52panelvan Samba Member
Posted: Thu Jan 21, 2010 5:22 am Post subject: |
Lovely Workmanship. |
Scotty Samba Member
Joined: July 02, 2003 Posts: 1531 Location: Northampton - Uk
Posted: Thu Jan 21, 2010 6:08 am Post subject: |
Looks like your Dad could be very busy with vw clocks if he wanted! _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
The Milky Barndoor Kid Samba Member
Joined: February 15, 2004 Posts: 84 Location: under the bus
Posted: Fri Feb 12, 2010 5:22 am Post subject: |
Scotty wrote: |
52panelvan wrote: |
Just fix the dammmm samba thingy thing and drive it |
It seems that deluxe owners are far more interested in having every single correct part before they'll even entertain the idea of driving their bus....... |
EasyTiger.............some of us do pull our fingers out _________________ --------------------5055--------------------------- in association with : Ishinkso engineering, Poncho Vw services, Freeking Delicious VW's,
Kafer Kraft, GWB, Pyros BBQ Services, Classic Wagon, Flame and Per-four-mance VW,
and not forgetting The PWA, (Pikeys with Attitude) |
barndoormambo Samba Member
Joined: April 25, 2005 Posts: 443 Location: East Coast, Homeland
Posted: Fri Feb 12, 2010 5:25 am Post subject: |
..'perfectionist ' springs to mind.. _________________ ....just cause you don't see it, doesn't mean it isn't there!.... |
SplitPersonality Samba Member
Joined: September 26, 2004 Posts: 630 Location: Norway
Posted: Fri Feb 12, 2010 6:35 am Post subject: |
So ... the conclusion is that my friend's February 1952 DeLuxe uses a clock which is exactly like a Split Window Beetle clock?
Correct? |
tstracy39 Samba Member
Joined: May 14, 2008 Posts: 3294 Location: Seattle, WA
Posted: Thu Nov 18, 2010 8:24 pm Post subject: |
Does anyone have a picture of an original early 1953 (black face) Barndoor deluxe pod clock winder knob? I'm working on a little something. I tried searching the gallery but I didn't find anything.
I did find this though, pretty kewl little bugger:
_________________ Check my classifieds for kewl gauges:
http://www.thesamba.com/vw/classifieds/search.php?username=tstracy39
EverettB wrote: |
I like your fork. |
nane_cox Samba Member
Joined: May 09, 2005 Posts: 115 Location: France-Switzerland
Posted: Thu Feb 07, 2013 10:43 am Post subject: |
Hi,
Can we put the mecanism of a bug Kienzle clock in a barndoor Kienzle 1954 clock ?
A Kienzle for a bug
A Kienzle for a barndoor
Has someone already tried please? Do someone has an exploded view of speedos or instructions to disassemble a speedo
Thanks |
Posted: Thu Feb 07, 2013 6:18 pm Post subject: |
nane_cox wrote: |
Hi,
A Kienzle for a bug
Thanks |
The size of the axles that the watch hands go on is probably different on the Barndoor clock mechanism, due to the large size of the hands. I have a similar miniature clock and the smaller axle is about 1/64 to 1/32 of an inch, I haven't taken apart any Barndoor clocks but all the Split Beetle clocks I've taken apart had something much larger, and as far as I know all Split Beetle hands interchange with Barndoor ones. You could probably have most of the parts from the Bug movement swapped over to the Barndoor movement by a clock restorer though, if they can't salvage the Barndoor movement. _________________ Check my classifieds for kewl gauges:
EverettB wrote: |
I like your fork. |
Posted: Tue Nov 19, 2013 12:56 pm Post subject: |
Hi, can someone tell me if the clock dial was hand painted, or made with decals, or painted with a stencil ?
