What's the most you've hauled?
Page: Previous  1, 2, 3 ... 18, 19, 20 ... 23, 24, 25  Next
j.pickens
j.pickens is offline
PostPosted: Tue Apr 15, 2014 8:31 pm    Post subject: Reply with quote
Damn, Dustin.
That's a serious load.
I'd have wimped out and put down some heavy cardboard or plywood under the block.
BeaterBarndoor wrote:
Red Fau Veh wrote:
54taterbug
54taterbug is offline
PostPosted: Wed Apr 16, 2014 3:16 am    Post subject: Reply with quote
j.pickens wrote:
Damn, Dustin.
Laughing John that wouldn't have been a wimp out. Crete block on metal would be like fingernails on a chalkboard. .The outer block over hung the cargo floor mat I have in the bed.
vinlong
vinlong is offline
PostPosted: Sat Apr 26, 2014 10:50 pm    Post subject: Reply with quote
Back in 1988, 14 kegs of beer for a party.
160 lbs a piece, makes 2240 lbs. No biggie, the bus was rated as a one-ton truck.
My bodybuilder roommate could throw one keg over each shoulder, and carry them up to the 3rd floor.
Just spent an hour and a half looking for the photo of it, can't find it, so as you guys say, "if you don't have a photo, it doesn't count".
Thats an hour and a half of my life I lost away from my garage.
Da TOW'D
Da TOW'D is offline
PostPosted: Sun Apr 27, 2014 5:58 pm    Post subject: Reply with quote
Not the heaviest may be the longest
long boards are 22 ft. long for our new greenhouse
We moved them from our saw mill out in the back 40 through the trees
smooth
'57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy DD
and NUTS
D-train
D-train is offline
PostPosted: Mon Apr 28, 2014 3:08 am    Post subject: Reply with quote
just under a ton of pavers
a cube of crusher dust (mr wiki said 1.5 ton?) doesnt sound right
that old girl.
all done running 6.40 15s cross plys, original brakes an original shocks from 1960 too..
shiny paint doesnt make it worth any more
cdennisg
cdennisg is offline
PostPosted: Mon Apr 28, 2014 7:55 pm    Post subject: Reply with quote
smooth
that is great!
nothing
vwassing
vwassing is offline
PostPosted: Tue Apr 29, 2014 2:59 am    Post subject: Reply with quote
smooth
That is a long load for a Single Cab. Looks like you could use my trailer!
Not my heaviest load but definitely the most fun.
Da TOW'D
Da TOW'D is offline
PostPosted: Tue Apr 29, 2014 1:14 pm    Post subject: Reply with quote
that is a cool looking trailer!
Do the logs pivot on the deck?
I'll do it one more time for a few more boards used in the greenhouse puzzle
cheers
hank
'58 SC Ruf
'62 type 3 Notch
and NUTS
mandraks
mandraks is offline
PostPosted: Wed Apr 30, 2014 11:18 am    Post subject: Reply with quote
the SO14 Wolperding
regards
Uli
cdennisg
cdennisg is offline
PostPosted: Wed Apr 30, 2014 1:18 pm    Post subject: Reply with quote
mandraks wrote:
the SO14 Wolperding
I have always wonder how well that works, with the pivot points of the trailer beam and the logs in different places. The logs must be able to slip fore and aft in the trailer cradle.
nothing
Culito
11010101
Culito is offline
PostPosted: Thu May 01, 2014 5:18 pm    Post subject: Reply with quote
"Wolperding". Laughing
sorry.
Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
mandraks
mandraks is offline
PostPosted: Thu May 01, 2014 7:06 pm    Post subject: Reply with quote
sorry.
here is the original Smile
regards
Uli
Big Bill
Big Bill is offline
PostPosted: Fri May 02, 2014 8:21 am    Post subject: Reply with quote
Not as much as some of you have hauled. About 30 or so 2" thick Flagstone Paver stones and 3 bags of rock fines. Rides so much bettewr with some weight in it. Smile
j.pickens
PostPosted: Fri May 02, 2014 8:59 am    Post subject: Reply with quote
smooth
I'd like to see some photos of your truck by the sawmill.
And vwassing, it was a pleasure to crawl all over your bus in Amersfoort.
Definitely a highlight of the trip!
Red Fau Veh wrote:
Da TOW'D
Da TOW'D is offline
PostPosted: Fri May 02, 2014 5:41 pm    Post subject: Reply with quote
Here you go, J.P
our grandson loading the scraps for the wood shed
cheers
hank
'58 SC Ruf
'62 type 3 Notch
and NUTS
PostPosted: Fri May 02, 2014 5:43 pm    Post subject: Reply with quote
^^^ That is an awesome photo
Da TOW'D
Da TOW'D is offline
PostPosted: Fri May 02, 2014 7:06 pm    Post subject: Reply with quote
Thanks
We are cutting 22 ft long 4x10
to be used in a cabin addition we are building
Oh my aching back
hank
'58 SC Ruf
'62 type 3 Notch
and NUTS
busworks
busworks is offline
PostPosted: Sat May 03, 2014 7:06 am    Post subject: Reply with quote
That is one cool ass saw!!!
BarryL Premium Member
BarryL is offline
PostPosted: Sat May 03, 2014 8:50 am    Post subject: Reply with quote
Fer sure. If you squint real hard its engine could almost be construed as a dual-port husky VW type 1 although it's not.
Da TOW'D
Da TOW'D is offline
PostPosted: Sat May 03, 2014 1:01 pm    Post subject: Reply with quote
original single port engine was eaten up by electrolysis- exposed to seawater
3 engines gave up their lives to build this
We built a
balanced 1600 DP
3 angle valve grind
Volvo SU carb and air filter
Mann oil filters
Tuned Tee Pee exhaust
alternator
adapt thrust bearing and electric start
Only the original steel parts from the OE used with new bearings
all the rest of the other metals were junk
gauges- vacuum - oil pressure oil temperature
300 hrs so far
it cuts Accurate dimensions and sounds great with that exhaust
check out
Mobile Dimension Saw Company Trout Dale Oregon
'58 SC Ruf
'62 type 3 Notch
and NUTS
Page 19 of 25
