1955 Barndoor Deluxe - Former Seattle/Japan resident
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Douglas Denlinger
Douglas Denlinger is offline
PostPosted: Sat Jan 26, 2008 11:33 am    Post subject: Reply with quote
2. Under the front seat - ie any little feet on the cab seatbase? Any (painted area) sound deadening material? Rubber stops (on the painted area)?
Thanks
RS
Here's the next set of photos for reference:
No sound deadening on the front seat stands, no evidence of any...ie glue, etc. BTW that's not rust it's the dust from the OG horse hair padding Smile
There appears to have been rubber stops (round stops based on paint discoloration around the 4 holes)
Douglas Denlinger
PostPosted: Sat Jan 26, 2008 11:40 am    Post subject: Reply with quote
Rusting Hulk wrote:
Doug does it still have an ashtray on the back of the middle seat? I would also be interested to see the front seat bracket on the bulkhead.
Hope this helps
Transporter Restorations
Upholstery Haus
Active 23 Window Samba Collector/Restorer,since 1986
crxgames
crxgames is offline
PostPosted: Sat Jan 26, 2008 11:42 am    Post subject: Reply with quote
That is one sweet/clean bus. Glad it went to someone who seems to care about it.
RockStock
RockStock is offline
PostPosted: Sat Jan 26, 2008 11:47 am    Post subject: Reply with quote
More:
7. Rocker/Sill detail - both sides - any drain holes along the outer edge?
8. Inner wheel arch colour/s - front and rear
9. Evidence of SWR overspray on outer belly pans
yes, mine still has a couple of these black bungs
-StockRocks-
Douglas Denlinger
PostPosted: Sat Jan 26, 2008 11:50 am    Post subject: Reply with quote
Pictures?
Upholstery Haus
RockStock
PostPosted: Sat Jan 26, 2008 11:51 am    Post subject: Reply with quote
Pictures?
Yes, I'll take some
-StockRocks-
Douglas Denlinger
PostPosted: Sat Jan 26, 2008 12:01 pm    Post subject: Reply with quote
Additional photo in gallery
Upholstery Haus
Douglas Denlinger
PostPosted: Sat Jan 26, 2008 12:07 pm    Post subject: Reply with quote
Anyone ever see this stuff???
Sound deadening?
Upholstery Haus
Last edited by Douglas Denlinger on Sat Jan 26, 2008 12:10 pm; edited 1 time in total
Douglas Denlinger
PostPosted: Sat Jan 26, 2008 12:08 pm    Post subject: Reply with quote
RockStock wrote:
4. The Glass Sekurit iogos - fixed side glass/front screens/cab door windows/skylights
All the glass in the bus is this logo. Except the corners which are still plexiglass. The windscreens appear to have been replaced. Would the windscreens be the same logo? In my earlier life experiences with BD's two 52's I owned had the large block logo. I would think by 55, the US DOT probably required something other than the German Sekurit??? Any thoughts??
Upholstery Haus
campingbox Premium Member
campingbox is offline
PostPosted: Sat Jan 26, 2008 12:25 pm    Post subject: Reply with quote
If it's a U.S. spec bus then it should have Sigla, with logos in the outter corners.
PostPosted: Sat Jan 26, 2008 2:03 pm    Post subject: Reply with quote
The front seat should have the little rubber pads. They are the same pads used on early post-Barndoor Buses. They are available new.
The 4 little feet on the front seat should stick straight down to prop up the front. Most of the ones I have seen are always bent underneath or broken off. If you drive the Bus for a long time, it's more comfortable for the seat to be propped up by the legs.
How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
Drew Ogden
Drew Ogden is offline
PostPosted: Sat Jan 26, 2008 2:56 pm    Post subject: Reply with quote
Doug, a late US barndoor would likely have sigla front windshields, what are your logos?
Edit: sorry, just saw that Greggy mentioned the same thing
Anchovy
Anchovy is offline
PostPosted: Sat Jan 26, 2008 3:44 pm    Post subject: Reply with quote
Doug, nice bus.
Are your door pocket rivets sliver colored or brass?
Are you sure about the mileage being 10K? It is interesting that the bus lost its motor, got a respray and has shifter and pedal wear like it has seen more use. You would expect the speedo to have rolled on a bus with those characteristics.
PostPosted: Sat Jan 26, 2008 3:50 pm    Post subject: Reply with quote
Anchovy wrote:
Doug, nice bus.
I was talking to Barndoor Dave today and he remembers when Rick Madden bought that bus from Jack White. Dave said when they drove it up from Oregon after Rick bought it that they blew the tranny up coming off the freeway. Luckily it was only a few blocks from Rick's house.
Doug thinks it has 100,000 miles, meaning it's travelled just over 10K miles since being advertised in '88.
Anchovy
Anchovy is offline
PostPosted: Sat Jan 26, 2008 4:32 pm    Post subject: Reply with quote
Of course, that seems to make more sense.
Did it come with the ambulance step from VW?
RockStock
PostPosted: Sat Jan 26, 2008 5:55 pm    Post subject: Reply with quote
Dougie - my bus' birth certificate says it was delivered to Riviera Motors, Portland, via San Francisco. Wonder if yours was the same
criminal masking effort on an og paint bus!
was Rick the guy who had it for sale in the Hot VWs ad?
-StockRocks-
RockStock
PostPosted: Sat Jan 26, 2008 6:21 pm    Post subject: Reply with quote
Sound deadening?
from the 53/54 Workshop Manual:
Forest Find DLX (55):
Unk BD:
Swedish 54:
all the pics i have show the 5"(?) wide black strip stuff on the vertical firewall section...
whereas the arch covers and lower firewall area appear match yours
-StockRocks-
Anchovy
Anchovy is offline
PostPosted: Sat Jan 26, 2008 6:48 pm    Post subject: Reply with quote
My '54 had a similar material under the front seat and helped to keep the springs from rattling on the sheet metal.
RockStock
PostPosted: Sat Jan 26, 2008 7:19 pm    Post subject: Reply with quote
Schmeling's 54/55 Sunroof Standard
Sound deadening, same location
One of the 4 rubber bungs too, btm right of steering wheel
[Over-rated bus, I was told(;]
-StockRocks-
Douglas Denlinger
PostPosted: Sat Jan 26, 2008 9:18 pm    Post subject: Reply with quote
Where are the feet? ^^^
The rubber stops are no problem to locate.....cross that one off the list Smile
Upholstery Haus
Page 2 of 9