If you know someone who can restore a dial, please tell me
Thanks for the help. It s for the tomtom bus |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2176 Location: Graz, Austria, Europe
geraldcrewcab Samba Member
Posted: Wed Nov 20, 2013 8:25 am Post subject: |
...I asked him but still have no answer from for the moment |
Posted: Thu Nov 21, 2013 6:07 am Post subject: |
djfordmanjack wrote: |
it was spray painted with stencils, that's how you would restore it also.
needs very detailed work and steady hands to do all of this. |
Was is a stencil or a buffer (I don't know the exact word in English)
Posted: Thu Nov 21, 2013 6:19 am Post subject: |
Interesting, fine grey(blueish) lines seem to have been drawn by hand on his faceplate.
The lines definitely look inconsistent and hand-painted in places, but they were probably only touch-up painted in places where the original ink was missing, and most of the lines actually consist of the original ink. _________________ Check my classifieds for kewl gauges:
EverettB wrote: |
I like your fork. |
Posted: Thu Nov 21, 2013 8:13 am Post subject: |
tstracy39 wrote: |
but they were probably only touch-up painted in places where the original ink was missing |
never ever ! Did you see the before pic ? this face has been completely painted and striped/signwritten. I think the letters have been done by hand too, probably with stencils, Still guessing about the VDO and Kienzle scripts.
Yeah maybe stencils is the wrong word, should be a stamp/mold whatever you call it, which is printing the lines/numbers on the color sprayed face. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
52 deelux Samba Member
Posted: Thu Nov 21, 2013 1:58 pm Post subject: |
I spoke to an instrument manufacturer about producing this (and other) faces.
He speculated that after screen printing (silk screen) the flat blank, they are then hydro-formed to achieve the circular rib.
This process was and is used on tin toys. How do you think they print on irregular shapes. Answer: They Don't.
Further investigation led me to specialist inkjet printers' that can print on onto irregular surfaces. This appears to be the modern restoration solution if you have a clock.
As I have sourced the correct instruments I originally intended to reproduce I haven't followed this any further, although I have produced the artwork in Illustrator. _________________ 52 BD Deluxe
57 Ghia golde
54 Ragtop |
Posted: Thu Nov 21, 2013 4:14 pm Post subject: |
52 deelux wrote: |
well yeah, that sounds absolutely logical, die stamping the finished painted face.
still is no solution to restoring an old face plate, well the modern printer could be. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
Posted: Sat Nov 23, 2013 5:15 am Post subject: |
tstracy39 wrote: |
Yeah maybe stencils is the wrong word, should be a stamp/mold whatever you call it, which is printing the lines/numbers on the color sprayed face. |
Didn't see the before pic until I looked at the link just now. Someone I once sold about $400 worth of stuff to once tried to commission me to restore his Hebmuller speedo by hand-painting the dial. I insisted that it wouldn't look perfect, he insisted that I do it anyway, and because he'd already bought so much stuff from me, I couldn't say no. I had the speedo disassembled and repainted the dial, at which point he asked for an update. I told him it looked OK except for the fact that the surface had brushstrokes in it, and he got very upset and told me it needed to be perfect, absolutely no brushstrokes allowed. I told him he was the one who insisted I repaint the dial by hand, a process which leaves brushstrokes behind, and that I only agreed to do it that way because he insisted. I sent the disassembled speedo back to him and never got paid for the full day of work I put into it. According to him I "Ruined" his "400 dollar part." I'm convinced that he wanted me to do the job by hand mostly for the cool factor and bragging rights, mistakenly believing hand-painting to be a perfect process by its very nature. This was the only time I've had a major beef with someone via thesamba. _________________ Check my classifieds for kewl gauges:
EverettB wrote: |
I like your fork. |
Posted: Sat Nov 23, 2013 11:27 am Post subject: |
That is absolutely the same obstacles I see in restoring a faceplate without digital 3D printing devices. it will never look like original, especially when concerning that they molded (diestamped) the already finished faceplate into its 3 dimensional shape. I think one could do with lasercut foil letters, lines and stripes, but you will see the thickness of the foil. I see another possible solution with photo etching/ light sensitive paint that would be developed by stencils or a digital projected pattern of the face. This would be an easy one with the right tools/equipment/program. Doing this by hand is possible and will be appreciated by a lot of people but it will never look like the original. Hand and brush is art, not gearwork. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
