun Jan 20, 2008 10:58 pm Post subject: |
I had inquired about these last year. Several messages sent to [email protected], with NO response. I did get a response from another member here that said the fitment was terrible...then, somewhere John said the jig was messed up, and fixed. Since I never got replies from them, I move my business elsewhere. |
Posted: Wed Feb 20, 2008 9:58 am Post subject: |
welder i used:
cut bearing housing at 90 degrees completely through the arm:
weld plate (thicker than arm housing) inside and out:
carefully measure and weld bearing housing on (note that this was cut at 90 degrees (laser marked), so it sits flush:
Cut and weld new cap on:
Add re-enforcement:
clean , grind, marine epoxy and compare to stock IRS:
Stub axles being removed:
Note - this was narrowed 30mm (~1.2")
the difference in axle length is 26mm (1"), but there is available play int he CV's that i used. also note the 1.5" trailing arm above uses the same 389.5mm axles / CV. _________________ - Paul |
Merlin Samba Member
Joined: August 19, 2004 Posts: 2103 Location: South Africa
Posted: Wed Feb 20, 2008 11:10 am Post subject: |
That's brilliant!
Thanks Paul. It's certainly going to help my mate should we go this route.
I still *sigh* haven't gotten around to the chassis builder - dependant on someone else - so I can't get photos and measurements.
I presume measuring and cutting the arms to match up with the T3 auto axles will solve the 'play' problem, or is this a general problem when modifying the TAs?
Thanks, N. _________________ the3rdrock.com - …musings, discoveries and postulating, by a restless itinerant in search of enlightenment.
iowegian wrote: |
People who are allowed to have signature lines annoy me. |
Posted: Wed Feb 20, 2008 3:28 pm Post subject: |
Great work/documentation Paul. Great stuff! |
Bruce Samba Member
Posted: Wed Feb 20, 2008 11:17 pm Post subject: |
What happened to the snubber mount? What brakes will you be using? _________________
Posted: Thu Feb 21, 2008 9:34 am Post subject: |
i cut off the snubber mount.
i have converted to wide 5 brakes (this in itself was a tech article). _________________ - Paul |
Bruce Samba Member
Posted: Fri Feb 22, 2008 12:41 am Post subject: |
Not gonna put the snubber mount back on? _________________
Posted: Mon Feb 25, 2008 9:40 am Post subject: |
^ nope.
i installed them last night. They fit perfect. and can go uber low without the snubber on. _________________ - Paul |
rustytortoise Samba Member
Joined: September 14, 2006 Posts: 100 Location: williston, fl
Posted: Sun May 04, 2008 10:21 pm Post subject: |
i've been studying how you narrowed your trailing arms and really like it.
could you go any narrower do you think? or is that it?
what i am looking to do is put irs in my 61 beetle and have it the same width as the short swing axle that is stock for my car. or atleast very close.
i'm not sure how much wider a stock irs set up is compared to a short axle set up.. _________________ -Jonathan |
volksmike Samba Member
Joined: May 17, 2002 Posts: 64 Location: Macedonia SC
Posted: Thu May 15, 2008 5:44 am Post subject: bump with question |
when weldng the bearing carrier back on, could you change the angle to get rid of some negitive camber that happens even with IRS? |
Posted: Wed May 21, 2008 8:41 am Post subject: Re: bump with question |
volksmike wrote: |
absolutely.
I redid these with a jig though. I was out by a few mm (not very much) and the tire was off, so i had to correct it.
I suppse you could adjust the jig to compensate the negative camber.
also - you are limited by the axle choices. These are the narrowest ones available that are OEM. any more narrow and you need custom axles (read: $$$$$) _________________ - Paul |
