buggin'forfun Samba Member
Posted: Fri Jan 18, 2008 6:00 pm Post subject: 5x130 conversion, need some help |
I have researched the threads, but still have some questions. Most of ehat I've read doesn't involve a Super. I have a 75 Super Conv , lowered 1.5", with drums. I would like to run some 15"x6 Fuch replicas. I am planning to have the drums re-drilled, and hoping that that is all that is needed.
Questons:- what studs do I want for the drums after the redrill??
- what is a backing plate, and do I need a new one?
-does anyone think I'll run into any problems??
ANY suggestions would be welcomed. Thanks. |
Posted: Sat Jan 19, 2008 3:07 pm Post subject: |
Really...I hate to beat the topic to death...but I have searched the threads but have been unable to get these questions answered.
ANY help would be very appreciated. Thanks. |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Sat Jan 19, 2008 7:34 pm Post subject: Re: 5x130 conversion, need some help |
buggin'forfun wrote: |
If you choose to redrill your current drums then I would recommend the press in studs because 4 lug drums are reinforced in the 4 spots where the stock lugs are at only. If you choose blank drums, you can run screw in studs or press in.
You will still be able to use your stock backing plates.. Hope this helps. _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
